- 1990 Acura Legend Missfire
- Motor Mounts
- ZDX Designers Video
- 05-07 RL and 04-06 TL ABS/VSA modulators should be recalled- complain to the NHTSA
- anyone has crutchfield mastersheet for 01 CL?
- TL OEM 17 wheels handling
- 1997 Acura TL wheel specs. (did search)
- Can 96-98 3.2TL engine swap into 91-95 Legend?
- Looking for a used or rebuilt engine for my 1990 Legend.
- 2001 acura tl swap (09 tl type s)
- TL navigation woes.. Help!?
- 2000 RL Squealing noise
- Staggered Wheels on 6speed 05 TL
- RL Exhaust tip question and where to buy?
- new left side bearing stiill humming
- How hard is it
- Headlight Unit for 96 TL
- 02 TL Rear wheel hub
- Need advice 2002 Acura TL TypeS
- TL type s ECU
- trading a car you dont have paid off?
- Acura TL Opinions!!!!
- SH-AWD in the Snow
- Are We Getting a 2011 TL A-Spec ?
- Where to locate Evap Emission Control Sensor on '96 RL
- NEED HELP! POSSIBLE BLOWN HEADGASKET 02 rl
- Transmission Problems
- TL vs RL for a daily driver need some input
- ***Radio code help!!!***
- 02 CL TYPE-S PART OUT
- c35a dimensions
- 1G RL NAVI QUESTION
- Acura RL question
- New to site
- ****.... with time, the new TL is actually starting to look DECENT
- Anybody from DFW area?
- Speedometer and Odometer not working
- question about my TL 04 navigation GPS screen
- LOOKIN FOR A 2000 TL TRANS.. IN N.J...
- 2000 3.2 tl misfiring codes plus more
- Can't enter radio code because 6 button does not work
- 05 TL Steering Wheel Light is burnt out?
- Lower Prices for 2010 Acura TL !!
- Buying advice needed - new to acura. Help appreciated
- HELP...
- 97 Acura TL radio code
- HELP! 2009 Acura TL VSA and ABS lights on!
- 04-06 front fog light?
- wheel question??
- FS: 2002 Acura TL S engine/trans
- 2005 acura TL lights on but car won't start
- engine runs rough. any suggestions?
- 99 tl radiocode
- Painted my stock TL rims. what do you think?
- Installing Navigation 03 TL
- Crash Tests Acura TL 2009 - 2013
- Service light code?
- Question about buying 96 RL?
- Multiplex Unit for Acura TL 2005
- 3g TL single exhaust
- Upcoming HT Tail of the Dragon Rally
- More Good News
- '96 Acura TL 2.5, NEED RADIO CODE PLEASE!
- help with accesory belt 2000 tl
- December Sales = 4G TL Now Best Selling Acura
- 2003 Acura tl type s Please help
- Replacing Cl Type S HID
- Does a 2003 Acura 3.2TL have or need a mass airflow sensor??
- Requesting Pix of clean 2005-2008 Acura RL
- How to remove/install foglight on 07 Acura TL?
- 2004 TL CEL code P0603
- 2003 TL. How can I tell if I have high flow Cats???
- Increase compression ratio on TL 3.2
- 4G TL Brake Cooling Ducts
- Transmission problems only on Type S models?
- How to be prompted for the radio code?
- Acura 2.2cl 1997 Strut & and Lower Ball Joint
- What the Power Plenum Grill Originally Looked Like
- RADIO CODE URGENT PLEASE ASSIST
- VIP'd 2G TL ...!
- First time posting up my TL
- Yet another Radio Code request! 2001 Acura TL 3.2
- 03 tl surge help!!!!
- new proud owner of a 06 tl
- 96-98 RL Where to find parts and filament question
- 4G TL Nose : Does Carbon Fibre Help?
- 3.2 TL cluster color change
- 02 acura rl check engine light/timing belt issue?
- 2010 TL Gas Mileage Report
- Cant put 3.2 Cl-S in gear but can when key is entered into the rlease slot
- 97-99 CL Headlights. Any nice aftermarkets??
- 1997 CL immoblizer question
- TL Type S Tails on Regular TL
- Will a TL type S transmission work in regular TL?
- Acura CL - Problem with electronic signal modifier?
- J-pipe and test pipe= better fuel economy?
- 04 TL transmission compadability?
- G25A vigor ECU question
- Anybody Heard of the "Midnight Chrome" TL OEM Grille?
- CD automatically pops out, wont play....help!!
- 1999 Acura TL Radio Code Please anyone??
- how do i adjust my headlights?
- Why Fly?
- Question about A/T Clutch pressure valves (A&B)
- shops in dallas or houston???
- Headlight restore
- First Drive Reviews of ZDX
- jdm legend USDM RL 05 08 conversion to 09+
- Problems starting- HELP!!!!
- Here's the guy you all hate.... (Acura TL Styling)
- G4 TL Exterior Designer
- Interview Matt Harget (G4 TL Chief Engineer)
- Help! 04 Acura TL Trans problem!
- ZDX Pricing Announced
- 96 Acura 2.5 TL radio code
- Anybody looking for a 2010 Acura TL AWD 6-6 w/HPT ?
- 2003 Acura 3.2TL Transmission
- The TL Grille: Is This Better?
- 02-03 replacement headlights/fog
- searched: link to acura TL tranny recall
- 99 Acura Bose Stereo
- 99 TL Heater problem
- 04' WDP- Good deal or no?
- 22mm sway bar vs. 28mm sway bar
- hid projector help
- Spark plugs + Wires?
- acura tl tranny recall question
- Question about buying a TL of CL Type S:
- Should I buy one or should I stay away?
- Custom aux input for 99 TL?
- 2000 3.2TL - Hands Free Bluetooth Car Kit
- Vibrant Performance Mufflers on My Acura CL-S. [VID CLIP]
- 02 TL Photoshoot
- 92 Acura Vigor Radio Code Doesn't Work
- Seat Re-Adjusts When You Open the Door
- 04-08 TL Tail lights
- Discount Acura Parts?
- Need help with 00 TL tranny asap!
- 97 CL jdm engine question
- 05 TL Problem
- i need help on a engine swap
- battery problem
- 94 vigor
- Looking for 2007 TL stock wheels
- 96 TL 3.2 AC and cooling fans inop.
- radio doesnt work
- Intake manifold Question
- 2G TL wheel fitment question
- busco amigo latino en este foro
- What TL performance mods have you done? Worth it??
- i need help wit my acura tl 2004
- Two issues with a 2003 Acura TL - Please Help
- 05 Acura TL Bending Wheels?
- I need a anti theft radio code for 2000 acura 3.5 RL
- 2010 Acura TL 6spd SH-AWD Lowering Springs
- TSX or TL ?
- Thinking about buying a older RL
- Oil pressure problem on 02 TL
- Follow up on: 99 TL engine dies
- Help throwing codes 2002 RL
- 94-97 accord suspension on a Vigor
- Official Announcement TL SH-AWD Six Speed
- Offical: 2010 Acura TL 6-6 Will Come
- NEED a good used map sensor for Vigor
- WEird light issue
- HELP ME 1997 Acura cl
- rise up control on 90 legend
- 07 TL Type S navi ?
- Please help! Stranded in Seattle, car starts then dies 96 tl
- Please help! Stranded in Seattle, 96 2.5 tl starts then dies
- delete this...
- 1998-2003 Pros / Cons Acura TL
- Engine dies
- NEEDS HELP deciding which exhaust system for 2008 tl
- noob question: how to shift in an automatic 2008 tl
- 98 cl power steering
- what coilovers???
- timing belt/wp tips on 97' 3.5 RL
- 06' TL 3rd gear bulletin?
- HELP? '04 TL Spark Plug Gap?
- Cash for Clunkers Legend
- Acura TL 2009. How do you mute the navigation system?
- check out TOV ZDX montage!
- Need help deciding which TL?
- 03 Acura TL headlight and Blower Issues
- 03 CL Vibration
- 2001 acura tl radio code
- Question about changing a motor
- Have a ? about stereo harness
- 02 TL Ball Joint
- Do TL rims fit?
- Acura CL type S
- Spreen Honda Meet Sept.12th
- newbie question!
- Acura TL Crash Test (Side)
- 96 tl head gasket
- Looking to buy an 05-06 TL
- Photoshoped a new TL front grille
- forgetting to shift
- 93 Vigor starting issues.
- 02 TL Type-s with brake issue ... need advice
- 92 acura legend question
- 05' RL Driver asking various ?'s
- 92 vigor braking problem
- Location of Blower Motor Resistor?
- Do I buy her the '04 or '05 TL 3.2
- g25a swap!!!
- 01 3.2 CL T-Belt write up?
- 2.3 CL potential
- Is this where the LEGEND fits in??
- wood grain steering wheel
- So did Honda ever fix the tranmission problem?
- 2007 TL, what if you run 87 octane gas
- ITR owner, lookin to DD a 3rd gen TL! need some input fellas
- wtb 98-02 type s tl wheels
- 02 RL complete swap into an 00 RL
- sway bars
- Acura 3.2 Type II Intake / Trunk Emblems Available
- who makes good 03 tls rotors or a big brake kit???
- 1999 acura RL not turning over
- Navigation went out on the tl
- OEM pop-screws/plastic?
- Hello, new here and am considering a 2006
- 2000 Acura 3.5RL *Radio Code*
- possibly getting a 2000 acura tl non type-s
- 02 tl type-s front brakes issue
- Looking to BUY
- 98-02 accord compatible parts
- 2004 TL ECM
- CF goodies.
- My capret stinks!
- Have code - Won't work!
- 2004 acura rl navi and climate control issue
- I need A diagram
- Changing transmission fluid? 2003 3.2TL
- Is a J32A3 a Zero Clearance Engine?
- Is a J32A3 a Xero Clearance Engine?
- 91 ACura legend Radio code
- 02 TL Rear Wheel Bearing Assembly Replacement Help???
- 1997 Acura RL New Air Conditioner Install
- Bought a J32A3 for my '96 TEG... PICS!
- 98 3.5 RL body kit and taillights
- 04'+ Coilovers?
- Torsen LSD? 2005 TL 6 Spd
- 2000 RL STEERING WHEEL LIGHTING
- navi up date
- a-spec lip kit 06'
- acura tl 06/07 front end..possible swap?
- harmonic balancer question
- power steering rack help!!!!
