Honda S2000 Honda S2000
Need help low compression
Old Aug 27, 2010 | 09:49 PM
chasmataz's Avatar
Default Need help low compression
My compression is 90 on all 4 cylinders I just had my head gasket changed head checked and shaved replaced the 3mm head gasket with a new one due to not getting all the air out after installing a new radiator . Need help any advise might be helpful. Car runs and idles good but low compression is bothering me
Old Aug 29, 2010 | 10:07 PM
chasmataz's Avatar
Default Re: Need help low compression
Anyone
Old Aug 30, 2010 | 10:59 AM
lke2drvgsr's Avatar
Leakdown test?
Old Aug 30, 2010 | 11:49 AM
White Smoke's Avatar
i my honda
Global Mod
90 on all 4 is pretty bad, but consistent. Are you sure something else isn't the problem. Have you tried another gauge yet? The fact that they are all similar #'s, but close in range leads me to think it could be a bad gauge.
Old Aug 31, 2010 | 09:27 PM
chasmataz's Avatar
Yes used different gauge and same results. The head was inspected and checked .came back good . We checked the timing aging and it dead on
Old Sep 1, 2010 | 06:10 AM
lke2drvgsr's Avatar
Do a leakdown test, it'll show you where the leak is.
Old Sep 1, 2010 | 06:18 AM
chasmataz's Avatar
Leak down test will be next. Dies anyone know with a 3mm headgasket what the compression should be?
Old Oct 1, 2010 | 09:59 PM
chasmataz's Avatar
Bump
Old Oct 2, 2010 | 08:03 PM
lke2drvgsr's Avatar
Results on the test?
Old Nov 10, 2010 | 07:02 PM
chasmataz's Avatar
i still have 90 comp on all 4
Old Nov 11, 2010 | 10:20 AM
ryan_1014's Avatar
do a wet compression test
Old Nov 11, 2010 | 11:14 AM
spectacle's Avatar
Put in the stock headgasket.
Old Nov 12, 2010 | 09:27 PM
DavidT's Avatar
are you doing the compression test procedure correctly? take out all the spark plugs, take out the fuel pump fuse, hold the gas pedal all the way down and crank the motor over anywhere from 6-8 rotations.
ej6kid
Dec 12, 2010 07:22 AM
Boostn B20
11
Nov 27, 2008 01:22 PM
Keeper1343
Dec 17, 2007 09:10 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
CRXtacy2006
Sep 21, 2006 09:08 PM
