The Great Header Test Question -- Comptech Header
Old Jul 1, 2003 | 03:27 PM
jond's Avatar
Default The Great Header Test Question -- Comptech Header
The Comptech header used during the great header test was the carb legal 2.25'' one right? Was that bolted up to the stock cat and b-pipe?
Just wondering since the rest of the headers seem to be 2.5'' yet the comptech makes just as much power.
Old Jul 1, 2003 | 04:34 PM
BlueTeg's Avatar
Default Re: The Great Header Test Question -- Comptech Header (jond)
Actually the Comptech street header has a 2" collector. And yes its carb legal.
This is what Comtech said when I asked exactly what size their collector was on the street header:
"The collector pipe itself is 2-1/4" but it does step down a bit to 2.14" at the flange. This is needed so that the correct gasket can be used. The effect on power is negligible."
The only cat used in The Great Header test was a 2-1/4" Carsound used with the oem ITR header and cat back.
The Comptech header used a 2-1/4"x 2-1/2" stepped test pipe with a 2-1/2" cat back
The other JDM headers used a 2-1/2" test pipe.
Modified by BlueTeg at 6:20 PM 7/1/2003
Old Jul 1, 2003 | 05:25 PM
sackdz's Avatar
Default Re: The Great Header Test Question -- Comptech Header (BlueTeg)
Old Jul 2, 2003 | 03:30 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">"The collector pipe itself is 2-1/4" but it does step down a bit to 2.14" at the flange. This is needed so that the correct gasket can be used. The effect on power is negligible."</TD></TR></TABLE>
Thanks.
Its hard to believe it makes are much power as it does with that bottleneck in it.
Old Jul 2, 2003 | 03:02 PM
Edwin's Avatar
183 at the wheels baby with the Comptech 4-2-1 and a 2.5" exhaust and high flow cat. Stock intake.
Old Jul 2, 2003 | 03:28 PM
Chris N's Avatar
Default Re: The Great Header Test Question -- Comptech Header (Edwin)
amazing power considering the size....
Old Jul 2, 2003 | 04:49 PM
chet's Avatar
Default Re: The Great Header Test Question -- Comptech Header (Chris N)
the comptech is what i run, with a test pipe of course
Old Jul 2, 2003 | 07:10 PM
The Kernel's Avatar
Default Re: The Great Header Test Question -- Comptech Header (chet)
Old Jul 3, 2003 | 06:05 AM
WAFFLES's Avatar
Default Re: The Great Header Test Question -- Comptech Header (NBP #0933)
I wonder how that header would fair with a 2.25 or 2-3/8 exhaust piping on it? I'm sure the 2.5" helped it out quite a bit.
Old Jul 4, 2003 | 01:26 PM
BlueTeg's Avatar
On a bone stock R like the one tested, a Comptech street header + a 2 3/8" header back exhaust would most likely perform pretty close. At about 165 whp (stock output of the itr) you really don't need 2.5" piping. The 2.5" begins to show advantages when you start increasing the power into the mid-170's and higher.
Hukd Up
Apr 7, 2003 10:46 PM
OBDI JEDI
Mar 12, 2003 10:15 AM
DaRKniGhT ITR
Aug 21, 2002 01:50 PM
Monarch
Jul 15, 2002 10:26 AM
brownman72000
Jun 17, 2002 10:15 AM
