Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Fuses to remove to do a compression test
Old Dec 20, 2023 | 09:43 AM
Madmadra's Avatar
Default Fuses to remove to do a compression test
Hi, I want to do a compression test on a 2007 hybrid engine. I'm wondering what fuses to remove to disable fuel and spark and just wondering if there's anything extra or different that I need to do from a standard compression test since I'm dealing with 8 plugs as opposed to 4? Thanks in advance
Old Dec 20, 2023 | 10:32 AM
Ryanthegreat1's Avatar
Default Re: Fuses to remove to do a compression test
Should be able to hold the throttle pedal to the floor tonget flood clear mode. No fuel will be injected.
You have to hold the throttle open anyway for a compression check.
Old Dec 20, 2023 | 11:59 AM
Madmadra's Avatar
Thanks for getting back. I'm unfamiliar with that, so pedal to the metal before starting? Are there fuses which control fuel injection and spark to the cylinders on this model? I've looked and can't see anything in either panel. Would pulling the main fuse to the ecu do it?
Old Dec 20, 2023 | 12:11 PM
It likely won't crank with the fuse for the PCM pulled.
Vladglad
20
Dec 18, 2013 02:56 PM
txl146
Apr 28, 2005 05:53 AM
tgod1020
12
Oct 9, 2003 04:29 PM
RCautoworks
Apr 17, 2003 08:03 AM
wm5holla
Mar 23, 2003 03:39 PM
