Civic 2013 ex l ac relay
Battery drain on civic it has been suggested ac relay gets stuck on and could be the issue problem is I don’t know which relay it is. Every diagram is different nothing is marked ac
Re: Civic 2013 ex l ac relay
There is a Honda service bulletin (TSB A12-041) regarding a new software update the vehicle did not start due to a low battery. The condition of the battery also needs to be checked and possibly replaced.
POSSIBLE CAUSE
The vehicle’s battery sensor monitors battery condition and the PCM determines charging mode. Based on the sulfation of the battery and customer driving habits, the PCM may not select the correct charge mode.
Edit: I just double checked, your year Civic is not part of the service bulletin, only certain 2012 Civics and 2012 - 2014 CR-Vs.
POSSIBLE CAUSE
akb427
Honda Civic (2001 - 2005)
06-28-2013 08:51 AM
