04' Civic SI rear caliper drags after break job
Just replaced the pads and rotors on a 2004 civic si and for some reason after the job the driver side rear caliper is draging so bad its smoking. replaced the rotors with a set of no name drilled and slotted rotors that came with a set of ommni 5 pads please let me know of any reasons this is happening ASAP thanks
Re: 04' Civic SI rear caliper drags after break job
but...... you might just wanna take it all apart and re-do it all and make sure everything is straight and true and also make sure that you are using all the correct parts with the correct part numbers and all that.
Sounds like your rear caliper might be seized, it's a common problem with EP3's. I had a similar problem and only replacing the caliper fixed it.
If it is dragging, the slide may be seized or it may be the piston itself not returning like its supposed to.
Getting a new caliper is probably the only sure way to fix it.
Disassemble it all, make sure you got it all right. If it still drags, replace the caliper.
SHG_Claudio
20
05-12-2010 07:41 AM
chameleon
03-03-2005 08:57 PM
kevinoneill
22
02-21-2004 08:24 AM
