Stock rear toe adjustment? 1st gen
As far as I can see there's no stock/factory rear toe adjustment on the CL9? unless i'm missing something. I assume one has to go and buy the Hardrace kit(4 arms total), as soon as you use an adjustable upper control arm in the rear you can see the toe is out of spec.
Re: Stock rear toe adjustment? 1st gen
I saw that once I decided to remove all the multi-link arms, wouldn't have provided adequate toe adjustment at my current ride height. Decided to get the 4pc toe/lateral arm set from hard race and the rear upper control arm aka camber kit as well.
scheibler
04-22-2016 10:20 PM
What good does swapping right rear upper control arms for left rear upper control arms do for caster
ESCALVANTE
11
03-12-2002 06:17 PM
