any known problem with the KB1 (2005) RL?
my friend is in the market for one, and found a 2005 for $12k here in Socal that has 120k miles. Anything he should be looking out for ? Does the SH-AWD tranny hold up well?
Re: any known problem with the KB1 (2005) RL?
Check A/C Compressor make sure it has been serviced or replaced
Brake Master Cylinder Seal ( Recall)
Armrest wear on doors and center console
Propeller Shaft Wine (usually happens when it is cold outside)
Rattle from the rear suspension (fix it by tightening the Ebrake pedal cable 10mm deep well)
Test door handles to make sure the touch sensors are working
