Why does this happen?
Old Apr 8, 2003 | 09:06 AM
Mr Boston's Avatar
Default Why does this happen?
I got my R a couple of weeks ago and it comes with new falken azenis. The problem is when I['m on the gas on 1st or 2nd gear, the car would steer to the right or left. But this doesnt happen unless I'm at WOT. Is it because of the tires?
Old Apr 8, 2003 | 09:11 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Why does this happen? (Integra Type R)
Balance/alignment check out ok?
Old Apr 8, 2003 | 09:13 AM
SonicGSR's Avatar
Default Re: Why does this happen? (Splat)
Torque steer?
Old Apr 8, 2003 | 09:16 AM
Mr Boston's Avatar
Default Re: Why does this happen? (SonicGSR)
Not sure what it is but the car seems to like to follow the grooves on the road.
Old Apr 8, 2003 | 09:17 AM
Ex-ITR5874's Avatar
What is your scrub radius ? Are you on stock rims ?
rated_r's Avatar
torque steer
Old Apr 8, 2003 | 09:23 AM
Mr Boston's Avatar
Default Re: Why does this happen? (rated_r)
Yes I'm on stock rims, If its torque steer does this happen to anyone elses R?
Old Apr 8, 2003 | 10:23 AM
SpoonMyHonda's Avatar
My buddy's LS did that when he first got it... Torque steer i believe
Old Apr 8, 2003 | 10:28 AM
SlapSmak's Avatar
Default Re: Why does this happen? (SpoonMyHonda)
at WOT torque steer, but only to the right. do it all the time when i am autocrossing
Old Apr 8, 2003 | 10:31 AM
(__________)'s Avatar
Default Re: Why does this happen? (SlapSmak)
mine does that when I hit bumps in the road, no PS can sometime get tricky when you are not paying attention while driving.
Why dont you sell those Falken's to me?
Old Apr 8, 2003 | 10:34 AM
Big Phat R's Avatar
Check your alignment and tire pressures.
Old Apr 8, 2003 | 10:35 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Why does this happen? (steves98itr247)
Hold the wheel tighter.
I assume these are 205/50/15 Azenis - on the stock ITR wheels, you will get some slop. Try upgrading to a 7" wheel, Kosei K-1s are a popular choice.
Old Apr 8, 2003 | 10:36 AM
BudMan's Avatar
Default Re: Why does this happen? (Big Phat R)
Welcome to front-wheel-drive + power = torque steer Get used to it.
Old Apr 8, 2003 | 11:15 AM
TypeR 01 886's Avatar
Default Re: Why does this happen? (BudMan)
Yep, I would also say torque steer. I have the same situation. Its not a problem really if you are going straight with the right tire pressure and a properly aligned car.
ITRs will do that alot when at WOT and switching lanes, I hold the wheel with both hands and she performs like a dream, one hand it feels like the car wants to go all over the road.
Old Apr 8, 2003 | 11:20 AM
Tom 190's Avatar
Default Re: Why does this happen? (Ross)
also make sure your tire pressures are correct, that could be a small part of it
Old Apr 8, 2003 | 11:46 AM
Angry Joe's Avatar
There is no such thing as torque steer on an Integra, the shafts are equal length. Check tire pressure, then alignment if the former is okay.
Interestingly, I thought my old Kumhos were a lot more prone to following ruts and grooves than the Azenis
Old Apr 8, 2003 | 11:53 AM
baonest1's Avatar
Default Re: Why does this happen? (Angry Joe)
terk steer... you have too much POWER
Old Apr 8, 2003 | 01:24 PM
nfn15037's Avatar
Yes the axles are equal length, but one side has the intermediate shaft, so it will wind up some more.
Old Apr 8, 2003 | 01:58 PM
00MRSi's Avatar
Default Re: Why does this happen? (nfn15037)
Sounds like torque steer. I wouldn't know, I have a b16a2 and the word "torque" does not exist for me..
Old Apr 8, 2003 | 02:26 PM
B2FiNiTY's Avatar
Happens all the time. No worries.
Old Apr 8, 2003 | 02:50 PM
20lb.teg's Avatar
Default Re: Why does this happen? (B2FiNiTY)
Well, it is torque steer. And the reason why it wants to almost pull out of you hands when not holding it really tight is because of the LSD. Type-R's are equipped with the LSD stock, so when it transferes the power to one wheel from both wheels it will PULL suddenlly and very hard to one side. Try accelerating over railroad tracks Oh yah!!!! Lot's of fun there.... Hope this helps.
Later,
Sean C.
Old Apr 8, 2003 | 02:59 PM
2001TypeR's Avatar
Yup same thing happens when its hooking good, its torque steer
Old Apr 8, 2003 | 04:49 PM
Dr Pooface's Avatar
Default Re: Why does this happen? (2001TypeR)
If it was torque steer, it would only pull to one side.
What is happening to you is normal. You could try getting an alignment to see if it helps, but I doubt it.
Old Apr 9, 2003 | 03:20 AM
Ex-ITR5874's Avatar
Default Re: Why does this happen? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">If it was torque steer, it would only pull to one side. </TD></TR></TABLE>
That`s what I was thinking.... He sais "to the left OR the right"...
Try other tires (wheelset of a friend or so) and see if it`s the same... The way you described the pulling reminds me of the cold season, when I put on winter tires... It gets difficult to stay on the street in 3rd/8k+ at WOT.
Once the cp035 are on, the "steer" is gone.
smd6942
Honda Civic (2006 - 2015)
May 4, 2010 01:48 PM
90teg91hatch
13
Jul 29, 2008 05:09 AM
accord745
Apr 17, 2004 10:13 PM
patdemps
Nov 4, 2003 11:48 AM
hondafrk
Feb 22, 2002 06:52 AM
