3-4 syncro problem
Old Jan 23, 2008 | 07:42 PM
R.Kelley's Avatar
Default 3-4 syncro problem
think i found my grinding issue, any one have any input?
Old Jan 23, 2008 | 07:47 PM
R.Kelley's Avatar
crap i forgot to write...theres no clearance between the gears and brass rings
Old Jan 23, 2008 | 08:10 PM
RTW DC2R's Avatar
thats how its supposed to be. syncro just sits right on the gear.
the problem to me looks to be on the dog teeth of the gear itself, the syncro looks fine. i would bet the sleeve (part that slides between the gears to select one or the other) probably has some damage as well. just my .02 based on the pics.
you should see my 4th gear which i had to replace. the dog teeth were shot, syncro wasnt too bad (worse than yours in that pic). decided to replace just the gear and i havent had much of a problem since.
Old Jan 23, 2008 | 08:22 PM
Aquafina's Avatar
It's possible to file the dog teeth, but its just a band-aid and doesn't work all the time. Get a new gear.
Old Jan 23, 2008 | 08:24 PM
RTW DC2R's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">It's possible to file the dog teeth, but its just a band-aid and doesn't work all the time. Get a new gear and dont forget to check the teeth on the sleeve.</TD></TR></TABLE>
Old Jan 23, 2008 | 08:25 PM
Aquafina's Avatar
I thought a new gear came with the sleeve and synchro?
Old Jan 23, 2008 | 08:27 PM
RTW DC2R's Avatar
maybe if you order the countershaft and mainshaft gears as a set? i just ordered the one gear by part number and it didnt include anything else.
Old Jan 23, 2008 | 08:31 PM
Aquafina's Avatar
I &lt;3 RTW.
He learned me sumthin 2dae.
Old Jan 23, 2008 | 08:33 PM
R.Kelley's Avatar
that 3-4 sleeve set and 3rd gear had about 6k miles on them. the teeth on the collar are kinda rounded too
Old Jan 23, 2008 | 08:34 PM
Aquafina's Avatar
Engage your clutch all the way before you start to shift.
Old Jan 23, 2008 | 08:35 PM
R.Kelley's Avatar
lol.....i also had a bad main shaft bearing(other side of Input shaft) it was all wobbly and **** might have been what cause the problem to begin with
Old Jan 23, 2008 | 08:38 PM
Aquafina's Avatar
From the trannys I've worked on, clutch case ISB goes first, then housing side ISB. Anytime I split a trans I replace the clutch ISB and inspect all the other bearings.
Old Jan 23, 2008 | 08:42 PM
R.Kelley's Avatar
the ISB was replaced before expo, the other one wasnt, so im thinking thats why all this **** went bad. Im hoping that acura will hook me up with warrany gears
Old Jan 23, 2008 | 08:43 PM
RTW DC2R's Avatar
or u could call these guys to help you out
18007778000
Old Jan 23, 2008 | 08:44 PM
R.Kelley's Avatar
I hate you Ryan
Old Jan 23, 2008 | 08:46 PM
RTW DC2R's Avatar
lol
Old Jan 23, 2008 | 08:48 PM
R.Kelley's Avatar
Default Re: (RTW DC2R)
i googled it
Old Jan 23, 2008 | 08:55 PM
RTW DC2R's Avatar
Default Re: (R.Kelley)
liaar nothing comes up in the google search i just tried haha youu are still on the fone with them?
Old Jan 23, 2008 | 11:04 PM
Aquafina's Avatar
I tried googling it. You have to add in the hyphens.
Old Jan 24, 2008 | 03:50 AM
R.Kelley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">liaar nothing comes up in the google search i just tried haha youu are still on the fone with them?</TD></TR></TABLE>
i did like waterboy said
Old Jan 24, 2008 | 06:29 AM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.Kelley &raquo;</TD></TR><TR><TD CLASS="quote">lol.....i also had a bad main shaft bearing(other side of Input shaft) it was all wobbly and **** might have been what cause the problem to begin with </TD></TR></TABLE>
Same thing happened to me in October. ISB went, caused 3rd and 4th to eat themselves, along with the slider ring. Although my tranny was beginning to pop out of gear when I realized something wasn't right. I would also recommend inspecting the faces of 3rd gear for any grooves or wear, if you had a bearing failure, many weird things may have happened.
BTW I replaced the 3/4/5 synchro rings with the GearSpeed carbon units, along with replacement slider collar and 3rd and 4th gears, thanks to some generous H-T users for providing decent (certainly better than mine) used parts. Tranny rebuilds seriously start adding up in cost
Old Jan 24, 2008 | 06:42 AM
R.Kelley's Avatar
yea like i said the 3rd gear was purchased back in april or may along with 2nd gear, 1-2 sleeve set, 3-4 sleeve set and countershaft bearings. im going to acura today to pick up some "special order" floor mats and too see what they can do for me for the busted parts
Apex1972
Dec 27, 2009 11:55 PM
integraboi1010
Mar 5, 2007 09:14 AM
creepy116
Dec 11, 2006 12:21 PM
maxpsi
Jun 16, 2003 01:40 PM
