What type of engine oil?
Old Mar 8, 2005 | 08:07 PM
n2civicsi's Avatar
Default oil type for itr
i have an 01 itr i was told to use 20-w50 is that a good oil to use or what u guys recommend thanks only 18k on it
Old Mar 8, 2005 | 08:08 PM
uNF$@#!'s Avatar
Default Re: oil type for itr (n2civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n2civicsi &raquo;</TD></TR><TR><TD CLASS="quote">i have an 01 itr i was told to use 20-w50 is that a good oil to use or what u guys recommend thanks only 18k on it</TD></TR></TABLE>
we recommend you search
or read the FAQ sticky on top
on this ghey thread.
Old Mar 8, 2005 | 09:42 PM
justahobbie's Avatar
I mix 9 parts motor oil with 1 part canola oil and a teaspoon of 3 in 1 for added lube.
Old Mar 8, 2005 | 10:14 PM
330R's Avatar
For a stock bottom end I would recommend looking on your oil cap or in the owner's manual.... those Honda guys know a thing or three about engines.
Old Mar 9, 2005 | 12:57 AM
pikkagtr's Avatar
i think Honda recommends 5w-30
i use Mobil 1 5w-30 in my R btw
Old Mar 9, 2005 | 02:18 AM
1999all_motoR_teg's Avatar
Default Re: (pikkagtr)
Straight milk. If it does a body good think what it does for your motor.
Old Mar 9, 2005 | 02:44 AM
DC2IntegraTypeR's Avatar
Default Re: oil type for itr (255.255.255.255)
Originally Posted by [url
https://honda-tech.com/zerothread?id=766629[/url]]
Oil Manufacturers Data Sheets:
https://honda-tech.com/zerothread?id=778788
Some Good Writeups and General Information Regarding Engine Oil:
https://honda-tech.com/zerothread?id=778792
https://honda-tech.com/zerothread?id=163845 - General Discussion
https://honda-tech.com/zerothre...54666 - General Information
https://honda-tech.com/zerothread?id=755474 - General Discussion
https://honda-tech.com/zerothread?id=736572 - General Discussion
https://honda-tech.com/zerothre...34928 - General Information
https://honda-tech.com/zerothread?id=735436 - General Discussion
https://honda-tech.com/zerothread?id=155706 - General Discussion - Racing Oils
https://honda-tech.com/zerothread?id=848572 - General Discussion
https://honda-tech.com/zerothre...39688 - Synthetic Oils
https://honda-tech.com/zerothre...55919 - Scan From European Honda Owners Manual
https://honda-tech.com/zerothread?id=687373 - Why Does Oil Change Color?
https://honda-tech.com/zerothread?id=237011 - Mixing Oils
https://honda-tech.com/zerothread?id=752447 - Oil Cooler
https://honda-tech.com/zerothread?id=772291 - Oil Cooler
https://honda-tech.com/zerothread?id=690311 - Oil Cooler
https://honda-tech.com/zerothread?id=790738 - Oil Change Intervals - Viscosity vs Oil Pressure
https://honda-tech.com/zerothread?id=683649 - Oil Change Intervals
https://honda-tech.com/zerothread?id=703074 - Oil Change Intervals - Raod Racing Forum
https://honda-tech.com/zerothread?id=676441 - Oil Change Intervals - FI Forum
https://honda-tech.com/zerothread?id=953467 - OEM Oil Filter Guide
https://honda-tech.com/zerothread?id=776832 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=636065 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=628322 - Oil Filter Comparison
https://honda-tech.com/zerothread?id=655093 - Oil Filters
https://honda-tech.com/zerothread?id=692703 - Oil Filters
https://honda-tech.com/zerothread?id=645376 - Oil FIlters
https://honda-tech.com/zerothread?id=257687 - Oil Filters
https://honda-tech.com/zerothread?id=667846 - Oil Filters
https://honda-tech.com/zerothread?id=301809 - Oil Filters
https://honda-tech.com/zerothre...84428 - Smaller vs Larger Filters
https://honda-tech.com/zerothread?id=749869 - S2000 Oil Filter
https://honda-tech.com/zerothread?id=338193 - OEM Oil Filter
https://honda-tech.com/zerothread?id=776832 - OEM Oil Filter
https://honda-tech.com/zerothread?id=775725 - Oil Pressure Gauge Intallation
https://honda-tech.com/zerothread?id=748910 - Oil Pressure Gauge Benefits
https://honda-tech.com/zerothread?id=734880 - Oil Pressure Gauge - Mechanical vs Electric
https://honda-tech.com/zerothread?id=764002 - Oil Pan Baffling
https://honda-tech.com/zerothread?id=493919 - Oil Pan Baffling
https://honda-tech.com/zerothread?id=728886 - Oil Clean Up - Driveway Spills
Old Mar 9, 2005 | 05:29 AM
200cs's Avatar
I use Amsoil 10w40 full synthetic. My bottom end has forged pistons and is a little looser than a stock cast one. It is also boosted. I have had good luck with Amsoil-I use it in the following vehicles:
2000 ITR 9psi boost.
2001 Ford Expedition 4x4.
2002 Stingray 200cs Powerboat.
Old Mar 9, 2005 | 09:13 AM
TypeRlove's Avatar
Default Re: oil type for itr (200cs)
i use honda 5w30, but i hear alot of people use mobil 1 5w30 which may be better for the motor.
Old Mar 9, 2005 | 09:21 AM
white rocket's Avatar
Castrol GTX 5w-30. I used to go to my local Acura dealership and get them to do it. But my hook-up that did it for next to nothing quit.
Old Mar 9, 2005 | 10:38 AM
Viper8L488's Avatar
Default Re: oil type for itr (white rocket)
It depends on a lot of things. First, how many miles do you have? Do you burn any oil? How often do you change your oil?
If you have a high mileage engine and burn 1-1.5 quarts every 3000 miles, than a heavier oil would be better. Perhaps a 10w40 or 20w50 castrol high mileage oil.
If you burn excessively, like more than 1.5 quarts overy 3000 miles, you should definately be using 20w50 and don't waste your money on synthetic. No need to spend more money on oil that is not staying in your crank case.
If you burn minimal amounts of oil (less than 1 quart every 3000) and change it often (3000 or less), 5w30 honda oil will be fine. If you change it less frequently, you can use a synthetic like Mobile 1 5w30.
I am a hypocrit because I change the oil in my ITR engine swap every 2500-2800 miles with Mobile 1 5w30. I also flush a quart through the engine once the crank case is drained before putting the drain plug back in. At $5/quart, it gets expensive to use Mobile 1.
As a side note, the biggest difference that I noticed when I went from conventional 5w30 to Mobile 1 5w30 is that I burned less oil. My engine has about 35k on it. When I used conventional oil and drove my car hard, I could burn 1 quart every 3000. With Mobile 1, I usually only burn 1/4 quart every 3000. I don't know, there is something about 8500 rpms that just makes oil disappear.
Old Mar 9, 2005 | 10:58 AM
uzabatty's Avatar
Default Re: (1999all_motoR_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Straight milk. If it does a body good think what it does for your motor.</TD></TR></TABLE>
lol
I use mobil1 fully synthetic 5w-30
Old Mar 9, 2005 | 11:28 AM
onyx00's Avatar
Default Re: (uzabatty)
Mobil1 10-w30; it's hot in AZ.
Old Mar 9, 2005 | 03:29 PM
JDMSpoonType-R's Avatar
Default Re: (onyx00)
I use Mobil 1 Fully Synthetic 10-w30, I don't know why, but I just do. Never given me any problems.
Old Mar 9, 2005 | 05:25 PM
totsie7944's Avatar
ROTF! haha
RACEPAK
Jun 18, 2010 11:46 PM
Mikeyjarey
Jul 25, 2009 05:06 AM
young_tuner
Jul 8, 2008 03:42 PM
N20civicB18
Jun 7, 2005 10:27 AM
HiChanDC2R
May 6, 2004 06:09 PM
