motor problems continued: solved?
Old May 12, 2004 | 06:00 PM
magic hat #9's Avatar
Default motor problems continued: solved?
i went all the way down to http://www.jeimportperformance.com and met james evans, chris, and john. chris prepped my car for the dynapack and james worked the magic.
if you've never seen a dynapack, it's pretty f'ing cool dyno. it's so compact and eliminates the variables the wheels/tires can introduce.
if you remember, i've been consistently melting away the sparkplug electrode in cylinder #3. i have a mostly stock R with toda header and smsp cat; stock injectors and plugs. prior to my visit, i had eliminated the cause being the injectors, plugs, or a compression issue. the o2 sensor is an unlikely cause because there is no cel.
at je performance, we hooked up a fuel pressure gauge and eliminated a faulty fuel pressure regulator or fuel pump.
on the dyno we discovered the motor was running quite lean above 6k rpm. however, it wasn't lean enough to throw a cel so it may not be the true cause of my problem. james used a vafc to adjust the a/f ratio and move vtec engagement, here is the results:
nice gains, eh?!
the crooked lines around 7k rpm on the 1st run indicate detonation
i pulled out the plugs once i got home and they were still white however, i don't know how long it takes for the white stuff to get cleaned off; the drive home was 150 miles. i'm going to order fresh plugs tomorrow and keep a close eye on them.
Old May 12, 2004 | 06:41 PM
Bbasso's Avatar
Default Re: motor problems continued: solved? (magic hat #9)
Can't see the pics, do you feel any difference in the car after being tuned?
Old May 12, 2004 | 06:45 PM
Default Re: motor problems continued: solved? (Bbasso)
the pictures are courtesy of the wee-todds and it's running a bit slow. if you're patient, the pictures will eventually load.
i can feel the increased power, but i haven't gotten to rip up the local roads yet to really enjoy it. the vtec engagement point has been lowered so i no longer have that extreme pop going into vtec; it just pulls nicely right through the power band. of course, i still have bbbbaaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAAA!!!
PS: the pictures show 5ftxlbs and 15whp increase
Old May 12, 2004 | 06:57 PM
nightrider's Avatar
keep us updated because you had a very interesting problem.
Old May 12, 2004 | 06:58 PM
RTW DC2R's Avatar
if you are beating on the car, your plugs will probably have a whitish tinge to them even if you arent running that rich. why its melting/damaging the electrode though Im not sure.
Either way as long as its not detonating, those look like some decent gains from just a vafc tune
Old May 13, 2004 | 05:58 AM
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Either way as long as its not detonating, those look like some decent gains from just a vafc tune</TD></TR></TABLE>
yes, nice gains because the car was starved for fuel in vtec previously i can't wait to take her to a track!
Old May 13, 2004 | 06:00 AM
.RJ's Avatar
.RJ
Just curious, whats with the 10 ft-lb dip in torque?
Old May 13, 2004 | 08:06 AM
owen_the_soyboy's Avatar
yeah what is with that tq curve?
Old May 13, 2004 | 07:36 PM
Default Re: motor problems continued: solved? (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">yeah what is with that tq curve? </TD></TR></TABLE>
i don't know. the resolution makes the curve look even wierder since we're looking at a small portion of the torque range.
Old May 16, 2004 | 05:51 AM
6ghatch's Avatar
EDIT: Nice gains!!!
Modified by 6ghatch at 4:35 PM 5/17/2004
jeux
Jun 15, 2004 09:26 PM
91integraLSVTEC
16
Mar 7, 2004 07:16 AM
shermanyang
Nov 20, 2003 05:47 PM
accordexchange
Apr 5, 2003 03:44 AM
