View Full Version : Acura TL, RL & ZDX
- Water on Passenger Floorboard
- front rotors question '03 TL
- 2nd Gen TL Service Manual
- 96 TL Foglight Question
- 02 Sensor help. Bank 2/Sensor 1...Location?
- 97 3.0 CL dies randomly
- Paint code ???
- does 3/5 Series BMW rims fit on My 06 Acura RL?
- Legend Hesitation
- TL headlights
- Pics of VindiCated's TL
- Do my GS400 wheels fit a TL
- 2004 Acura TL hard start problem
- TL automatic windows....
- Hello... New to acura world
- can i run an aftermarket amp and subs on my 03 tls radio
- 2004 TL Engine ticking problem
- Type S tire size?
- valet switch
- Engine Over-heated! Is it okay???
- Acura CL
- No start: Related to Alarm immobilizer
- HID conversion for 03 TLS fog lights
- 3g imminent trans failure?
- suspension mods
- 199 vigor timing belt question?
- anyone with an 09 TL?
- eibach??
- 2006 RL Help Needed, Runs Flats & TPMS
- 04 TL Wheels
- 2002 3.2 type-s swap issues
- 2000 3.2 TL Engine Hesitation
- Can anyone check this VIN for me please
- Radio code for Acura
- Resonator Delete
- For Sale. Exhaust Tips.
- Is the TL Tranny Issue Large Enough to Concider a TSX Instead?
- Taking the 05 TL to the dealer tomorrow for 3rd gear...have a question
- Why is this sooo cheap?
- Tl navi question
- 05 TL- Impending trans or torque converter failure?
- Jdm question bout the tl
- What color to paint oem rims.
- Thinking of buying a 2006 TL...
- Help Help...07 TL
- Help - cl tech question
- 03 cl-s lip kit
- 2002 tl motor and trans for sale
- 2003 acura tl
- just bought 99TL looking for advise and where i can find some parts
- Acura Optionz!????
- clutch is bad 2004 TL
- 98 TL ignition switch
- 2004 TL with engine sputtering
- flashed or re programmed ecu for '05 TL???
- 08 Acura TL/S Factory woofer swap
- who makes headers for an 05 tl? and TL vs. Type-s
- Help me with my 04 TL power steering pump please.
- 01 cl driver seat wont recline
- Help with airbag cap removal
- can i put an 02 5 speed tl trans into my 99 tl
- CD changer on 06 TL doesn't work
- Acura TL 2002 Radio Code
- 97 rl
- Trouble with Nav system
- Stock cd player and amp wiring diagram
- Acura CL-S Transmission Cooler & Mangnefine Inline Filter Install
- 98-02 accord susp fit 95-98 tl
- acura vigor will not shift
- What do you think? 19" Rays Forged wheels.
- 2005 TL Transmission & brake Fluids
- acura transmission interchangable
- 2000 TL Passenger Seat Fuse
- 2003 cl type s need help again urgent!!!
- 96 3.2 TL- Heater is driving me nuts!!
- Wheel Fitment Whore TL Style
- 99 TL Misfiring Problems
- New TL
- cl type s need help
- Fresno Acura Meet Jan. 31, 2009-6PM
- delete
- 99-04 Acura Tl/Cl parts
- 2004 TL Audio Problems
- cl type s
- 99 acura tl with problems
- Timing belt and water pump change 01 TL type S
- 99 TL navi software help
- anyone have spring rate info for 96-04?
- Is this where ppl with CL's post comments/pics?
- Resetting Maintenance Display Codes
- no heat!
- TL airbags?
- 09 acura tl needed for r&d
- 2007 Acura TL-S Exhaust
- head light adjustment on 02 acura tl
- New to the site, but not the scene
- another radio code needed
- 2002 acuta TL AC/Heater making noise
- 1997 acura cl head unit installation help
- 3rd gen TL tranny fail
- 04-08 Acura tl lowering springs
- Legend Overheating
- TL Noob quick questions
- 92 vigor GS
- E-Brake help
- Yea, another radio code request
- What color is this?
- How to wire stock BOSE sub with aftermarket deck?
- Valve lash clearance spec: acura TL 05 base
- 96 TL2.5 heater blower help
- Tl or cl v6
- 2008 tl type-s
- 2g inspire side marker
- trying to find a white TL build
- Just bought 01 cl-s have a question. Tranny q's.
- 99 TL Battery Problem
- TL type-s 3rd gen??
- new here.
- Acura Code p1607 and PCS light
- 2006 RL Oil change
- Honda Logo Engine swap???
- Legend overheating
- FS and WTB
- vibrating at high speeds
- 2002 Acura RL AC Clutch not engaging
- 2002 TL Type S - Help Mechanic Screwed up
- Manual Tranny on 3.5L V6
- DIY: How to install lowering springs on a TL Type-S
- DIY: How to change TL-S Brembo Caliper brake pads
- S3 light blinking
- 2003 CL type-s
- legend....
- 02 Acura TL Type S Fuse Diagram
- 2000 Acura TL Transmission Recall
- TL heat not working
- brake help 08 tl type-s
- Will 235-55-17 tires fit a 04 TL???
- timing belt/water pump replacement
- Key fob calibration
- anyone ever swap a cl type s motor/manual tranny into 99 tl-p
- Buying a 96 2.5 TL..... Need words of wisdom
- 2003 element making wierd sound
- confused
- J32a2 engine tech question
- help dont know which bulb
- 2003 Acura 3.2 Tl and 2003 Honda Accord Underspoilers and body kits?
- 99 CL TCC CEL
- HELP STEREO CODE FOR ACURA TL 3.2
- Buying a 2002/2003 Acura TL Type S. Questions.
- 2002 TL with Navigation system
- Problem with TPS Throttle Position Sensor and Shift Lock 99 TL
- quick question: is 06 TL v6's valve hydaulic or mechanical?
- 2005 TL HELP!!
- timing belt, water pump replacement on 2003 TL type-S
- my car
- 2002 acura tl type s
- cl 6speed into 02-03 tl type S
- Oops... need valves replaced
- 99 tl, no dash lights, no running lights
- 2001 acura 3.2 cl Transmission problems!!!!!!!
- 97 acura wont TURN OFF PLEASE READ!!!
- 3rd gen wheels on a 1st gen?
- New 3.2CL-s6, New member
- common problems on early tl? 95, 96, 97?
- 1st gen tl manual swap?
- speaker size
- 99 CL 3.0 Parking Brake Light Always On.
- Radio Code for 03 TL
- SH-AWD fluid
- my suspension is creeking and squeeking--help!
- IAC LOCATION
- auto tranns on a 3.5l v6 legend
- 01 acura cl blinker problem
- Headlight adjustment on my 2005 Acura RL?
- Help me to find code for Civic CD Player
- 2010 TL Six Speed Re-Affirmed
- 2002 TL Driveability 84K miles; Hesitation and Vibration at variable Cruising speeds
- offset question...help
- Help! Resetting ABS, SHAWD, VSA etc.. (Battery died)
- why does my steering wheel wobble when i brake under high speed?
- STEREO CODE FOR ACURA TL 3.2 2000
- 03 TL: Electric noise in reverse
- Does a 5 cyl '93 acura vigor have a vtec in it?
- my battery died and i need a radio code for acura tl 2.5 98
- 08 TL Type S Cat Delete
- Fog lights not working?
- (04-08 TL's) how many miles did your OEM tires last?
- need help! new to the j series motors....
- 1997 Acura CL Radio Help
- Long Shot ... Can someone help me find ....
- Saw the new TL...
- are these window visors OEM?
- 2003 TL-S Wipers Not Working
- 1999 acura tl 3.2 vibrating in drive at idle
- 2002 TL, every cylinder is misfiring help??? Quick help if possible
- WTB: D2R bulbs.
- looking to buy
- U V Kenny help me out....plz.
- 2005 ACURA RL MANUAL SWAP
- Need Parts : 1999 Acura 3.5RL
- 01 acura cl type s headlight bulb replacement... need help
- What do you think of this deal on this acura RL?
- Acura cl 2.2
- Help! I need injector connectors...
- 04 - 08 Body kits
- Remus Mufflers on My Acura CL. [VID CLIP]
- Electrical Problem (LED on heated seat switch)
- tl front on cl help?
- Anyone changed a gen2 Acura CL rear wheel bearing? Easy?
- thinking of picking up a 99-03 TL but hear they have trany issues is this tru
- 2003 3.2 CL advice
- 02 TL-S, a lot of things stopped working all at the same time
- '03 Acura TL won't come out of park w/o using the shift lock release
- 99 Acura 3.2 Tl Trunk HELP
- Long Shot 89 Legend
- 2000 RL wont start
- jus changed my (vsa) abs rf side wheel sensor..???
- Legend Couple performance parts???
- Acura CL Windshield Wiper Not Working
- 02/03 conversion
- 2001 TL code P1457
- Double Din Radio
- small jump when i start off
- 01 TL Maint. Light
- 03 TL-S heater not working
- 99 CL V6 Trans slipping
- Buying a 04 6sp TL tonight need help
- TL Dead Battery = Normal?
- Want to buy all Weather Mats??
- HELP PLEASE
- HELP MEEEEEE
- FOG lights
- Suspension Help 96 Acura TL 2.5
- TL SUSPENSION
- Plz help me 4 radio code!!!!
- need a code for radio
- tapping under acceleration
- RADIO and NAVI CODE
- Is it difficult to remove the HID bulb on a 99-03 TL?
- Radiocode for my acura tl
- 96 3.2 TL head bolt torque specs?
- 2003 ACURA TL WINDOW WIPER and WEATHER STRIP PROBLEM?
- quick question about tl's please don't flame -_-...
- 04 TL 6-SPEED, Want new shocks and springs. Sugestions?
- FOR SALE ACURA 3.2CL S Type
- 02 RL vsa problem
- Isn't an Accord a TL??
- Just got me a 03 TL Type S, have a few questions.
- coilovers
- New member needs help. 2003 RL electrical problems.
