Rust Removal?
Old Oct 26, 2010 | 08:10 AM
jhendry's Avatar
Icon2 Rust Removal?
K i'm taking care of some surface rust in the bay before i re-do the paint and i've seen tens and tens of rust removers, neutralizers and converters. What is the proper use or situations for these? what would be the best one for my application. (battery fuse box area) so no submersing ones.
Old Oct 26, 2010 | 09:24 AM
WigginsSiR's Avatar
Default Re: Rust Removal?
you need to sand/ grind the rust back to clean bare metal...
then you can use filler to make it smooth then prep it for paint.
that is the ONLY correct way.
Old Oct 26, 2010 | 09:55 AM
jhendry's Avatar
Thanks For your answer i've seen your posts on the topic before and i think i still have some questions. i will be working on an eg bay where the battery and fuze box used to be and in the areas where and angle grinder can reach i will be using a drill bit and there will still be crevasses where two pieces of metal meet. would a product such as picklex or rust mort be a safe bet to help out where i cant reach?. i can post a picture later today
Old Oct 26, 2010 | 11:40 AM
WigginsSiR's Avatar
are you talking about the seams and weld divits? something like this might help...
w/ thiss.....
i work at a body shop in parts.... so i can always ask a tech for help
Old Oct 26, 2010 | 12:28 PM
jhendry's Avatar
yes that looks good because i can see some runs coming from a seem or two in the bay and just want to do a decent job of grinding and sanding before i try a chemical on the rust.
Old Oct 30, 2010 | 06:10 AM
ken9's Avatar
It depend on how bad the rust is..
harmonator84
Paint and Body
275
Jan 30, 2018 09:22 AM
97CWITR
Paint and Body
Feb 27, 2008 07:20 AM
immrtaltchnq
Paint and Body
Oct 12, 2007 06:22 PM
Ohgodzirra
Paint and Body
Apr 20, 2007 07:02 AM
JDMFantasy2k
Jan 8, 2007 08:14 PM
