Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2016 Tech: Road Departure Mitigation
Old 06-03-2015, 05:36 AM
H-T Order of Merit
George Knighton's Avatar
Default 2016 Tech: Road Departure Mitigation
New Technology Unique to the 5G RLX Sport Hybrid (5G Legend)
Road Departure Mitigation (RDM)4
New for the 2016 Acura RLX Sport Hybrid, Road Departure Mitigation (RDM) uses a Monocular Camera (mounted on the upper portion of the windshield) to identify solid or dashed painted lane lines, Botts' Dots and Cat Eye markers. RDM uses both steering force, via EPS, and braking force, via VSA, to help the RLX Sport Hybrid from leaving a detected lane or detected roadway.
The monocular camera can recognize lane features and identify a lane or roadway edge. If the RDM system determines that the RLX Sport Hybrid is about to leave a detected lane or roadway defined by solid lines without a turn signal in use, it will provide steering assist (primary) and, in rare occasions when steering is not sufficient, braking assist to help the driver stay on the road. If a lane only identified by dashed lines, Bott's Dots or Cat Eye markers and the system determines that there is an unintended departure, no braking assist will be provided. Instead, the RLX Sport Hybrid will use active steering force to help return to the detected lane. RDM is integrated with the Vehicle Stability Assist (VSA) system to provide moderate braking, and with the Electric Power Steering (EPS) system to provide steering input.
Multiple visual and audible warnings alert the driver when the RDM system is taking corrective action. These include a lane departure warning on the driver's Multi Information Display (MID) along with an audible warning. RDM also has a customizable initial warning of either a steering wheel shake/vibration and/or an audible alert. This can be customized in the vehicle settings.
George Knighton
09-08-2008 04:38 PM
namberland
35
12-16-2007 08:11 AM
JMelt4
04-27-2007 08:43 AM
Simple SOHC
12-18-2003 04:40 AM
Quick Reply: 2016 Tech: Road Departure Mitigation
