TYPE R ENGINE OIL and TRANNY FLUID
Old Aug 21, 2007 | 09:53 AM
93(Civic)EG6's Avatar
Default TYPE R ENGINE OIL and TRANNY FLUID
What type of engine oil, tranny fluid, and oil filter do you guys recommend for a Type R? I am swapping a type r and need to refill all fluids. Also the prestone antifreeze works fine for this motor just as it does a GSR, right? Thanks.
Old Aug 21, 2007 | 09:54 AM
Dave_B's Avatar
This should keep you busy without questions for a while...
Oil Manufacturers Data Sheets:
https://honda-tech.com/zerothread?id=778788
Some Good Writeups and General Information Regarding Engine Oil:
https://honda-tech.com/zerothread?id=778792
https://honda-tech.com/zerothread?id=163845 - General Discussion
https://honda-tech.com/zerothre...54666 - General Information
https://honda-tech.com/zerothread?id=755474 - General Discussion
https://honda-tech.com/zerothread?id=736572 - General Discussion
https://honda-tech.com/zerothre...34928 - General Information
https://honda-tech.com/zerothread?id=735436 - General Discussion
https://honda-tech.com/zerothread?id=155706 - General Discussion - Racing Oils
https://honda-tech.com/zerothread?id=848572 - General Discussion
https://honda-tech.com/zerothre...39688 - Synthetic Oils
https://honda-tech.com/zerothre...55919 - Scan From European Honda Owners Manual
https://honda-tech.com/zerothread?id=687373 - Why Does Oil Change Color?
https://honda-tech.com/zerothread?id=237011 - Mixing Oils
https://honda-tech.com/zerothread?id=752447 - Oil Cooler
https://honda-tech.com/zerothread?id=772291 - Oil Cooler
https://honda-tech.com/zerothread?id=690311 - Oil Cooler
https://honda-tech.com/zerothread?id=790738 - Oil Change Intervals - Viscosity vs Oil Pressure
https://honda-tech.com/zerothread?id=683649 - Oil Change Intervals
https://honda-tech.com/zerothread?id=703074 - Oil Change Intervals - Raod Racing Forum
https://honda-tech.com/zerothread?id=676441 - Oil Change Intervals - FI Forum
https://honda-tech.com/zerothread?id=953467 - OEM Oil Filter Guide
https://honda-tech.com/zerothread?id=776832 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=636065 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=628322 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=655093 - Oil Filters
https://honda-tech.com/zerothread?id=692703 - Oil Filters
https://honda-tech.com/zerothread?id=645376 - Oil FIlters
https://honda-tech.com/zerothread?id=257687 - Oil Filters
https://honda-tech.com/zerothread?id=667846 - Oil Filters
https://honda-tech.com/zerothread?id=301809 - Oil Filters
https://honda-tech.com/zerothre...84428 - Smaller vs Larger Filters
https://honda-tech.com/zerothread?id=749869 - S2000 Oil Filter
https://honda-tech.com/zerothread?id=338193 - OEM Oil Filter
https://honda-tech.com/zerothread?id=776832 - OEM Oil Filter
https://honda-tech.com/zerothread?id=775725 - Oil Pressure Gauge Intallation
https://honda-tech.com/zerothread?id=748910 - Oil Pressure Gauge Benefits
https://honda-tech.com/zerothread?id=734880 - Oil Pressure Gauge - Mechanical vs Electric
https://honda-tech.com/zerothread?id=764002 - Oil Pan Baffling
https://honda-tech.com/zerothread?id=493919 - Oil Pan Baffling
https://honda-tech.com/zerothread?id=728886 - Oil Clean Up - Driveway Spills
Old Aug 21, 2007 | 09:59 AM
Default Re: TYPE R ENGINE OIL and TRANNY FLUID (93(Civic)EG6)
Wow,Now thats great for the oil now how about my other two questions about the tranny fluid and coolant?
Old Aug 21, 2007 | 10:00 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93(Civic)EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Wow,Now thats great for the oil now how about my other two questions about the tranny fluid and coolant?</TD></TR></TABLE>
Honda
and
Honda
Old Aug 21, 2007 | 10:09 AM
Dave_B's Avatar
I'm an avid Amsoil kind of guy myself.
Old Aug 21, 2007 | 10:11 AM
Ed 341's Avatar
Default Re: TYPE R ENGINE OIL and TRANNY FLUID (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
Honda
and
Honda</TD></TR></TABLE>
They make the car, can't go wrong with using their fluids.
Old Aug 31, 2007 | 02:09 PM
Mhollaek9's Avatar
how much tranny fluid does a GSR tranny take? Im changing it tomorrow for the first time and dont kow how much it needs? thanks
Old Aug 31, 2007 | 03:29 PM
pvt_awol's Avatar
Default Re: TYPE R ENGINE OIL and TRANNY FLUID (Mhollaek9)
damn Dave, you spent some time on that. I think the idea you may have been trying to get across though was lost.
Old Aug 31, 2007 | 04:28 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">Honda
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mhollaek9 &raquo;</TD></TR><TR><TD CLASS="quote">how much tranny fluid does a GSR tranny take? Im changing it tomorrow for the first time and dont kow how much it needs? thanks</TD></TR></TABLE>
1. You can find the answer in your factory service manual. If you work on your own car, you should have a service manual. If you don't already have one, you can buy a new one here. You might also find a used one on eBay or in the marketplace forums.
2. Perhaps you have not noticed. This is the Integra Type R forum, for discussing the Integra Type R. Questions about a GS-R belong in the Integra forum, not here.
Have a nice day.
Old Aug 31, 2007 | 07:43 PM
94rs-turbo's Avatar
2.3 qts of tranny fluid so 3 qts cost like $5.00 per qt newer stuff has a green label good stuff
Always recommend using oem honda oil filter
Many different oils you can use honda oil is made by Mobil 1 but get the Mobile1 at walmart 5 qt is cheap like $20-22
Rad. fluid you need to bottles of premixed since your already at honda might was well get it there costs like $8-9 anywhere you go
Slomo_civic
Honda Motorcycles
Mar 17, 2008 12:51 PM
d3xt3r19
Honda Civic (2006 - 2015)
Oct 9, 2007 07:51 PM
Tweakmeister
Oct 24, 2004 06:56 PM
jeux
Jun 20, 2004 08:48 PM
Floyd
Aug 3, 2002 04:28 PM
