bad idle problems
Old Jul 4, 2003 | 01:52 PM
Chubz's Avatar
Default bad idle problems
My JDM ITR motor has a weird idle. it idles and sounds like its a v8 with cams. Sprayed down all the vacuum lines and gasket areas and no leak. Im getting no check engine lights. I cleaned out the IACV. Compression test numbers are perfect. I adjusted the idle screw and no difference. Performance wise there are no problems, the idle will get low and the ecu will catch it and raise it,repeating the process over and over, the whole time it will not idle over 1000 rpms. Im stumped
Old Jul 4, 2003 | 02:14 PM
Big Phat R's Avatar
Default Re: bad idle problems (B18CR01)
Check your air filter?
Old Jul 4, 2003 | 02:49 PM
TypeR 599's Avatar
regap your spark plugs. that may help
Old Jul 4, 2003 | 04:34 PM
Chubz's Avatar
Default Re: bad idle problems (TypeR 599)
im going to replace the plugs with stock NGKs. My JDM ITR engine came stock with a 7 heat range, will it matter if i switch to a 6 range
vrrodri
Aug 20, 2018 07:06 AM
downshift3r
Sep 30, 2013 06:34 AM
dc4b20
22
Dec 3, 2012 09:54 PM
abusedvtec
Sep 1, 2009 01:44 PM
whitediamond642
Apr 10, 2007 04:37 AM
