VTEC engagement problem
Old May 9, 2004 | 08:14 AM
1insaneR's Avatar
Default Vtec engagement problem
I am having problems with the vtec engaging. Right when it kicks in, it starts to jump in and out of vtec, like it wants to go in but doesnt. Not sure what it could be, i have vafc but i have not had any problems with it for the year or so that i have had it. Any suggestions?
Old May 9, 2004 | 08:16 AM
Opie's Avatar
Check your oil
Old May 9, 2004 | 08:22 AM
TypeR15's Avatar
Default Re: (opie)
OIL!!!!!!!!!!!!!!!!!!!!!!
Old May 9, 2004 | 08:45 AM
BigBird
Default Re: Vtec engagement problem (1insaneR)
He's right If your vtec oil pressure switch closes then it will stop activation of vtec. If your oil is ok then check to see if you have a loose connection at your vafc or at the solenoid.. If nothings wrong it might be the solenoid. Seen a few go bad.
Old May 9, 2004 | 12:31 PM
1insaneR's Avatar
not the oil just changed it now, can't figure it out?
Old May 9, 2004 | 04:17 PM
type_r_556's Avatar
check the vafc wiring to the ecu, how did you install it, make sure there are no loose connections on the ecu and your vtec solenoid.
Old May 9, 2004 | 05:52 PM
1insaneR's Avatar
Plugged it into the pgm and it is throwing two codes, 1259 (Vtec system failure and Evap Leak) I guess the solenoid is gone. As for the Evap Leak i don't know what the hell that could be!
01ITR#173DC2ning
Aug 11, 2006 07:20 PM
tuckin15s_8315
Sep 28, 2005 10:12 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
salman
Mar 14, 2005 12:43 AM
crispydee
Sep 29, 2004 03:30 AM
