View Full Version : Acura TL, RL & ZDX
- 03 TL Reverse to Drive Transmission Stall/engine drag
- temp sensor for the gauge location
- 92 acura vigor barely starts then wants to die
- The radio code I got from Acura website is wrong
- 2002 Acura RL 3.5, ABS Problem
- 1996 Acura TL suspension options.
- Common problems on a 04 TL?
- 02-03 tl hid install help!
- I am having trouble getting 5 posts
- Planning to buy 03 Acura CL Type S 6sp.-Have questions
- 03 acura tl v6 transmission problems
- error code!!
- Headlights
- Replacing a M7WA transmission - 00 TL
- Transmission? Engine mount?
- Car is hard to shift
- Torque Specs Transmission 3.2cl
- high kms on 3.2 tl type s
- Acura TL A-Spec Suspension....is it worth it?
- 2002 Acura TL Type-S occasional idle problem
- 91-96 legend koni adjustables fs
- '01 TL brakes shimmy, mainly right side
- 97 tl wont start in park
- '04 Acura TL SRS DTC Codes - What's the problem?
- 08 tl-s code p0171
- Question on TL rims???
- Indash tv/nav in third gen TL. Have one?how
- my tl wont start HELPits not starter or battery
- Please help!
- Mysterious Radio/Brake Light/Fuse and possibly Main Relay??? HELP!!
- Help! Radio Comes on when press brakes and turns off when release..
- 2006 Acura TL - transmission fluid: flush or drain?
- New RL, 2013 or 2014
- '96 2.5 TL starts then shuts off.
- suspension 1999 honda legend
- 2004 TL brakes.
- Some one help me asap?
- sputtering
- Your opinion: best year of third generation TL?
- 2003 Acura TL purchased in auction - so far so good
- CL-S 6MT transmission rebuild?
- Bzzzzt when I start the car
- 05 acura O2 sensor location
- '01 TL question on transmission
- Parts online
- What are the best brake pads?
- 05 tl goes to about 20mph then stops
- 2005 Acura TL hard to start!
- Help 95 Legend running very rough
- 96 RL Horrible MPG
- Need Help with my baby
- 2006 TL timing belt info and part numbers
- 2004 Acura TL keyless entry question
- Check this RL out.. good deal?? $7900
- 1996 acura rl bad fuel pump?
- Tires for stock TL-S wheels?
- Could this be a wheel bearing or a bad axle?? -00 TL
- TL's with wheels and stock ride height
- Bunch of questions after minor service at Dealer
- 1997 Acura 3.2TL Parts I order is always wrong?
- 2nd Gear Slipping - Giving Jerks
- 2001 Acura cl motor for sale
- Legend motor swap recommendations?
- ACURA TL TRANSMISSION HELP PLEASE!!
- Acura 3.2CL troubles (56k Beware) wtf does 56k even exist anymore?
- 03 tls dilema
- Need your advice. 2006 Acura TL - Is it a good deal?
- My RL
- What's this piece called?
- Hybrid RL! Impressive!!!
- Need some advice... 99 TL radiator fan not coming on and car overheats
- 92 legend locks problem
- 2010/2011 TL Good or Bad?
- 1996 Acura TL 2.5 - Ignition Problem
- 96 Acura TL 2.5 - relay cutting off ignigtion when you crank it
- Any threads with pics of RL with 18-20's?
- 1996 Honda Passport V6 Knock Sensor
- Oxygen Sensor location
- will the us j32a1 trans and ecu work with the jdm j32a??
- tl-s transmision issue
- 2000 TL Yep a bad auto transmission
- Slight hard shift when cold and noise in first gear, Should I still be concerned?
- I wish I found this site two days ago
- 2006 tl 80,000 miles tranny shot??
- Replacement Tranny for 2002 TL-S
- Plan on Buying a 02 TL Type-s any suggestions
- 96 acura rl wont start
- 05 tl, noise @ part throttle
- 2003 CL alarm sensor issue
- help!! right rear brake light doesnt work
- 1998 Acura 3.2 TL
- 2004 TL with 130k miles. Anything I should look for?
- WANTED: TL OEM Brembo Front Calipers
- 4G RonJon body kit
- Rear "H" emblem on 2nd gen
- Sub kit
- Want to lower 04 acura tl (opinions)
- need the helms pda files on how to pull the engine and tran from a 99 tl
- Looking for 01 RL caliper brackets.
- 1991-1993 Honda Legend EDM spoiler
- 04 Acura TL insurance?
- 2005 TL car won't start.
- 2004 Acura TL Base Transmission Problem
- 2nd Gen O2 Wiring Question
- Hood label locations -1996 3.5RL
- '99 ACURA TL 3.2L rough bouncing idle (see video link)
- 97 acura CL owners temp gauge question
- 2013 3rd Generation RL to be released at the 2012 NYC Auto show...
- Err 2 in Radio Display
- 97 acura rl..where to buy coilovers or...
- MY 2005 ACURA RL SRS Light ON, 81-64 and 85-64 , HELP HELP HELP!!!
- 03' TL Type-S No Driver low-high beam or either fog
- 03 TL transmission questions
- my car wont move in gear
- Air/Mix motor for 03 acura
- is this tl worth 10k?
- 97 3.2TL vibration under acceleration *need help*
- OBD@ code PO 401
- What Acuras should I avoid?
- 1994 Vigor
- 1998 Acura 2.3 CL, can I make it fast?
- I'm completely baffled...
- 93 legend oil/antifreeze mix problem
- axles
- 97 RL Transmission info needed - How many different versions?
- 2001 cl-s missfire
- Possible Purchase: 1986 Acura legend 2.5L 24V (pics)
- 2005 TL wont start up
- How to tell which bank has a blown HG on a TL
- 96 acura tl tranny
- portwork anyone?
- Help!!! 2005 Acura TL wont start!
- Good Deal? $850 - 93 Legend
- 2001 Acura CL front end collision.
- 2000 tl misfire on 5 cylinders/w multiple code and my tcs light stays on
- I joined the club ... again !
- 2002 TL keyless entry problem?
- Auto Transmission Fluid Change/Refill
- it feels good to be back...
- Feedback: Looking into a 2005 TL base (manual transmission)
- acura newbie here, have a question plz.
- 98 RL no spark after engine swap
- J32 starter ring/flexplate question
- Rennen Forged+Acura RL+20x10/20x11.5+Poke/Stretch/Roll
- 04-11 TL which years came with AWD?
- Any second gen CL owners here...
- Looking to buy a 2003 Acura TL..
- Break lights do not work can't shift out of park
- TypeS or no
- Need help from a current TL-S owner!
- 98' acura 1.6el 2300$ good deal?
- Vigor Charging Issue
- first gen tl help! getting the rear speaker covers off
- Having misfiring problems for my 05' Acura TL...
- will Accord V6 rotors fit on a '03 3.2TL
- Blower Motor
- 2004-2005 tl reliability
- new here
- 99 Acura TL Fumetsu ABTYPE-S Project
- Removing back cover Cluster*Need help*
- Need help with '99 TL Radio Code!
- Front Bumper & Headlight Removal
- 2001 Acura TL retrofit
- que es ACG S fuse
- '98 Acura 2.5 TL starts initially but won't start after driving
- New legend owner needs help!!!
- 1995 Honda Ascot. New to the forums
- NEW BRAKES AND TURNED ROTORS
- 05 TL- a/c not working
- Weird issues after maintenance/repair HELP
- New to the TL
- Remote works but key doesn't
- 2003 Acura 3.2TL Transmission Failure
- what transmissions are interchangable 00 tl
- h22 head on a 98 cl 2.3?
- 96 RL what fits?
- HELP PLEASE: Deisel in the 2001 Accura TL
- '05 TL non-Navi, blower motor fan always on full
- 96 Acura TL tranny
- 1999 acura tl idle problem
- 2000 Acura 3.2TL Transmission Problem
- acura rl coilovers
- Vigor Blower Motor Issue
- 01' Acura Cl Type S Head Light Housing Question
- OBDII Sensor Location in 2006 TL
- 93 acura legend, hope i didnt kill it.....
- 05 tl speed is off w/ stock tire and wheel size
- Acura 2002 3.2 TL help please
- Acura CL not starting?
- Help!! radio code
- Display screen locked - No manual for Acura TL S type
- does the 05 TL facotry 75% window protect from interior fade?
- RL parts car price
- 91' Legend MAF location??
- blind spot mirrors and how to get both mirrors to tilt down
- 02 tl axle seal leak...still
- DTC Code PO135 - PO155
- Cl Type S
- AT fill plug-2001 3.2CLS
- best atf for 01 tl
- 07 TL Type S Brakes
- Acura TL does deck lid vibrate with additional subwoofer?
- 96 Acura TL 2.5
- Thinking of buying an 05-06 Tl
- Passenger Heated seat
- Might purchase 08 TL type S, any current owners please advise
- Happy New Owner of 08 WDP Type-S!!!
- lip kit / mugen spoiler?
- 99 TL trans slipping but No CEL
- TL factory tech upgrade options
- 3.2 TL Engine NEED HELP!!
- inter changeable wheels and tires
- How to remove carpet?
- [Questions] Acura 2.5 TL 1996
- looking to buy a acura tl
- Dead passenger seat warmer in 04 TL
- Clutch Problems 06 TL
- is this legit
- D5 light flasing TL
- 1998 acura 2.3 cl coupe problem
- *help*dashboard, interior,turn signal and exterior back light would not turn on!
- 2003 Acura 3.2TL Transmission Problem
- New to us 2000 TL need parts...
- 99 Acura TL
- 2002 TL Will Not Crank After Sitting For 4+ Months
- 2000 Acura TL overheats when AC is on
- New fluids for SH-AWD vehicles.
- [Help] Problems with Audio System
- 2003 Acura CL Manual Trans
- 2001 tl fuel filter?
- 2000 TL Alarm Problem
- Acura tl 3.2 - Turbo, engine swap?? how do i boost performance, hp, etc.
- 2000 TL Alarm problem
- A/C problems & its hot, HELP!
- for those who have one: considering 2010 AWD manual TL
- 99 3.2 TL cruise control problem???
- NEED HELP GETTING MY RADIO CODE !! =[ HELP 99 ACURA TL
- 98 Acura CL 2.3...accord trans work?
- 2012 TL Rim Weights?
- Removing head on my '96 2.5TL what to expect.
- help removing valve cover gasket
- 05 Tl Type s MT Trans problem
- DTC P0441
- HELP!! I got oil in my spark plug holes...
- My TL & ITR
- 2000 TL SRS light reset
- NoObIe
- J32A2 Dual Mass Flywheel disc play?
- Infiniti M45 Wheels????
