Problem
Old Apr 10, 2003 | 07:16 AM
rated_r's Avatar
Default Problem
doing my finally checks on the car before the expo.. See that the rear brake lights work sometimes and sometimes it wont work.. The 3rd brake light in the car is always working, but the other two don't all the time.. I checked the ground its good. I checked the wires nothing is broken, anyone help me out
Old Apr 10, 2003 | 07:19 AM
B( * Y * )BIES's Avatar
Default Re: Problem (rated_r)
:lack of tech skillz, sorry:
try checking the wires on the sockets themselves - see if maybe they are loose.
Old Apr 10, 2003 | 07:27 AM
Batoutahell's Avatar
You probably checked already, but are the bulbs good?
Old Apr 10, 2003 | 07:35 AM
JDM CTR '00's Avatar
Default Re: Problem (Batoutahell)
try the fuse prolly not it tho.
Old Apr 10, 2003 | 08:13 AM
rated_r's Avatar
Default Re: Problem (ChargedSi99)
i checked the bulbs, sockets and fuse... nothing wrong with them
Old Apr 10, 2003 | 08:16 AM
oryanh's Avatar
Helms "official" fix is to completly remove all in-line sockets and reseat them.
"this effectively cleans the connectors".
My wife's Jetta did this... it was a relay that neeed to be replaced.
I'm going to be a jackhole for a sec cause someone else is thinking the same thing:
"If the lights only come on when braking... but go off when releasing the brake then this is normal operation."
-ryan <such a jack-hole.
Old Apr 10, 2003 | 08:39 AM
cut wires? pinched? One more thing check the bulb where the contacts are the 2 little solderd parts make sure thats making contact with the socket. I seen this happen many times.
Old Apr 10, 2003 | 09:29 AM
Teepo's Avatar
make sure 1157 bulbs are in right.....remember they have **** on them and they are offset......put them on the wrong way and then they dont work .......check your alarm connections never know
b18c1vtecdc2
Sep 2, 2013 09:31 PM
WhatASlowEg
Nov 23, 2009 08:49 PM
JAYDmManny1331
Sep 16, 2009 10:43 PM
integracura
Nov 26, 2007 05:25 PM
96prelude1212
Aug 18, 2007 05:04 PM
