Harnesses Help
Old Jul 10, 2002 | 12:18 PM
slowassR's Avatar
Default Harnesses Help
I'm ordering a pair of Sparco Evo's but I'm having trouble choosing which harness to go with. How are the 4 point Fixed catch Clubman harness? EEC approved with push button release buckle, $80? Is it worth paying $200+ for 4 point Professional rally/saloon harness. Aircraft quick release buckle, 3" shoulder straps and lap straps. FIA approved? Or is there some other Harnesses I should look at ....Takata's?
Old Jul 10, 2002 | 12:20 PM
uNF$@#!'s Avatar
Default Re: Harnesses Help (slowassR)
get a roll bar and proceed with a 5 pt or higher harness so you dont go submarining.
and for a harness that will need replacing every 2 years or so, better try your luck with something more affordable than takatas. SABELT does the job.
[Modified by Soup ****, 4:20 PM 7/10/2002]
Old Jul 10, 2002 | 12:29 PM
willydawsonv's Avatar
Default Re: Harnesses Help (Soup ****)
how much are they?
Old Jul 10, 2002 | 12:34 PM
ZygSpeed's Avatar
Harnesses are usually acceptable/good for about 5 years after the date of manufacture.
Old Jul 10, 2002 | 02:50 PM
uNF$@#!'s Avatar
Default Re: Harnesses Help (Zygspeed)
really? i thought most regulatory bodies require harnesses no more than 2 years old..
Old Jul 10, 2002 | 03:40 PM
slowassR's Avatar
Where is a good/affordable place to purchase harnesses?
Old Jul 10, 2002 | 04:45 PM
Bob#455's Avatar
For Sabelts:
http://www.racerwholesale.com
For Sparcos:
http://www.upracing.com
*Note: You will have to buy the appropriate mounting hardware separately. Sparco and Sabelt belt construction is the same...if you don't mind red, you can get the Sabelts for $109. If you do mind red, then you have to get Sparcos which are about $170. I got the Sparcos.
Old Jul 10, 2002 | 05:06 PM
ZygSpeed's Avatar
No Soup For You!!
I do believe SCCA is 5 years from the date of manufacture.
That is, unless you "use" them.
Another thing, it might be that Sparco and Sabelt are made by the same company.
[Modified by Zygspeed, 9:08 PM 7/10/2002]
Old Jul 10, 2002 | 05:48 PM
Chris's Avatar
Old Jul 10, 2002 | 05:52 PM
Bob#455's Avatar
Yes, they are identical except for the company name that happens to get stitched on the belts...
Old Jul 10, 2002 | 06:11 PM
Brett@SoloRacer.com's Avatar
I used to sell both Sabelt and Sparco 4 points but not anymore. Schroths are much better IMHO... http://www.soloracer.com/schroth.html
FYI: I only recommend using them for autocross. I wouldnt use them on the street or road course unless you have rollover protection. Alot of guys seem to use the Schroths in show cars too.
[Modified by Brett@SoloRacer.com, 7:12 PM 7/10/2002]
Old Jul 10, 2002 | 06:14 PM
Bob#455's Avatar
Default Re: Harnesses Help (Brett@SoloRacer.com)
I used to sell both Schroth and Sparco 4 points but not anymore. Schroths are much better IMHO... http://www.soloracer.com/schroth.html
I was looking into Schroth before I got my Sparco... Both offer 3" lap and shoulder belts. So what makes Schroth so much better? I wanted to get them, but for an extra $70, I couldn't justify it. They will both hold you in...
Old Jul 10, 2002 | 06:18 PM
D's Avatar
D
jeez... Brett loves schroth... we know, we know...
D
Old Jul 10, 2002 | 06:45 PM
SamB's Avatar
New User
Default Re: Harnesses Help (D)
If you can, get 3" lap and shoulder belts, they're alot more "comfortable" if you hit something!!! Plus 5 point is way better than 4 for more than just the submarining thing, the extra strap keeps the belts in a much better (lower) position and stops them riding up.
Sam
Old Jul 11, 2002 | 01:41 PM
slowassR's Avatar
Default Re: Harnesses Help (Sam & Bridget)
Awsome, thanks for all the help. I'll let you know what I choose and post some picks of the evo's. I'm ordering them tomorrow ...oh yea : ): )
Thanks again,
Luke
.:Made in OC:.
Feb 18, 2008 11:15 PM
chunkybs
64
Jan 17, 2007 10:28 AM
2fstGSR
65
Mar 11, 2003 06:32 AM
Ausmith
Apr 30, 2002 09:02 PM
