? about installing new pistons
ok i am looking at getting the toda pistons.
my ? is. i am pretty sure that i would have to bore and hone the stock sleeves for the new pistons. the stock bore is 81.25? correct? should i get the 81.50 or the 82mm? and what ever the pistons size is that what you bore the block out to?
Re: ? about installing new pistons (sgT)
why ctr if i plan on doing a full toda head package. 12.3:1 sounds just about right for the cams.
also would i be able to use the stock itr rods? caus i read somewhere that not a lot of aftermarket rods work with todas pistons
Re: ? about installing new pistons (Vampyre)
but its your money
Re: ? about installing new pistons (Johnny Tran)
i am doing research. its just that i have read that in a few places and want to confire or denie it.
sometimes this place is touchey
gimme your email and I'll email ,you some info re clearances and tolerances.. I just had to replace my pistons with toda 81.25mm.. I had the dilemma of choosing stock 81.00 or 81.25 but believe me, it will save you money in the long run... BORE AND HONE THE biatch!! Also if you have a type R we calculated the displacement to be around 1.81125 litres ( taking into consideration the original was 1.8 for simplicstic sake)
Jansen
Jansen
Re: ? about installing new pistons (jansenrw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jansenrw »</TD></TR><TR><TD CLASS="quote"> Also if you have a type R we calculated the displacement to be around 1.81125 litres ( taking into consideration the original was 1.8 for simplicstic sake)
Jansen
what's the point in carrying out your calculation to 5 decimal places when you rounded the initial displacement?
Jansen
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Re: ? about installing new pistons (D)
There is sufficient evidence to indicate that the rate of increase in output per unit increase of input decreases as the input increases.
Re: ? about installing new pistons (RealTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR »</TD></TR><TR><TD CLASS="quote">There is sufficient evidence to indicate that the rate of increase in output per unit increase of input decreases as the input increases.
word
word
Spec R_GSR
05-12-2007 07:01 AM
DC5ftmfw
11
05-01-2006 08:05 PM
PickleTeg
04-04-2006 07:59 PM
night
10-02-2004 07:05 PM
