Brief question about header
Old Jul 5, 2003 | 07:19 AM
Utilitarian's Avatar
Default Brief question about header
I'm putting my stock two-piece exhaust manifold back on the R and getting rid of the DC 4-1 for autocross. Anyway, I was wondering if the stock manifold gasket can be used for the DC header? I haven't taken the header off yet so I don't know if the previous owner had to even change the gasket when installing the header. Do aftermarket headers usually come with gaskets the are necessary for installation? Lastly, will I be able to remove a big one piece header in my driveway with jackstands (clearance issue)?
Old Jul 5, 2003 | 08:20 AM
Padawan's Avatar
Darth ModerVader
Default Re: Brief question about header (BlackeR2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackeR2000 &raquo;</TD></TR><TR><TD CLASS="quote"> Anyway, I was wondering if the stock manifold gasket can be used for the DC header?</TD></TR></TABLE>
Yes, a stock gasket is used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackeR2000 &raquo;</TD></TR><TR><TD CLASS="quote">Do aftermarket headers usually come with gaskets the are necessary for installation?</TD></TR></TABLE>
Some do (e.g. Mugen), DC Sports does not. The instructions recommend that you reuse the manifold gasket and replace the donut gasket. I've never had a leak when I reused either/both of them, but I usually like to replace the donut gasket since it is soft and tends to wear and "mold" itself over time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackeR2000 &raquo;</TD></TR><TR><TD CLASS="quote">Lastly, will I be able to remove a big one piece header in my driveway with jackstands (clearance issue)?</TD></TR></TABLE>
Yes, you shouldn't have any problems. A few reminders:
- Torque specs. for the bolts at the head are 23 ft-lbs. in a criss-cross pattern starting at the center.
- Using anti-seize on the bolts/studs will make changing the header much easier in the future, and reduce the chance of snapping a bolt.
- The fans and AC lines can occasionally get in the way and it can be helpful to move them
Old Jul 5, 2003 | 10:31 AM
Default Re: Brief question about header (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
- The fans and AC lines can occasionally get in the way and it can be helpful to move them </TD></TR></TABLE>
Thanks.
beastman@
Jul 18, 2008 06:12 AM
94LSmanual
Jul 20, 2006 11:17 PM
escape2me
Apr 10, 2006 07:48 PM
Wazup
Sep 7, 2005 01:08 PM
rMak
18
Feb 4, 2005 12:02 PM
