Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
99 TL MAP sensor?
Old 01-04-2013, 05:30 AM
kgkmav's Avatar
Icon7 99 TL MAP sensor?
I have a 99 TL with 243k miles. I didn't drive it for like a month and when I got in, it wouldn't hold an idle. It kept jumping around on me. Is this the MAP sensor. I just threw a code (my dad has my reader so I can't read it yet). I have cleaned the EGR several times. Think the MAP needs cleaned as well? Thanks again.
Old 01-06-2013, 07:51 PM
go-part's Avatar
Default Re: 99 TL MAP sensor?
I would first get those codes, then you will have a better idea of what your problem is.
But in the back of your mind the next steps you can take are replaceing the MAF and the IAC(idle air control valve).
You can try cleaning the IAC while you are waiting..
http://www.ehow.com/how_2301261_clea...tor-valve.html
Old 01-07-2013, 03:36 PM
kgkmav's Avatar
Well I got my code reader back. It is throwing a P0505 Idle Control Valve Malfunction. I'm going to see if I can bring up a diagram, but is this pretty easy to fix? Seems like it should be since it is right there on the side of the manifold
Old 01-16-2013, 12:48 PM
kgkmav's Avatar
So I unplugged the sensor and it didn't throw the code again. Do I need to drive it around like that, or when it throws the other code (from unplugging) should it just throw that one too?
eggie75
04-07-2008 01:40 PM
TRYLSTEG808
05-28-2007 07:40 PM
92ehatch
16
02-19-2007 11:41 PM
chrysler kid
09-28-2004 07:24 PM
Quick Reply: 99 TL MAP sensor?
