Overheating help
Old Apr 25, 2020 | 11:51 AM
Pd9264's Avatar
Default Overheating help
Hi I have a b18c4 boosted sleeved engine.
im having problem with it overheating.
I have a 3 core half rad with shroud and fab.
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
the gauge in the car doesn’t go past half way. Yet when I plug my smanager in the temp from cold will just continue to rise. The fan kicks and the temp will stay at 208. When driving it goes as high as 227. Then the s300 just puts the car into limp mode. I don’t know what to try next.
when I take the rad cap of there doesn’t seem to much happening with the coolant. It’s pretty steady. Should I be seeing some sort of flow. Could it be the water pump. If so how would I test This. tia
Old May 20, 2020 | 06:24 AM
98r860's Avatar
Default Re: Overheating help
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
You might have a thermostat issue.
tech410
15
Sep 22, 2010 05:22 AM
$amGD3
Jul 26, 2010 09:24 AM
naptownrex
27
Nov 20, 2006 04:43 PM
blackpearlv6
Apr 29, 2006 07:10 AM
PHILLIPDEEZ
Jun 2, 2005 12:35 PM
