shift knob install
Old May 14, 2004 | 01:49 PM
-KangaRod-'s Avatar
Default shift **** install
Hey, a friend of mine bought a Momo shadow for her ITR, and loves the shift ****, but hates the fact that the boot sits down on the shifter. Does anyone have anytricks to hold the shift boot up?
Old May 14, 2004 | 02:18 PM
mugenracer's Avatar
Default Re: shift **** install (-KangaRod-)
Take off the centre console, get a small jubilee clip or something to clamp onto the shift lever at the point you want the boot to sit at (obviosly it'll have to be wider than the opening in the top of the boot) then put the console back on, screw on the **** and ta da...boot dont fall down anymore!
Old May 14, 2004 | 02:22 PM
vegas36's Avatar
my short shifter has a "nut like" thing that is tightened with a "key" screwdriver.....used to hold the shift boot up....im not sure what it's called or if the sell it seperatly...it's a DC sports short shifter if that helps.
Old May 14, 2004 | 02:36 PM
Ricey McRicerton's Avatar
Default Re: (vegas36)
You can just get under the boot and put a rubberband looped a lot of times. As long as its too big for the top of the boot to fall over it'll stay. Mine lasted 2 years before I tried to take it off and it descentegrated.
Old May 14, 2004 | 02:44 PM
98itr0448's Avatar
Get a momo boot. They have threads at the top of the boot that will go over the allen screws and take the place of the bottom ring cover on the ****. This will attach the boot to the bottom of the **** and eliminate any gap.
Old May 14, 2004 | 11:36 PM
ildknyli's Avatar
use a rubber band, works great
Old May 15, 2004 | 12:06 AM
J_Edwards's Avatar
Default Re: shift **** install (ildknyli)
I just used a zip tie. Just tighten it around the point that you want the boot to stop, and cut off the excess. It will stay forever.
J N
Old May 15, 2004 | 07:12 AM
-KangaRod-'s Avatar
when you guys say use the elastic band do you mean on the outside or the inside of the boot, because how would it work on the inside. I like the nut idea so far.
galognu
Transmission & Drivetrain
Feb 2, 2016 05:39 PM
Bright13
Honda S2000
Oct 30, 2011 03:10 PM
toshko321
10
Oct 5, 2009 08:21 PM
JDMtweezy
Honda S2000
May 6, 2007 11:57 AM
M0NEYnH0s
Feb 4, 2002 07:04 AM
