A/C problem
Old Apr 25, 2009 | 05:55 AM
beat's Avatar
Default A/C problem
Problem with the A/C pump.
It wouldnt turn on... but it would turn on if I fed it power directly....
Thought it was a problem with the ECU, but then I plugged in another ECU and it was still not working...
Any idea on what is wrong?
Where to start checking?
Old Apr 25, 2009 | 01:12 PM
Petah's Avatar
Default Re: A/C problem
Check your underhood fuse box for the AC relay. If it's firing up after being hardwired, chances are, your relay is not working.
Oh, also check your refrigerant level, i think there is sensor to disable thr AC compressor if it's low.
Old Apr 25, 2009 | 01:13 PM
beat's Avatar
OK, will check...
thanks
Old Apr 25, 2009 | 02:21 PM
Mr.OB*GYN_Rhett's Avatar
yeah, more than likely the relay, the pressure switch does not go bad very often.
Old Apr 27, 2009 | 09:16 AM
beat's Avatar
Checked the relay...
The relay is fine...
How to check the pressure switch? or any other suggestions?
Cheers..
pudhonda
Honda Civic (2006 - 2015)
Jun 10, 2017 11:43 AM
ek.troy
Jun 14, 2015 06:38 AM
E30LS1
Honda Civic (2001 - 2005)
Apr 21, 2013 07:34 PM
Jmunk
Dec 18, 2006 08:47 AM
Turbo E
16
Jun 2, 2004 01:32 PM
