View Full Version : Acura TSX
Pages :
1]
11
- 2012 tsx 2.4 no spark
- K24a2 Timing Chain Rattle
- 2006 TSX re-locks immediately after unlocking with remote or key
- Is shorting ODB2 port pins 4 and 9 ok while engine is running?
- Shorted wrong OBD2 port pins - 2006 TSX not starting
- 2006 TSX engine delays response and goes weak at ignition
- 2006 TSX transmission "D" light flashing with message, but no EML
- Bad Starter?
- 09 Acura CSX Timing
- what can be used from TSX in EG swap
- 05 tsx 2.4L jdm types s engine/trans swap issues
- Reverse rear light not working
- TSX V6
- Custom gauge cluster idea
- What ECT2 and/or ECT1 temp turns on radiator fan?
- Tsx wagon 2013 transmission question
- Power Steering Pump Replacement Suggestions
- 2005 TYPE S 2.4 K24A3 Auto 5 speed
- DTC:PGM-FI
- 2005 TSX Hoses
- Header and HFC
- EPS module replaced, unable to clear fault code
- Regarding engine mount
- 06 TSX Gauge Cluster CAN adresses help
- Wagon production numbers by color?
- Wagon Cargo Dimensions sought
- 09 automatic transmission on 04 TSX
- How do I get front passenger Air Vent out. CL9 series Chassis
- 2009 Navigation issue
- 04 TSX Rear Speakers!
- TSX CL7 CL9 Mugen Wing
- In Need Of Some Help
- TSX RSX CRV same 2nd gear
- 2006 TSX ECU Swap To 07-08 ECU
- HandsFree Link - Bluetooth
- Desperately need battery advice
- 2007 TSX, will not start
- 09- 14 tsx 6 speed manual code?
- Do Integra Rotors fit 2010 TSX?
- 04 6mt tsx don’t start after rain ?!
- 08 tsx grill on a 09 tsx???
- Something exciting
- Lowering
- Battery Drain
- 2008 TSX warning lights stay on
- Speedometer
- 04 tsx engine swap
- 6 speed tsx turbo build questions
- Turbo TSX Build Questions.
- Problem with Hands Free Link system
- Location of ECU 2009 Acura TSX [CU2]
- Troubleshooting headlight issues on 2012 TSX
- Purchased new headlight bulb, worked for a few hours and then blew out...
- Headlight Bulb Question
- Searching for the hid ballast unit
- Engine sound problem
- JDM Accord and USDM TSX motor?
- Engine rattle, performance issue, tried everything: consider it a challenge!
- Knocking noise only when I start the car
- Acura TSX loud banging noise from the rear after fitting lowering springs
- 08 TSX HELP!!!! electric power mr2 spyder pump and breaking racks
- Blinking D and no start issue
- Cold start rattle. VTC actuator?
- Can Front Impact Sensors Be Re-used?
- TSX oil drain bolt
- TSX swap
- TEXAS A/C ISSUES, ITS HOT!
- 2004 TSX ECU.. Help
- TPMS calibration needed?
- Folding mirrrs not working
- Electricals shut down whilst driving/at idle
- Correct part for 2010 TSX AT 3rd Clutch Pressure Switch
- Stock rear toe adjustment? 1st gen
- PLEASE HELP!!! (K24A)What reference/service manual do i use to rebuild motor?
- 2013 trim question
- 09 tsx turning steering wheel and power shuts on and off
- How to Swap the Transmission WITHOUT Dropping the Subframe
- 06 TSX with Apex’i afc???
- Help buying Front Engine mounts
- Aftermarket Components
- can i run 235 Front and 245/45 Rear on 17x8 +45 TL waffles, stock height 08TSX.
- 2008 TSX with high mileage
- Honda accord key
- OEM amplifier compatibility
- 2009 TSX AC Issues
- Gas cap replacement. Lockable.
- 06+ A spec lip foglight bezel/garnish replacemeant?
- 2004 Automatic Trans. Noise
- Broke a harness- please help identify
- Is it true that the intake resonator only acts as a noise dampener if ..?
- TSX AC Woes
- 2004-06 CAN Bus Logging
- "Installed pads backwards" now LF/LR caliper seized! 08 tsx
- FlashPro not Not Detecting ECU
- Paint bubbles on windshield panels
- timing belt Acura tsx v6 2010
- 06 TSX Cold Start Grind Help
- 2005 TSX start-up issue
- Tsx 2007 Tein H Tech question
- 206 Acura TSX VSA / ! lights on after extended repair
- 06 TSX door lock actuator
- VSA and Engine light Honda Accord Euro 2005
- 2006 seat wiring pin out
- High idle not revving over 3k
- Techna-fit braided clutch line
- 2004 Acura TSX CTCC race car build
- 2014 TSX wagon
- 07 tsx climate control.
- Electrical issues
- 2011 acura tsx speakers don't work
- thinking about 2009-2010 6 speed tsx what can i expect?
- Alternative 6 speed manual transmission
- DC Sports Carbon Steel Front Upper Strut Bar for 04 TSX?
- help me figure out what these 2 plugs are
- 2004 Honda Accord Navigation Screen Messed Up
- transmission play. worn out diff?
- engine mount/bushings mistery solved
- 04 tsx massive throttle delay1 to2nd gear
- Symbol Maintenance Items
- 12 TSX HFL?
- Peering into the abyss
- Bad Alternator
- 2007 TSX A/C ISSUES?
- few issues with tsx i just bought
- softer solid rubber mounts?
- 2004 TSX AC compressor noisy but press clutch in and it goes away
- what are my options for engine mounts?
- 04-08 TSX ac compressor wire harness connector
- B13 reset?
- Speaker Brackets
- K24a absolute PS pump????
- Horrible gas mileage 05 TSX
- flashing engine light
- ABS light and handbrake light on at the same time
- clutch replacement
- Noise from my 2004 TSX
- Ac compressor lock up??
- Best D2S Bulb Replacement?
- 09 TSX CU2 Upgrades
- Acura TSX 2004 Navi - Radio Power Issue
- 04 TSX nav-Swapped in 06 stereo/cruise controls-lost voice controls-need wire diagram
- I need a Carbon Fiber TSX fenders
- Anyone have the TEIN Flex Z Coilovers?
- 04 TSX foglights not working anymore. New fuse, bulbs etc.
- D2R bulb in the TSX light?
- 2012 Interior buzzing noise
- Engine Clunk - Please Help
- TSX (Euro R Front emblem) screws
- AUX cord in 04 tsx, Searched. non-navi.
- 2006 TSX A/C Clutch Coil replacement
- VTC actuator
- 2004 2.2 i-CTDI low speed from the start
- Civic SI Transmission in TSX
- insurance Company Rip Off, or Not?
- Car only starts on second attempt
- K24a1 into tsx help?
- Summer tires for 2006 TSX
- 04-08 TSX Drl (daytime running lights)?
- Auto to manual tsx
- Owning my first CU9 '13 FSX
- HELP TSX CU2 Mugen Wing Install
- Heat induced LIMP mode. No error codes!
- 2006 TSX Radio Problem
- TL type S brembo on TSX
- A13 maintenance code
- *HELP* ABS codes 83-1 and 84-1 and p1009
- Mirror Control 2007 TSX
- HELP "My car runs but won't drive."
- 2004 TSX 6-speed (I just bought with engine issue)
- 2007 tsx cunningham edition
- Need Help Diagnosing Possible Transmission Issue
- Accord 5 speed trans into 06 tsx?
- How can I get Kpro in a 03 Euro R
- TSX LOUD rattling noise at stop in R or D
- TSX wagon owners, any here?
- My review for the new TruHART StreetMAX coil overs
- Need help finding a rear window visor ?
- Power Steering Leak, Only when Powered
- Delay problem. Maybe fuel pump? Idk
- Acura issue
- A/c clutch no engaging need help
- 2005 tsx..crank, no start
- 2006 Tsx Cold air intake
- rbc install on rsx - what's required
- 06 TSX Wipers: Pics, Info, Confusion
- picked up a 04 tsx with a blow motor what are my options
- New belt out of range?
- need help
- k24a2 rod bolt torque?? and main torque?
- A/C & Heater Stopped Working
- worth repairing a tsx?
- Engine Swap compatibility
- Original shocks tsx
- Timing chain tensioner specification?
- Anti-theft code for radio... before i rip it out.
- ABS/VSA light on after new OEM Honda abs sensors+pads
- Code: P0139 on 05 auto TSX(on/off)
- i want replace this broken parts
- 04 tsx vsa light and (!) on
- New Clutch And Now Car Wont Move
- Purchasing a high-mileage TSX?
- J32A3 vs A1 A2 compatablity
- Changing out wheels
- 06 TSX 4 year warranty?
- K24a2 Ac bypass belt 04 tsx
- 05 tsx exhaust
- Need assistance: Need Part # for Pigtail
- HELP!!! Connector Identification
- 05 TSX Navigation System
- what to look for when buying a TSX?
- New Owner of 2004 TSX - Some issues
- Ignition Coil and Tune Up Cost
- USDM 04-08 tsx front end conversion to 97-01 Euro r front end.
- TSX highest horsepower w.o force injection.
- Manual Conversion
- Mugen NR mirror face 18" help with these
- 08 TSX: A/C or Heat no longer blowing through vents. Culprit options?
- Changing vtec
- Gift idea for a TSX owner
- k-sport coilovers installed
- Did I mess up with that oil?
- what year rear bumpers interchange?
- Want advice on bodykits. Please help
- 6x9 and amp upgrade ??? 2006 tsx
- important question! do i need special tools
- 2004 tsx part coming off trans case
- Power steering pump replacement questiob
- what oils everyone running?
- tips and advice for changing a/c compressor
- Dashboard Error/Symbol Identification
- Back Up Camera (Post Accident)
- Need to replace clutch on 09 TSX. Looking for advice.
- CU2 Squad?
- A/C compressor not engaging ?
- after market hid bulb issue help please
- 3000k hid yellow fogs?
- Certified 2012 TSX Tech Missing TPMS Sensors
- Need some help with my wifes TSX...Running Rough
- vibration 22-30 mph.... wtf help
- please wheres the foglight reply
- Tires???????????????
- Help fix pregnant wife's car - P2647 VSA CEL Rough Startup/Idle
- Does anyone here have Accord V6-6MT wheels on their TSX?
- TSX transmission LSD?
- 2004-08 tsx have same headlights?
- i wanna see what a 1.5-2" drop looks like on a tsx
- fog lights not working?
- TSX Fuel Problem?
- wheel fitment ?
