Brake Upgrade for DC2R
I am currently upgrading the brake setup on my 01"R after the front rotors warped at a long track day.. braided lines, master cylinder brace and quality race fluid i have got sorted already, but... ive heard so many suggestions as to what rotors and calipers to run. I want to know what has worked for anyone else out there who has done some brake tweaking on their R. Ive been looking at the mugen kit.. it comes with awesome carbon pads, rotors and calipers... I was not sure if this is overkill and a waste of $$... im thinking quality pads and rotors with the stock calipers will be enough (with some cooling tricks .. removing the dust plates and running ducting from the front air dam onto the rotors.) would an NSX upgrade work? will the caliper bolt on? ive also heard that Honda oddessy rotors give results as well. Some info would be great from some knowledgeable heads..
Some background reading for you before you start:
Brakes - Aftermarket
https://honda-tech.com/zerothread?id=725969 - Brembo
https://honda-tech.com/zerothread?id=763573 - DC5 Brembo
https://honda-tech.com/zerothread?id=665984 - TL Brembo
https://honda-tech.com/zerothread?id=578725 - ATS
https://honda-tech.com/zerothread?id=743266 - NSX
https://honda-tech.com/zerothread?id=720430 - NSX
https://honda-tech.com/zerothread?id=610835 - NSX
https://honda-tech.com/zerothread?id=482434 - NSX
https://honda-tech.com/zerothread?id=291367 - NSX
https://honda-tech.com/zerothread?id=239844 - NSX
https://honda-tech.com/zerothread?id=349039 - NSX/Legend
https://honda-tech.com/zerothread?id=409290 - Legend
https://honda-tech.com/zerothread?id=716441 - Spoon
Brakes - 96Spec ITR
https://honda-tech.com/zerothread?id=753762
https://honda-tech.com/zerothread?id=696362
https://honda-tech.com/zerothread?id=514109
https://honda-tech.com/zerothread?id=507924
Brakes - Interchangeable Brake Pads - From Other Hondas
https://honda-tech.com/zerothread?id=720450
https://honda-tech.com/zerothread?id=456229
Brakes - Bench Racing
https://honda-tech.com/zerothread?id=718169
Brakes - Brake Rotors
https://honda-tech.com/zerothread?id=779391 - Slotted vs Drilled vs Blank
https://honda-tech.com/zerothread?id=181691 - Autozone Brake Rotors
Brakes - Brake Fluid - General and Technical
https://honda-tech.com/zerothread?id=356467
https://honda-tech.com/zerothread?id=738858
https://honda-tech.com/zerothread?id=476984
https://honda-tech.com/zerothread?id=215060
https://honda-tech.com/zerothread?id=173650
https://honda-tech.com/zerothread?id=150665
https://honda-tech.com/zerothread?id=91602
https://honda-tech.com/zerothread?id=90092
https://honda-tech.com/zerothread?id=52231
https://honda-tech.com/zerothread?id=56941
https://honda-tech.com/zerothread?id=52655
Brakes - Brake Fluid - Replacement
https://honda-tech.com/zerothread?id=96449
https://honda-tech.com/zerothread?id=389232
https://honda-tech.com/zerothread?id=408343
https://honda-tech.com/zerothread?id=261228
https://honda-tech.com/zerothread?id=162954
https://honda-tech.com/zerothread?id=168907
https://honda-tech.com/zerothread?id=87384
https://honda-tech.com/zerothread?id=76001
Brakes - 96Spec ITR
it's unlikely you actually warped your rotor unless you pulled off the track and parked it hot. it's more likely a brake pad deposit that is "catching" on the pad with each revolution. you can lightly sand the rotor to remove the deposit. are you using real track pads? i found removing the dust shields makes a world of difference for brake cooling. you probably just need more effective cooling (and cool down) and good pads for track time, but if you want the best stuff - http://www.stoptech.com
Guest
Posts: n/a
buy some pads from COBALT get there GT SPORT pads ... they will break your neck will that mad stopping power yO.... dont for get to use ATE SUPER BLUE brake fluid
ask around you will get the same response about these pads
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">Some background reading for you before you start:
Thanks a lot man. There are some useful posts up there that I didn't bookmark.
themikewoo
15
Oct 10, 2007 06:09 AM
