View Full Version : Acura TL, RL & ZDX
- 03 Acura Cl Type S popping on turns
- 99-03 TL engine/trans vs. 04-08 TL
- i think a lot
- factory HID ballast question
- How many CFM do stock heads flow?
- 2000 Acura RL
- Help, I need the radio code for my Acura TL 2001
- Radio Code Acura TL
- Radio Code
- 2003 Acura 3.2TL DRL Module
- Keep Factory BOSE Sub w/ Aftermarket Headunit
- 99tl idle problem after storage. (iacv problem and solution.)
- new to the forum
- wheel hub and bearing question
- Buddies 2003 3.2TL Type S is going wacky - Help please.
- My (KA9) Acura RL / Honda Legend build
- Should i run these wheels?
- 1999 Acura TL Navigation DVD
- 96 3.2 TL not starting : what do you think?
- Any takers...03 cl supercharged on auction.
- 2007 TL or TL Type S
- Size of the '04-08 TL decklid
- Rear end sway 1997 TL
- 1999 Acura TL Types-S Overheating
- 2007 TL 80K too many miles?
- 2005 TL alarm...
- 02 tl-s rev ?
- radio displays C 1
- question regarding OEM full nose bra ....
- NEW TO THIS SO HELP ME OUT A BIT.
- 99 RL COILS/SPRINGS
- 02 tl-s cruise control problem
- 1997 TL Headlight Problem
- 01 CL type s what to upgrade first
- 1995 Honda Raf-aga Loopy Speedo
- 96 TL 2.5 window motor
- New Whip
- 03 tl-s
- opinions on buying a 2001 acura CL
- Wiring problem Acura 2.2 CL 1997
- Help! 2002 Acura TLS Issue
- Some Suggestions, New to this.
- URGENT HELP ! less than 24hrs untill purcahse - TL OR TSX
- Need help with 98 cl door lock problem
- 2002 TL suspension help
- 20" Wheels
- 1996 Acura 2.5 TL, Got in an accident, totaled? (Pics)
- Roaming idle on first-gen Legend.
- Tail light question
- 06 TL Suspension compatiability
- 2002 Acura TL
- 01-03 CL auto to manual?
- 99 Acura 3.5RL 871xp RM OEM Alarm Problem
- 2003 acura tl type s problem. need advice!
- Question about Legend wheels
- Vigor map light wiring diagram- DESPERATE
- where can to find deal on suspension
- Rare color combo? 06 TL
- 96-98 TL jdm 2.5S front lip PICS!! RARE*
- 99 TL engine harness
- Acura Legend Question?
- 2006 acura tl heater blower is not working!
- 2001 TL red..ish headlight?!?!?!
- NEED HELP WITH MODS?
- 04+ TL pro's and con's
- Acura Legend Radio Code
- ECU? 3.2TL HELP
- 02 TL is this a deal?
- 03 Acura TL Radio/Navi Code Assistance!
- HELPPPP tl-s into tl swap
- 04+ Acura tl's Reliable at high mileage?
- any links for radio install on 00 tl
- 2005 TL won't start...searched
- 99' Tl Ignition Switch Question
- 1999 Acura TL Battery Problem HELP!!!!!! NOT CHARGING :(
- '03 TL driver side low bulb out w/condensation in headlight
- TL problems....uhhhhh!!!!
- front bumper
- 07 Acura tl all season tires uner $550
- Trying to find a very specific picture
- 06 TL suspension help
- 03 tl-s radio problems
- '03 TL type s tranny issues?
- '03 TL 88k stutter@ 1750 rpm 60mph
- transmission fitment for 2001 tl non type s
- 97' Acura TL struts
- Limp mode + CEL on cold mornings...
- 2004 TL pad / rotor replacement write up?
- Air in cooling system
- 03 acura cl ??
- 1997 Acura CL auto tranny problem,
- 1998 Acura RL Premier or 2002 Accord V6 Coupe
- TL Type S 6 speed transmission problem.
- 1997 Acura CL Bent LCA Mount Bracket question
- 02 TL Type-s W/codes P0740 & P1740
- 01 CL tranny into a 03 TL?
- c32 questions
- dont know what to *se
- have a question about 2004-2006 acura tl ecu
- 2010 TL Can You remove speed governor and turn off daytime lights?
- Spongy brake pedal on '06 TL
- 2005 Acura TL E-Brake not working
- 07 tl front grill
- wdp 3rd gen tl roof spoiler?
- Need Radio Code
- NBP on SSR Type Fs
- Question on hose
- 03 tl type s questions
- TOUGH QUESTION... 2003 ACURA 3.2TL
- 05 acura tl suspension help
- need some help with my tl suspension
- Fair price for a 07 TL type S???
- 04-09 TL Question
- Acura TL heating problem
- 2000 TL 3.2 tail lights dont work
- Acura OBD2 Codes
- 3.5 swapped Auto Legend wont down gear..
- 99 RL Valve Tapping or something else?
- ecu
- Wheel Fitment Guide
- 98 3.2TL makes clicking noise behind dash..
- Acura 2001 RL - Removing Radio
- 06 tl a/c blowing snowflakes!!freezing up
- 02 acura TL type-S pcm replacement, programming needed?
- Plastic around automatic shifter
- Request Bumper Cover Part Info
- Wheel Reboring, In Socal
- looking at a CL-S 6 tomorrow
- 2010 Acura TL in Targa Newfoundland
- '97 CL window stuck down, help!
- Body shop in Dallas area?
- 2000 Acura - 3.2TL Check Engine Light
- 2004 TL Transmission shifting
- Is my rebuilt tranny bad?
- 96 acura RL - general questions
- acura TL ????
- SPEED Channel Test Drive: TL-SH AWD w/ 6sp
- 07 tl type-s calipers on a 06 auto tl?
- Acura TL Warranty
- 2003 TL Transmission Solenoids
- 94-04 3.5RL Blown/Locked Up Shocks AFTER Vehicle is Raised on Lift - Honda's Take
- 04 TL Timing Belt
- Timing belt is skipping, engine bogging
- I need help Please....
- Helloo
- 3G TL Swift springs
- new to site need help w 89 legend
- TL with CT or Type S ?
- 2dr headlights on a 4dr?
- rear visors
- 2004 TL engine swap into a 2000 Acura TL
- 1999 Acura TL Headlights
- 2000 TL Transmission general questions
- interior colors
- 02-04 RL Blown Front Shocks - Need Help as a Shop Manager
- Acura 2.2cl 97' Strut Fork
- why does my car keep heating up?
- AEM FIC good for TL or kpro?
- tl still heating up
- 2010 TL advise
- 97 3.5 RL speedometer is off
- 2001 acura cl s
- replacement rear view mirror for 03 TL
- Acura TL SH-AWD 6-6 vs Audi S4
- VERY SERIOUS GAUGE CLUSTER PROBLEM, NEED ALL ACURA GURUS HERE
- 2012-2013 Acura TL MMC
- 3m DI-NOC carbon fiber vinyl interior on 04 TL check it out
- Need Radio Code
- 97 ACURA 3.2TL, OVERHEATING
- DO NOT Need a Radio Code, But Have a ?
- 1996 acura tl
- help 97 acura cl
- help with 98 cl
- Thank The Lord Most TL and TSX Owners are Women!
- 99 tl battery light on cluster?
- Looking for new tires
- A-Spec Suspension
- Reset light
- Weights & Measures: How Much Unsprung Weight Does A Racingbrake 2-Piece Rotor Save?
- Brake Specs
- Differences between 2004-2008 tl?
- Radio Code Acura TL Need Help
- Introduction of myself and my 1994 Acura
- 2004-2008 TL
- What to look for when buying a used UA5
- Engine Noise Help w/ Videos
- for sale! 2002 acura TL-s motor 265hp 74k miles
- Parts Question on 2004 TL
- turn brights on and headlights turn off
- 93 acura legend motor swap??
- help back breaks locked up
- Resetting Abs and tsc light on 03 3.2TL?
- Learn me the 2008 TL type S : wife just bought one
- Radio will not turn on 2005 TL with Navigation
- J32A3 use J32A2 or A1 Block??
- 06' TL optional wheels?
- p1399 code
- Headlights
- Found this purple TL on another site
- TL 3.5L vs. RL 3.5L
- Impact Wrench
- J32 P2R Power Plenum
- 01-03 cl
- D4 light??
- 99 TL Aftermarket struts
- New TL Type-S Add-on's?
- CL and TL transmissions?
- For Sale: CA 1999 TL Wheels
- Gear Shift Sticks
- Foglights on 1st Gen RL
- Alternator Removal, 1st DIY
- Acura Legend Transmission Swap
- People with 07-08 TL got a question..
- My new 05 TL
- Need to trade my ALP Base Exhaust for stock.
- Error Code 6
- Converging '06 TL stereo with '07 for AUX, mp3 support
- 97 RL odometer help/ looking for
- 2002 Acura TL Type S - Can Wrong Oil damage motor?
- TL maintenance light is on, how can I turn it off?
- Typus ski rack for Accord Inspire/Acura Vigor fitment on Accord?
- Where is the radio fuse for a acura tl??
- Anyone ever S/C'd the Auto TL?
- 93 Acura Legend
- 2001 acura cl type s
- 06 TL Hands Free Link Help
- How do you access the Foglights and front turn signals on 4th Gen TL?
- IF YOU NEED A RADIO CODE, PLEASE READ THIS THREAD.
- New to 702 need a good shop any 411???
- PLEASE HELP!!!
- Need advice on upcoming TL purchase.
- 2002 tl type s throttlebody size
- 2001 Acura CL 3.2 S-type - CEL, SRS, & VSA lights on
- Using a Mix of E85 in my 2003 TL
- BAGGED l "LECHE" l NYC's Finest TL
- 05 TL shakes when shifting
- 2003 3.2TL sub info??
- wtb 02-03 tl oem front lip
- My seat on my TL
- PGM-FI (Main Relay)
- Acura TL battery problem - changed bluetooth already
- Acura TL service manual anyone?
- Acura 2000 TL Radio code NEEDED!!
- just curious of the Vigor
- 2002 3.2 tl type s cruise control not working
- So I am looking to lower a 99-04 RL
- Acura legend: Whats a good Vacuum hose configuration source
- Road and Track Test (Four Sports Sedans)
- replacing a blown 97 2.5 tl engine(5 cyl) with jdm repl.
- HELP P1259 V-tec malfunction
