View Full Version : Acura TL, RL & ZDX
- simple coupe
- code p2101 after cleaning TB
- 2009 TL Battery Drain
- 2002 TL Rear Windows
- 05 TL: Cheap place to find replacement Leather?
- Anyone use 10w-40 in there TL
- 2011 Acura RL Dash Messages ISSUE
- 2005 TL worth consideration?
- EVAP and EGR Not Ready
- Alarmed
- Erase code will clear from ecm?
- Socket stuck in spark plug well
- 2008 TL Type S exhaust
- knock only when warm.
- Need help 99 Acura TL
- 07 tl leak? Common
- Suspension setup
- 2016 Acura RLX (General)
- 5G Legend (5G RLX) Access & Modulo Parts
- 2016 Tech: AcuraWatch
- 2016 Tech: Road Departure Mitigation
- NEED HELP--What controls 2005 RL AC Radiator Fan?
- 2001 acura 3.2 tl sputters upon first off then drives normal.
- 2007 TL type s
- Need Help! Battery Light Randomly Coming On!
- 96 RL issues.
- Looking for RL Mech/Specialist WA- Puget Sound
- 2002 acura TL vsa won't turn off.....
- Dallas car group/meet?
- 99 acura tl 3.2
- Holy Codes Batman F-can 86 issues 2007 Acura TL Type s
- 95 Legend type 1 no compression rebuild
- RL Center Console Armrest
- 2007 RL Info
- Battery is smoking
- 1999 acura RL gremlins
- 2007 Acura TL type S
- Looking for the highest power combo J-Series setup
- Coolant lead at rear
- A few small issues after trans rebuild. Need help.
- 2009 Headlights/foglight upgrades
- 03 CL axel question (6mt)
- TLX in SoCal?
- Oem wheels
- 94 Legend 150k Runs rough $1000?
- 2016 RLX MMC
- 94' acura legend LS coupe...good buy???
- Need help! 07 tl
- injectors not firing?
- RLX NAV Diagnostic Screens
- RLX Wiper Maintenance Mode
- Where to look for 07/08 TL Type S
- boosting my 03cl
- heater/front defroster on 2001 acura cl doesnt work!!!
- Did I pay too much 2004 acura tl ? (durp)
- Engine swap
- Help with 2000 3.2TL Glass Replacement
- Sport Hybrid Training (20 Days of RLX)
- 09 TL Cruise Control
- RLX Sport Hybrid Fuel Economy
- 97 acura tl 3.2 motor swap questions
- 08 TL GETS STUCK IN PARK AND SOMETIMES WON'T GO BACK INTO PARK
- RLX Hybrid SH-AWD
- 2007 Acura TL Type S electrical Problems?
- 2000 TL Heater/AC control screen lights out
- 1997 RL starter
- SH-AWD Torque bias ratio Discussion
- 2001 Acura TL swap questions
- RLX Chirping Noise
- RLX Wind Noise
- 2006 Acura RL - amazing gas mileage
- 2003 Acura TL (type S) multiple lights not working! (turn signal, dashboard, back)
- LOOKING FOR A TL 2008-2012 FOR TEST FITMENT
- My Brand New 2015 Acura TLX!!! (V6 w/ Technology & Advance Packages)
- Honda fluids
- starting issues on my 1997 Acura 3.2 TL, just hit 200,000 trying to keep her going
- transmission interchangeabilty
- No lower brake lights, other lights work fine 99 TL
- 2014 Acura TL. Any Issues?
- 07 Acura TL type S Tire pressure monitor system
- 2013 Acura ILX Steering Squeak.
- Smog test issues
- 99 CL -40 temp code
- 2000 Acura TL new battery no pwr
- 2001 Acura 3.2TL Acceleration Noise
- Just Bought 2000 Acura 3.5 RL for $200!
- idle problem J32A1
- 2003 Acura TL-S bad Idea?
- 96 TL 2.5 Battery starter cable
- 2006 TL Timing Belt Interval
- acura tl 3.2l engine
- 3M headlight restoration review
- 96 tl coilovers
- 1999 acura rl front lip oem
- cracked dash. yes, i know its common.
- Engine "ticks" when cold: creative solution?
- How do you remove the brake rotor on these POS TLs?
- performance rebuild kit for v6 5at? some japanese company? anything?
- Some TLX Details
- tl vs. tsx
- 2006 TL: aux input & bluetooth HELP
- 03 CL-S 6MT clutch questions
- RLX SH-AWD Has Revised Valve Timing
- 01 CL motor in 99 TL temp guage not working?
- High Pitch Noise from my Acura RL 2005
- Key Questions- 02 CL
- Sometimes long (really long) crank time, 2005 Acura TL
- 2014 RLX (5G Legend / 3G RL) TSB List
- wtb tl type s 07-08
- How bad is the TL transmission issue?
- flashing lights on dash of acura tl
- Teach me about the '10+ TL SH-AWD.
- UPGRADING from TSX to TL?
- Problem with 97 Acura RL Immobilizer
- Finally! A Good Advertisement!
- RLX Advance Reviews
- RLX Hybrid Wood Trim
- RLX Shocks (Explanation)
- ELD UNIT LOCATION--HELPP!!
- RLX w/Conventional Wheels?
- 1st Gen RL 3.5 Oil Pump Specs
- 2008 TL front speakers cut out
- 95 Legend Potential Swap ?
- Changing Oil Filter Holder 98 3.2 TL
- Visualization of P-AWS
- Krell Audio
- 2014 AcuraLink
- RLX Consumer Impressions
- Today is TLX Day
- 2014 RLX Sport Hybrid SH-AWD
- 1990 Honda 2.7L V6 running issues
- 2015 TLX GT
- 2014 RLX Advance
- Want to prevent a repeat dead battery when leaving for a week.
- 1998 CL 2.3L IAC problem.
- Can't remove belt tensioner!
- 2001 tl 3.2l
- 03 Acura 3.2 TL type S Project car
- 1st Gen RL Stereo/Gauge Cluster Removal How-To...
- 97 Acura 3.0 CL
- 2006 Acura RL windshield washer fuse
- 2003 Acura TL
- 02 Acura CL headlight
- SRS light won't reset, dealer can't diagnose
- No fuel
- Acura Rl 1996 136200-1380 VSV Part
- Trunk doesn't work on my 06 TL
- Wheel bearings
- Need help identifying an OEM Legend car cover
- 03 tl
- 03 Acura TL Engine Swap
- 89 legend v6l weird sound coming from engine bay
- 3rd gen Acura TL Suspension, Brakes, and Wheels
- pictures of cylinder head acura vigor vs tl 5 cylinder engine g25a
- 2001 Acura RL
- 05 TL charging system issue!!
- New battery keeps dying in 06 TL after a few days
- 04 tl: good starter, alt, battery.. But won't start
- Wobbling steering wheel
- headlamp problem , 2005 TL
- Set Base Ignition timing? Acura 3.2TL
- Need help for SH- AWD rear diff
- Wiring gurus, I'm calling you out!
- How to remove Acura 3.2tl fuse box (in upper left engine bay)
- Type S interior colors
- Acura tl 2000
- 2006 TL stutters and dies
- 99 Acura RL coilover help
- need some help
- tcs chek engine light on and d5 flashing !!!
- '96 Acura TL getting hot quickly and then whistling
- 2003 CL type S with bad tranny
- 2014.5 - 2015 TLX
- Revving While in Park (After Crash)
- 04 Acura TL Radio Code
- Changing of 06 TL A/T Front Rotors
- Acura TL 2006 Manual: difficult gear shifting after the clutch replacement
- MAF Sensor location on 97 RL
- [Acura 2.5TL] - What is this?
- 01 CL need tranny advice
- Acura TL AC blower motor failure
- 2000 Tl, Where to jump codes for CEL?
- Best source for transmission tear-down and rebuild information?
- Is the CL-S reliable?
- Trying to bring back a 97 RL that has been parked for 6 years - ADVICE/RECOMMENDATION
- any known problem with the KB1 (2005) RL?
- 2003 TL 177k miles Tranny Issue. Works 4 15 minutes then stops
- 96 RL Timing Belt Help
- can I swap cl s-type engine and tranny
- 2000 3.5RL D4 Blink
- j32a2 in a 03 TL
- TL navigation issues
- Should I get a TL?
- j series injector differences?
- 2005 TL A/C problem!
- 2010 tl not starting (flood damage)
- 2001 CL dies/stalls while driving... Never on highway.
- b7wa transission problem after rebuild
- Vigor parts websites
- Oil Leak
- Acura TL, RL, ZDX rear diff final drive?
- Head gasket torque sequence
- P1457 AGAIN
- 97 3.2 TL ABS wiring info
- learn me about 91 and up legends
- Excelerate J-Pipe Review/Issues
- 1997 Acura 3.2 TL
- Help with 1999 Acura TL catalytic converter
- acura 2005
- 2003 Acura TL Alarm problems
- 2004 TL Mil code
- Where are the CLs??
- CEL on my 06 TL (P0420)
- 2005 Acura TL Lost ability to arm factory security
- 3.2 TL electrical
- windshiel wipers going beserk
- Acura EL 1.7 windshield washer bottle tank
- 99 TL MAP sensor?
- Rear speaker deck buzz
- just replace 99 tl trans . where does this vac line connect
- NAVY SYSTEM & RADIO CODE FROM 05 ACURA TL
- 1999 acura tl compatible trans. help
- radio code
- 2003 TL type S - NO SOUND? Alpine CDA has power, everything connected behind it. HELP
- 2003 TL Transmission - Replace or rebuild
- Bought 2nd gen TL type S. Love the car, but PO removed aftermarket subs etc, no sound
- Acura TL Blower motor issue
- Chek engine light
- Ran into problems after battery died on me!
- TL NON Navi to Navi Conversion
- Acura 2001 TL low beam bulb change
- Acura TL Type S, 6 CD Changer not working.
- 2001 Acura TL, Failed:P0171, Pending:P0170
- 2006+ TL Question
- Please help, 2003 Acura 3.2tl radio code
- 1996 2.5 TL O2 Sensor Torque Spec?
- 2003 Acura TL transmission weird problems! help asap
- RL coilovers/suspension
- I have my radio code BUT
- 2001 tl idle problems
- Acura TL 05 Break upgrade
- 05 TL mirror problems while pushing seat memory
- What is this noise?
- TL shudders VIOLENTLY braking over bumpy surface
- 1996 Acura RL Fuel Pump ???
- 98 acura Rl radio code??
- followersam
- I need help please stereo code
- 06 TL rear brakes work, sorta.
- Was Acura trying to bullshit me
