Brakes. Lots of ?'s
Old Jan 3, 2007 | 01:12 PM
.Thomas's Avatar
Default Brakes. Lots of ?'s
ok, if my brakes go out (there starting to squeak) How much should it cost to do it diy style.
I wanted autozone blanks, need a reccomendation for brake pads, and new fluid.
if i am doing the fronts, should i just do the rears as well?
is it worth it to put in new SS break lines as well?
looked in the FAQ and found nothing, thanks
BTW: this is for a 96 ls. all stock.
Old Jan 3, 2007 | 01:18 PM
yjischoking's Avatar
Default Re: Brakes. Lots of ?'s (TanCar)
get some axxis/pbr ultimates off ebay. i got mine for 68 shipped at all 4 corners. rotors and fluid is autozone stuff. typically the rears wear a lot slower than the fronts so just inspect the rears first before buying any pads. as for the lines, some people say that they burst but unless you're tracking the car I would skip the lines. Plus, it looks like you're trying to save money so good lines aren't exactly cheap.
Old Jan 3, 2007 | 01:22 PM
.Thomas's Avatar
Default Re: Brakes. Lots of ?'s (yjischoking)
ok.
any word for a FAQ. like could a project like this get tackled in a day buy two people?
Old Jan 3, 2007 | 01:31 PM
redGSRguy's Avatar
Here is a article on brake pads and rotors.
http://www.team-integra.net/se...D=373
and one for brake bleeding
http://www.team-integra.net/se...D=417
Shouldn't take more than a few hours. You will need either a special brake tool or a big *** flat head to get the rear piston in.
Old Jan 3, 2007 | 02:08 PM
jdm_bones's Avatar
Default Re: Brakes. Lots of ?'s (redGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Here is a article on brake pads and rotors.
Shouldn't take more than a few hours. You will need either a special brake tool or a big *** flat head to get the rear piston in.</TD></TR></TABLE>
Couldn't have said it better myself^ you should be able to knock it out in around an hour with an extra set of hands, and air tools..
Old Jan 3, 2007 | 02:17 PM
.Thomas's Avatar
Default Re: Brakes. Lots of ?'s (jdm_bones)
ok. now the brake tool, is that something i can borrow or do i need to buy?
Old Jan 3, 2007 | 02:19 PM
redGSRguy's Avatar
It is like 5 dollars at sears, works pretty crappy in my opinion. I'd just get a HUGE flat head and turn the piston back in.
Old Jan 3, 2007 | 02:26 PM
Sumslapper's Avatar
Year 3030
buy brake cleaner and clean down all the new parts and the old clips on the caliper u have to reuse.
I HIGHLY recommed buying a impact driver to get off the rotors. im 99% sure u will strip them or have a major hard time getting the screws off the rotors without one. there only like 12$ too and well worth it
Old Jan 3, 2007 | 02:33 PM
Default Re: Brakes. Lots of ?'s (sumslapper)
for the rear pistons you can get a really big like 8'' long clamp and tighten it that way.
Old Jan 3, 2007 | 02:54 PM
.Thomas's Avatar
impact driver? whats that .....
like an impact wrench?
Old Jan 3, 2007 | 03:33 PM
PrinceAli132's Avatar
<U>Impact driver </U>- Costs about 20 bucks from Home Depot or Sears. It will make your life a lot easier and will remove the rotor screws without a problem. Just make sure to use the right size phillips head. Place the driver into the screw head and then take a hammer and whack the crap out of the driver. The force of the impact will generate enough torque to loosen the rotor screws.
<U>Pads</U>
I recommend getting Cobalt Friction GT Sports. I believe their new pad compound was just released and it is suppose to be even better. I have the older compound and they are great.
Just remember that if you choose to uprgade to a pad that has better bite, expect some consequences, like:
More brake dust
Possibly a decrease in cold bite
More sqeauling
<U>SS brake lines </U>
IMO i would not get SS brake lines for a DD car, unless you plan on inspecting them every now and then.
Here is a good link regarding SS brake lines; http://www.nsxprime.com/FAQ/Pe...s.htm
Now I'm not saying not to get them, because there are a lot of people using them daily without problems. But personally, I wouldn't risk it. A good set of pads and fluid will do the trick.
<U>Brake Fluid</U>
Im currently using ATE Super Blue 200 and recommend it. You should have no issues with it and I doubt you will boil the brakes with street and some track driving.
<U>Brake fluid specs;</U>
https://honda-tech.com/zerothread?id=1788969
<U>Brake Rotors</U>
It seems like your on the right track with those.
You should check the ITR FAQ out. Even though some of the info may not be directly related. You can still get a good idea of good pads, rotors, fluid, etc.
Originally Posted by ITR FAQ
Brakes - General/TroubleShooting
https://honda-tech.com/zerothread?id=552078
https://honda-tech.com/zerothread?id=678598
https://honda-tech.com/zerothread?id=542868
https://honda-tech.com/zerothread?id=522778
https://honda-tech.com/zerothread?id=489054
https://honda-tech.com/zerothread?id=489046
Brakes - Installation/Removal
https://honda-tech.com/zerothread?id=726774
https://honda-tech.com/zerothread?id=523818
https://honda-tech.com/zerothread?id=157444
https://honda-tech.com/zerothread?id=157429
Brakes - Aftermarket
https://honda-tech.com/zerothread?id=725969 - Brembo
https://honda-tech.com/zerothread?id=763573 - DC5 Brembo
https://honda-tech.com/zerothread?id=665984 - TL Brembo
https://honda-tech.com/zerothread?id=578725 - ATS
https://honda-tech.com/zerothread?id=743266 - NSX
https://honda-tech.com/zerothread?id=720430 - NSX
https://honda-tech.com/zerothread?id=610835 - NSX
https://honda-tech.com/zerothread?id=482434 - NSX
https://honda-tech.com/zerothread?id=291367 - NSX
https://honda-tech.com/zerothread?id=239844 - NSX
https://honda-tech.com/zerothread?id=349039 - NSX/Legend
https://honda-tech.com/zerothread?id=409290 - Legend
https://honda-tech.com/zerothread?id=716441 - Spoon
Brakes - 96Spec ITR
https://honda-tech.com/zerothread?id=753762
https://honda-tech.com/zerothread?id=696362
https://honda-tech.com/zerothread?id=514109
https://honda-tech.com/zerothread?id=507924
Brakes - Interchangable Brake Pads - From Other Hondas
https://honda-tech.com/zerothread?id=720450
https://honda-tech.com/zerothread?id=456229
Brakes - Bench Racing
https://honda-tech.com/zerothread?id=718169
Brakes - Brake Rotors
https://honda-tech.com/zerothread?id=779391 - Slotted vs Drilled vs Blank
https://honda-tech.com/zerothread?id=181691 - Autozone Brake Rotors
Brakes - Brake Fluid - General and Technical
https://honda-tech.com/zerothread?id=356467
https://honda-tech.com/zerothread?id=738858
https://honda-tech.com/zerothread?id=476984
https://honda-tech.com/zerothread?id=215060
https://honda-tech.com/zerothread?id=173650
https://honda-tech.com/zerothread?id=150665
https://honda-tech.com/zerothread?id=91602
https://honda-tech.com/zerothread?id=90092
https://honda-tech.com/zerothread?id=52231
https://honda-tech.com/zerothread?id=56941
https://honda-tech.com/zerothread?id=52655
Brakes - Brake Fluid - Replacement
https://honda-tech.com/zerothread?id=96449
https://honda-tech.com/zerothread?id=389232
https://honda-tech.com/zerothread?id=408343
https://honda-tech.com/zerothread?id=261228
https://honda-tech.com/zerothread?id=162954
https://honda-tech.com/zerothread?id=168907
https://honda-tech.com/zerothread?id=87384
https://honda-tech.com/zerothread?id=76001
Ali
Old Jan 3, 2007 | 04:13 PM
Sam92Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yjischoking &raquo;</TD></TR><TR><TD CLASS="quote">for the rear pistons you can get a really big like 8'' long clamp and tighten it that way.</TD></TR></TABLE>
The rear brake pistons are screwed in, do not use a clamp on the rear pistons. The C-clamp is used on the front brakes only to push the piston cup in (use an old pad between the cup and the clamp).
I always use an open ended wrench placed in the 'X' groves on the rear pistons with a screw driver placed in the closed end of the wrench to twist the rear brake pistons back in, works like a charm. I have the borg looking tool, and my wrench method works better because our calipers are so small, the box tool wouldn't fit in the caliper.
You don't need to bleed brakes unless you open the system, although it is advised if the brake fluid is old. Just changing pads and rotors doesn't require bleeding.
Brembo blank rotors are good rotors, but you don't need them unless yours are worn past minimum thickness (stamped on the rotor), or are in poor condition which can't be machined without reaching minimum thickness specs.
Old Jan 3, 2007 | 09:12 PM
Default Re: Brakes. Lots of ?'s (Sam92Teg)
the clamp is used to apply pressure on the rear piston. then as you turn the clamp, it will screw the piston in. It is not used to push the piston in but rather to use the friction between the two surfaces as a screwdriver.
Old Jan 4, 2007 | 09:41 AM
.Thomas's Avatar
best place to buy ATE super Blue? its at amazon for 11 bucks for a liter ...
http://www.amazon.com/Super-Bl...L0YMO
so, do you just need sockets, jack, large flathead screwdriver, impact driver to do this job tool wise?
Old Jan 4, 2007 | 10:22 AM
and stands and some anti-squeal compound. as for the large flathead I have never seen one that big...You'll see once you look at the rear calipers. The clamp is a lot easier to use as a "screwdriver"
Old Jan 4, 2007 | 01:07 PM
.Thomas's Avatar
is anti squeal a must?
can you pick that up at like napa?
Old Jan 4, 2007 | 02:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">is anti squeal a must?
can you pick that up at like napa?</TD></TR></TABLE>
Its not required. And you can pick it up at Napa, Autozone, Discount Auto Parts, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">Also, do you just need sockets, jack, large flathead screwdriver, impact driver to do this job tool wise?</TD></TR></TABLE>
Im pretty sure the team-integra links that provide a how-to have a tool list.
As far as the "screwdriver" needed for the rear pistons is use a screwdriver type chisel, which has a wide flat head when compared to a scewdriver.
Ali
Old Jan 5, 2007 | 11:03 AM
.Thomas's Avatar
Default Re: Brakes. Lots of ?'s (PrinceAli132)
i just got some napa rotors, damn there expensive!
are they normally like 45 bucks a rotor?
Old Jan 5, 2007 | 11:16 AM
Its been a while but i believe my autozone fronts were just over $20 each. And the rears were around $12 each.
Ali
Old Jan 5, 2007 | 11:21 AM
.Thomas's Avatar
sounds like i need to comparative shop at autozone .....
will they take them back? (the napa ones) i still have my paperwork and stuff ...
Old Jan 5, 2007 | 11:34 AM
They should.
I've returned rotors at autozone because they kept on giving me the wrong ones.
Ali
Old Jan 7, 2007 | 08:51 AM
.Thomas's Avatar
will i need more then 1 liter of brake fluid?
looking where to buy the brake fluid.
Old Jan 7, 2007 | 09:52 AM
tempname's Avatar
You know you probably don't need new rotors right? The squeaking noise is just the wear indicators on the pads telling you that you need new pads. Just find out where the sqeaking is coming from (front of rears) and change the pads. Take's all over 45 minutes.
Old Jan 7, 2007 | 11:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">will i need more then 1 liter of brake fluid?
looking where to buy the brake fluid.</TD></TR></TABLE>
I'm pretty sure you'll need two bottles to be able to properly flush out the system.
Ali
mooseheads36
Honda Civic (2006 - 2015)
33
Apr 20, 2007 04:54 AM
TomTomTuning
Honda S2000
25
Jun 22, 2006 02:27 PM
blulude92
May 22, 2006 08:07 AM
eou2
Aug 12, 2005 04:01 AM
XyKo
Feb 8, 2005 02:52 PM
