- CD player not working after fob replaced at dealership
- Source of rust on the door but what is the source ?
- 2009 civic EX
- Can’t diagnose sound. Anyone know?
- Something isnt right...
- 2012 Civic Hybrid
- 07 Si no start issue, slow crank no start.
- Desperately need help with cooling fan
- Automatic to Manual Transmision Convertion
- ignition switch inquiry
- Oil overfill
- Help with ECU Info for K24Z Build
- How do I figure out why my car is running rich?
- ECT Sensor 2 Wiring Location- 2015 1.8L
- JDM transmission in my 2007 FA1
- slow response when accelerating
- Ignition wire diagram color coded
- 9th Generation LX / EX 4DR Manual Question
- 8th gen civic ect sensor 2 wire location
- 2006 vs 2008 Civic
- No Crank No Start
- Honda Civic IX 1.6i dtec Headlights replacement
- 2010 Honda Civic Ignition lock
- Bluetooth audio not working
- 2014 Honda Civic Engine Wire Question
- Complete loss of power in Civic 2014
- Auto transmission oil leak on Honda Frv
- HONDA CIVIC 2009 LX SEDAN
- My Honda app and installing APK from USB
- 2013 Civic EX Shifter Cable
- Honda civic supposed leak from gasket
- Engine/trans issues?
- Tourer 1.6 i-DTEC Engine problems
- 2008 Honda Civic - No starting
- 2006 civic hybrid ECU question
- Honda civic 2006 Green light flashing on Dashboard
- 06 Honda Civic: Auto-Dimming Rear View Mirror, W/Compass
- Help / Advice — Repeating Ticking/Clicking Noise whn turning
- Civic FN Airbag System
- 2007 Honda Civic Coolant Reservoir Keeps Filling Up
- 2011 Si Troubleshooting engine failure?
- honda hybrid brakes
- 2007 civic radio , No F.M.
- Clutch pedal don’t work
- Retrofit Crui Control Honda Civic 2012 GEN 9
- Low Engine Temp With Hot Air Blowing 2008 Civic FD1
- 8th gen base model power steering delete
- Overheating and no heat
- Dent in 07 Civic Trunk
- Honda Civic 1.8 (R18) Blow by from crankcase
- Check tranny fluid 2015 civic
- slight knocking sound
- Engine will not start
- 08 Crv Battery Crossed up Still Stuck Please help ..... Thanks So Very Much In Advanc
- Fuses to remove to do a compression test
- Identifying Sensor for Honda Civic DPF Issue
- 2012 Civic Sedan LX - is odometer reading stored in the dash cluster in an EPROM?
- Fuel Leak / Stalling after replacing fuel pump
- EGR issues
- EGR issues
- Lost my key to 08 Civic LX (Manual), Fob battery is dead
- 2004 Civic LX cranks no start.
- K swap
- Blinking Engine Icon On Position 2
- Heater Hum noise only when on High
- 2013 Honda Civic Brake Lights Always on
- Considering a 2012 Civic HF
- 2009 Civic making strange noise
- J35 Throttle Body to OEM air tube assembly
- 2012 Honda civic take 2-3 times to start
- Need Help with 2013 Honda civic lx 5 speed
- Westar Rock Auto Mounts
- Car radio stuck on H boot loop (honda civic type r fk2)
- 2012 Civic Sunroof issue
- Strange scratching sound during cranking.
- FR axel won’t pop out from automatic Trans
- Where on the sunroof track is the "closed" position (9th gen)
- 2012 Civic SI / Intermittent A/C issues…
- Limp mode CEL p1780 p1747 p0722. Need help
- 2009 Honda Civic Coil Pack issues
- Engine light and vsa light
- 2007 Honda Civic Hybrid BRAKE SYSTEM light on
- What attaches to this bracket?
- Short rattling sound at a cold engine
- Gas question
- 2007 Civic fuel issue
- Tires Squealing On Light Acceleration From Stop
- 2008 Civic LX coolant leak from engine block
- Acura CSX compatibility
- 2014 Honda Civic hybrid oil sensor wires
- P0128 and Thermostat
- Replacing Mirror on 2006 Civic EX
- Honda Civic 2008 Dx Coupe
- 2013 Honda Civic Power Window Issue
- Is it dangerous to tie a box on top of the brake pedal?
- Help! Replaced Ignition Lock Cylinder, but Key Still Won't Turn
- Oil light flickers, oil pressure is good
- Code P0977
- Driver's Caliper piston dust boot seal, bleed screw cap, and cv axle boot are torn
- 2007 honda civic 1.8 EX operating temperature
- cargo measurements, 9th gen hatchback
- 2007 Honda civic si vs 2007 Honda civic dx ,ex suspension parts
- Hybrid Air Conditioning not working
- Help! Very low compression after clutch replacement
- Can't reinstall new serpentine belt - Civic 2009 R18
- 2013 Civic Oil Seepage Valve Cover Gasket PS
- Engine Swap
- Honda Civic starting issues
- Diagnose IMA problem
- OEM AC CONDENSOR VS AFTERMARKET
- 2010 Civic drivetrain noise getting louder
- Please help ! 2009 i-CDTI 2.2 Intermittent fail starting
- Car CEL with Evap Code P0453
- 2006 Civic Hybrid Immobilizer Issues.
- Civic 06 SI Lock Trunk (Handle+Power+Switch) - Honda (74851-SNR-C02) replacement
- my 2015 Honda Civic key FOB wont work after changing the battery. How to reprogram?
- 2010 Civic Transmission Leak/Spew
- My Car runs very rough for 15-20mins and runs just fine - what could be issue
- 2006 Civic SI Airbag light
- k20 rocker arm shaft diameter
- A/C Relay
- Help with steel tire and OEM lug nuts please, worried about incompatibility.
- Parts on hand
- Valve Cover Bolt Thread, R18
- JIC MAGIC AXLE BACK EXHAUST FITMENT?
- 05 civic lx special edition - Missing male o2 downstream sensor
- 2012-2015 does the EX model have vtec or all the same
- caliper not fulling releasing
- recommendations?? swap LDA-MF5 2007 Civic Hybrid (FD3)
- 2014 Civic running too cold after thermostat replacement
- EPS module interchange?
- Codes 300, 301,302,303,304, 128
- 2006 Civic Hard Shift Auto Trans
- 2007 Honda Civic EX starter
- DIY Transmission Flush Via Multiple Changes?
- SRS module fault (airbag light on)
- Please help me assess these problems under the hood of this '08
- Side break lights not working 2006 Civic hybrid
- 2006 Civic Si lower radiator support cover
- Which 1 of these is most likely the issue? 2008 [2.2 Diesal]
- Weird Misfire on partial throttle
- 2012 honda civic ex wont start
- All lights came on the hiway, then limp mode
- 2007 civic auto tranny
- Displaying Air Fuel Ratio on Tach
- Honda 2013 Civic EXL, Rear passenger noise
- 2015 CIVIC ENG REBUILT TO OEM SPECS
- 07 civic transmission won't shift when cold
- Po 172
- VTC 50° IN K24A TSX
- 2014 Civic LX Timing Belt Kit
- Factory Service manuals...
- Rough idle on 2009 Honda Civic hybrid
- Ringing Noise Drivers Side
- Windshield Replacement: OEM vs After Market
- Lower torque rod bracket oil leak
- Transmission chirp/bird noise
- Clean Throttle Body - N16A1 1.6 Diesel in Civic 9th Gen
- Valve cover gasket replaced 2x still leaking
- Is this pipe attached to the muffler?
- 2014 honda civic si left turn signal not working
- HAVING AN ISSUE WITH 2006 Civic Hybrid
- Help ... leak at the power steering pump connection
- R18Z1 swap options 2012 ex coupe
- Timing marks camshaft sprocket
- K20z4 o2 sensors
- Repair my '08 Civic Hybrid or buy a new car
- 2012 R18 K24 swap can it be done?
- 07 5 Speed Transmission
- 07 civic, help identifying part
- Clean up
- Triple tip exhaust
- 27-17 Steering angle sensor diag signal error (initial)
- 2009 Honda Civic Fluid Exchange & Coolant service cost
- Car Intermittently Won't Start
- N16A1 1.6 Diesel in Civic 2013 - Crankshaft Sensor Location PLEASE??
- 2010 Civic Si w/ TL Type S calipers
- Electronic power steering issue
- Honda civic heat and ac not workingb
- 2006 Civic EX very rough and stalling low RPM/idle
- Brake lights not working
- Horn randomly goes off on 2012 Civic EX
- 2007 civic radio code
- Civic Door Lock Cover Part
- Are there any decent body kits for a 09 4dr civic.
- Hybrid cooling fan issues
- '08 1.8L Coolant Leak near water pump
- Side Airbag possible reset Without replacement? 2015 Honda civic couple LX
- Bumper OEM PP or fiberglass
- 2012 Civic ex coupe downstream O2 sensor hardwire
- 2010 Honda Civic VP- Radio code
- Brake fluid leak
- Wires to fuse box keeps alternator from charging
- Engine Oil decreasing!!!!
- Dangerous Car Stall 2013 Honda civic 4 cyl.
- need quick answer Please
- 2007 Civic 5 Speed Transmission Issues
- Key fob remote works odly
- 2007 Civic Cooling Fans Not Running
- VTEC Oil Pressure switch (code P2647)
- Civic LX 07 ac compressor engages and disengages by itself
- K20Z3 Transmission
- Muffler rusted off can it be welded back together?
- oil drain plug
- 07 drivers' seat loose , .
- 2011 Civic electrical problems and buzzing sound
- Got a free 2008 Civic, Cranks but no start
- help! IMA meter sudden drop & related IMA problems
- Different spring rate on one side of the car, how should I adjust damping?
- code 53-11
- '07 DX-G Coupe (Canadian) in Nighthawk Black Pearl - clear coat gone
- ENGINE COOLANT TEMPERATURE SENSOR/COOLING FAN
- 2010 Shift Interlock Solenoid Replacement help
- 07 Civic Only starts with Jumper Pack
- 2014 civic humming over 40 mph ?
- 07 civic & 09 accord rims
- Engine Swap
- Anyone know how to fix this leak, and if it is easy?
- 2010 Honda Civic lx tuner
- Possible use?
- K24z7 gearset question
- Lower Mileage vs higher spec? Which to choose?
- 2007 civic speakers
- Radio on, display working, but no sound
- Dashboard warning lights
- Install screen on Honda Civic
- Slow Crank even with jumpstart and new starter
- 2008 honda civic
- 2007 civic front speakers ,
- type S oil pump on k20z3
- Clutch pedal bracket
- Low beams not working but Highbeams do
- 2008 Civic - ideal alternator output voltage?
- Trunk Release Handle Lock won't turn
- Start With No Keys - 2012 Civic SI
- Civic 2009 CEL blinks mid ride
- Hybrid - Installing used AC compressor. Oil?
- 2009 Civic - Steering Wheel shakes when accelerating/braking after new brakes/rotor
- Speaker Issues
- High rpm idles (up to almost 3)
- Heater at max only works on defrost.
- Shift knob stuck on?
- 2014 HONDA CIVIC CVT FAILURE. Need advice
- Size spacers needed for willwoods
- AC Help with 07 Civic 4 door
- 06 Honda Civic Ex - Crank, no start
- 2008 Civic Battery Drain Mystery
- Easy Fix, right?
- 2014 civic will not move in drive?
