JDM ITR brakes vs. US ITR brakes
Old Mar 3, 2005 | 05:29 AM
DC2IntegraTypeR's Avatar
Default JDM ITR brakes vs. US ITR brakes
I've been hearing some strange rumors and I did a search already but I feel this is the best place for the RIGHT answer.
Are the JDM 98 spec ITR calipers and rotors the same as the US 98 ITRs?
Old Mar 3, 2005 | 06:11 AM
Rene M's Avatar
Default Re: JDM ITR brakes vs. US ITR brakes (RisforTypeR)
From what i have read No they are not the same the 98 spec jdm ITR rotors are larger hence the need for a 16" rim.
Old Mar 3, 2005 | 06:13 AM
Bbasso's Avatar
Default Re: JDM ITR brakes vs. US ITR brakes (Rene M)
Wrong.
false.
BS.
they are the same thing except for different size axles.
Old Mar 3, 2005 | 06:20 AM
<------- Even more confused now. Who is right?
Old Mar 3, 2005 | 06:26 AM
Bbasso's Avatar
If you want to, I'm not.
Go and search thru these:
Brakes - General/TroubleShooting
https://honda-tech.com/zerothread?id=552078
https://honda-tech.com/zerothread?id=678598
https://honda-tech.com/zerothread?id=542868
https://honda-tech.com/zerothread?id=522778
https://honda-tech.com/zerothread?id=489054
https://honda-tech.com/zerothread?id=489046
Brakes - Installation/Removal
https://honda-tech.com/zerothread?id=726774
https://honda-tech.com/zerothread?id=523818
https://honda-tech.com/zerothread?id=157444
https://honda-tech.com/zerothread?id=157429
Brakes - Aftermarket
https://honda-tech.com/zerothread?id=725969 - Brembo
https://honda-tech.com/zerothread?id=763573 - DC5 Brembo
https://honda-tech.com/zerothread?id=665984 - TL Brembo
https://honda-tech.com/zerothread?id=578725 - ATS
https://honda-tech.com/zerothread?id=743266 - NSX
https://honda-tech.com/zerothread?id=720430 - NSX
https://honda-tech.com/zerothread?id=610835 - NSX
https://honda-tech.com/zerothread?id=482434 - NSX
https://honda-tech.com/zerothread?id=291367 - NSX
https://honda-tech.com/zerothread?id=239844 - NSX
https://honda-tech.com/zerothread?id=349039 - NSX/Legend
https://honda-tech.com/zerothread?id=409290 - Legend
https://honda-tech.com/zerothread?id=716441 - Spoon
Brakes - 96Spec ITR
https://honda-tech.com/zerothread?id=753762
https://honda-tech.com/zerothread?id=696362
https://honda-tech.com/zerothread?id=514109
https://honda-tech.com/zerothread?id=507924
Brakes - Interchangable Brake Pads - From Other Hondas
https://honda-tech.com/zerothread?id=720450
https://honda-tech.com/zerothread?id=456229
Brakes - Bench Racing
https://honda-tech.com/zerothread?id=718169
Brakes - Brake Rotors
https://honda-tech.com/zerothread?id=779391 - Slotted vs Drilled vs Blank
https://honda-tech.com/zerothread?id=181691 - Autozone Brake Rotors
Brakes - Brake Fluid - General and Technical
https://honda-tech.com/zerothread?id=356467
https://honda-tech.com/zerothread?id=738858
https://honda-tech.com/zerothread?id=476984
https://honda-tech.com/zerothread?id=215060
https://honda-tech.com/zerothread?id=173650
https://honda-tech.com/zerothread?id=150665
https://honda-tech.com/zerothread?id=91602
https://honda-tech.com/zerothread?id=90092
https://honda-tech.com/zerothread?id=52231
https://honda-tech.com/zerothread?id=56941
https://honda-tech.com/zerothread?id=52655
Brakes - Brake Fluid - Replacement
https://honda-tech.com/zerothread?id=96449
https://honda-tech.com/zerothread?id=389232
https://honda-tech.com/zerothread?id=408343
https://honda-tech.com/zerothread?id=261228
https://honda-tech.com/zerothread?id=162954
https://honda-tech.com/zerothread?id=168907
https://honda-tech.com/zerothread?id=87384
https://honda-tech.com/zerothread?id=76001
Old Mar 3, 2005 | 06:43 AM
Default Re: JDM ITR brakes vs. US ITR brakes (Bbasso)
NONE of those links help. I've went through all of them before I posted and searched under like 6 different inquiries. Nothing turned up
Old Mar 3, 2005 | 06:48 AM
R you serious's Avatar
they are the exact same..
where exactly did you read that they are bigger?
Old Mar 3, 2005 | 06:49 AM
thk's Avatar
thk
Members Only
Calipers are the same. IIRC, the rotors are the same too.
Hub/knuckle assembly is different.
Old Mar 3, 2005 | 06:50 AM
Jdm 98spec R's Avatar
I am 100%m sure that 98 spec Jdm braking system is exactly typical as euro Itr's and Usdm Itr's! The only difference is in the front knucle cause of the shaft that is thicker.
And to confirm,15" rims fit on 98 spec Jdm Itr...
Old Mar 3, 2005 | 06:53 AM
Thank you! I just wanted the rumors to be quelled so I can finally get some sleep.
Old Mar 3, 2005 | 07:19 AM
Bbasso's Avatar
And you doubted me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Wrong.
false.
BS.
they are the same thing except for different size axles.</TD></TR></TABLE>
Old Mar 3, 2005 | 07:33 AM
I just need sone re-assurance, thanks
Old Mar 3, 2005 | 09:46 AM
MUGEN2PT2's Avatar
Werd.... I can use my 15" Azenis's then
Old Mar 3, 2005 | 03:11 PM
Rene M's Avatar
Default Re: JDM ITR brakes vs. US ITR brakes (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">they are the exact same..
where exactly did you read that they are bigger?</TD></TR></TABLE>
Some obscure web site about the difference between the JDM 98 specs and the usdm.
" according to this site the JDM 98 speck got larger rotors both front and rear "
Then a few weeks later a buddy gave me some Type R vhs tape" Best motoring? " and the tape said the same thing.
I do not have time now but i will try to find the site, you will need a translator program for it though.
Old Mar 3, 2005 | 03:22 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">
I do not have time now but i will try to find the site, you will need a translator program for it though.</TD></TR></TABLE>
No, I remember that vid. But from what I remember it compared the JDM 96 spec R to the JDM 97 spec R and there was a difference since the first R had the same brakes as the GSR, other Intrgras, etc. But nothing between the JDM and USDM brakes.
But iirc the 97 R's brakes were upgraded to the larger off the shelf OEM Accord Wagon brakes, caliper, rotor, etc. So truthfully the 97-01 R's worldwide do have larger brakes, but not just JDM as opposed to anyone else.
ibme_uk
Nov 2, 2004 03:50 PM
JDM97R
Jul 16, 2004 03:45 PM
kenji
Nov 19, 2002 02:34 AM
chronic
14
Sep 17, 2002 07:59 AM
Cosworth
Apr 21, 2002 04:14 PM
