Honda S2000 Honda S2000
Mugen Plexiglass replacement.
Old Dec 10, 2010 | 10:06 AM
rikhemi's Avatar
Default Mugen Plexiglass replacement.
Just purchased a lexan glass to replace my cracked mugen glass. Is cutting lexan hard to do? I was going to get some measurments and make the cuts on the tinted piece i purchased. Also, would any universal windshield molding work for this or should I get something in particular. I know for the silicon/glue to use 3m window weld. (Think thats what its called)..
Thanks.
Old Dec 10, 2010 | 11:34 AM
camoy's Avatar
Default Re: Mugen Plexiglass replacement.
not sure about your molding question but as for cutting plexi you need to be careful as it like to chip at the edges where you cut and if you aren't careful crack. If you have it I would use a cut off wheel, less likely to cause the chipping on the cut edges. Just don't go too fast or you will melt more than you ment to cut.
85ZC
Feb 3, 2009 09:46 AM
mracejones
Honda Fit
Oct 6, 2008 09:15 PM
TarawaS2000
Honda S2000
Jun 17, 2007 02:14 AM
al4t1gbundy
Honda S2000
16
Jun 13, 2007 07:58 PM
