Check engine light when cold.
Old Jul 2, 2003 | 03:38 PM
Mires's Avatar
Default Check engine light when cold.
The other day I start my car after work and without warming it up I take off. A few minutes later the check engine light comes on. It has happened one other time and I reset the ecu and it went away untill now. I took it to Acura a few months ago and they told me that my cat took longer than normal to completely heat up. I was wondering if the check engine light came on because my cat wasnt fully warm before I started driving? Does this sound right and if not what could be?
Old Jul 2, 2003 | 03:41 PM
MaxSterling's Avatar
Default Re: Check engine light when cold. (Mires)
depends on what CEL? for secondary o2 sensor, then yes. it checks to see if your cat is working properly
Old Jul 2, 2003 | 07:27 PM
Mires's Avatar
Default Re: Check engine light when cold. (keith_phan)
Thanks, I will check it as soon as I can.
Old Jul 3, 2003 | 02:31 AM
kkim's Avatar
what CEL code is it throwing?
Old Jul 3, 2003 | 04:38 AM
JiggyKooAndy's Avatar
Default Re: Check engine light when cold. (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">what CEL code is it throwing?</TD></TR></TABLE>
Old Jul 3, 2003 | 07:34 AM
Mires's Avatar
Default Re: Check engine light when cold. (JiggyKooAndy)
Not sure because I am at work right now. The question I have though is how do you check the code?
Old Jul 3, 2003 | 07:37 AM
Go here to check the code... http://www.team-integra.net/se...ID=34
RaVAGE00's Avatar
New User
do you have a high flow cat installed?
ph0shizzle
May 13, 2006 08:36 PM
bma1818
Apr 19, 2006 09:55 PM
97gSrkId88
Mar 20, 2003 11:06 PM
Komsomol
Dec 27, 2002 09:20 AM
