Help Needed!! Rough running
Old Jul 6, 2023 | 12:04 PM
Add81's Avatar
Default Help Needed!! Rough running
Hi all,
I have a 98 ukdm Type R, Ive noticed that the car has a hesitation throughout the rev range and any gear. You can accelerate through and pulls fine in Vtec but doesn't flow as it should.
It happens at normal speeds and is not specific to any speed/gear or revs.
The feeling is of the car pulling back and then returning to whatever speed or revs it was at. You can keep a consistent throttle position and it will lose speed and the revs will fall,
I have changed the TPS and their new one is set to the correct amps,0.45. Also changed out the plugs and distributor. Doesn't seem to have a vacuum leak, no engine light, disconnecting the MAF does bring on the engine light and runs very rough until plugged back in so seems to be working. Throttle body seems clean. New thermostat, fuel filter and Rad going on next week.
Oxygen sensor was replaced before I collected the car but could be faulty. Valve clearances have recently been done.
Just wondered if anybody had encountered a similar problem and any advice on next steps and what to be looking at.
Cheers, Adam.
Old Jul 9, 2023 | 07:20 AM
BradC's Avatar
Default Re: Help Needed!! Rough running
Originally Posted by Add81
Hi all,
Cheers, Adam.
Are you logging fuel pressure? How old is that pump?
Old Jul 9, 2023 | 07:26 AM
roddrick's Avatar
Premium Member
5 Year Member
Once you replace the fuel filter, check the injector screens/filters. I had a similar issue with my 97 type r and it was the injector screen getting cloaked with debris from a old fuel tank.
Old Jul 10, 2023 | 10:50 AM
Add81's Avatar
I believe the pump is original, a Walbro replacement is not much ££ so definitely worth changing.
Thanks for the reply.
Old Jul 10, 2023 | 10:51 AM
Add81's Avatar
Fuel filter is being changed this week so will see if there's any difference, Ill run some injection cleaner through the tank and see if it improves.
protheos
May 22, 2018 09:00 PM
eltoro16
Honda CR-V & Element
Jan 12, 2015 02:40 AM
matwilliams
Mar 19, 2011 05:26 PM
woodenchef
Apr 29, 2010 11:45 AM
