Wheel offset question.... Need Help!!
Old Mar 3, 2006 | 05:08 PM
97EJ6R's Avatar
Default Wheel offset question.... Need Help!!
Hi, i wanted to know if anyone is running a wheels 16x7 5x114.3 +33 on their civic or integra.
want to know if it will work with 5lug ITR conversion.
My concern is the +33 offset
Thanks guys...
Old Mar 3, 2006 | 05:11 PM
BlueIntegraBoy's Avatar
Default Re: Wheel offset question.... Need Help!! (97EJ6R)
It will fit as long as it's 5x114.3 of course, but you will most likely have rubbing when you lower your car.
Old Mar 3, 2006 | 06:18 PM
TPB's Avatar
TPB
Default Re: Wheel offset question.... Need Help!! (BlueIntegraBoy)
A +33 offset is going to stick out way too far, rubbing both front and rear fenders. There is no way you can flare the fenders enough to accomodate that offset. Try a +38 or +43
Old Mar 3, 2006 | 06:25 PM
RagingAngel's Avatar
depends on how bad you want to run the wheels.
You can get away with it by flairing but also running at least over 3degrees over negative camber.
Either way, you won't be able to lower much. You can also get a shop to machine the wheel. Funny enough as it is, I know somebody who had it done to a 17X7 +40mm TE37 as well....machined it so it was a +42mm in the end.
Old Mar 4, 2006 | 03:23 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: Wheel offset question.... Need Help!! (RagingAngel)
It's funny how every once in a while there are posts with little hints in it that tell you who the real "OG" are. That post above is one of those posts.
+33 is a little much, I think, unless you are willing to make compromises or modifications to accommodate the wheels.
Old Mar 4, 2006 | 04:25 AM
Reid's Avatar
Global Moderator
Default Re: Wheel offset question.... Need Help!! (George Knighton)
On a 7" wide wheel with a +33 offset, the rim will be 55.9mm from the centerline of the wheel. I've fitted a 8" wide wheel with a +45mm offset, which has a rim that is 56.9mm from the centerline of the wheel. So I believe you should be fine.
However, in order to do this the fenders must be rolled and the car must be running a decent amount of camber in both the front and rear.
Old Mar 4, 2006 | 05:30 AM
H-T Order of Merit
Default Re: Wheel offset question.... Need Help!! (Reid)
Unless it's the first Sunday after the first full moon after Vernal Equinox, but it has to be after Passover.
But it could be dark.
In Okinawa.
Old Mar 4, 2006 | 11:55 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Unless it's the first Sunday after the first full moon after Vernal Equinox, but it has to be after Passover.
In Okinawa.</TD></TR></TABLE>
Oh no! You're losing it!
Old Mar 5, 2006 | 12:23 AM
jeremy.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">A +33 offset is going to stick out way too far, rubbing both front and rear fenders. There is no way you can flare the fenders enough to accomodate that offset. Try a +38 or +43</TD></TR></TABLE>
I have 32+ offset on my integra and fits just fine
Modified by ekay_jeremy at 1:46 AM 3/5/2006
Old Mar 5, 2006 | 12:43 AM
WhoisDan's Avatar
Default Re: Wheel offset question.... Need Help!! (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">
I have 32+ offset on my integra and fits just fine</TD></TR></TABLE>
40 series tires. I am surprised you dont rub. I rubbed with 42+ offset.
Old Mar 5, 2006 | 01:02 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">On a 7" wide wheel with a +33 offset, the rim will be 55.9mm from the centerline of the wheel. I've fitted a 8" wide wheel with a +45mm offset, which has a rim that is 56.9mm from the centerline of the wheel. So I believe you should be fine.
However, in order to do this the fenders must be rolled and the car must be running a decent amount of camber in both the front and rear.</TD></TR></TABLE>
To add to this, I test fit a 225/45/16 A048 on a 16x8 +45mm wheel in the front and a 205/50/16 A048 on a 16x8 +45mm in the rear.
I'm also using 22k springs in the front and 18k in the rear, so the body does not roll much at all. I'm sure on softer springs, I would be hitting the fenders. The tyre to fender clearance is very small.
Having said all that, I now see George's point. 99% of the time the setup I described will not fit on an Integra.
oskarsEG6
Nov 16, 2011 03:21 AM
meric0786
Jul 10, 2011 11:16 AM
thomasw91
Nov 6, 2009 08:40 AM
matt94z
Aug 7, 2008 05:03 PM
L4NDO
Mar 30, 2003 03:04 PM
