Holset users unite!
Old Sep 23, 2008 | 07:16 PM
  #2601
TopEndTuner's Avatar
Default Re: (SwappedTURBOegg)
what about spool time? I'm only shooting for around 15-17 lbs and maybe 400 Hp. Would the HX35 be a better choice for that?
Old Sep 23, 2008 | 07:25 PM
  #2602
SwappedTURBOegg's Avatar
no
Old Sep 23, 2008 | 08:04 PM
  #2603
I'm hearing on some of the dodge and diesel forums that the HX35 is good till around 35 lbs. Then I've got a tuner that has done a few nissans with them bolted on having some shaft problems at around 18 to 20 lbs. Whats the deal here? Will this charger get me to 400HP and be reliable?
Modified by TopEndTuner at 9:49 AM 9/24/2008
Old Sep 24, 2008 | 10:11 AM
  #2604
b20vtechb's Avatar
Default Re: (TopEndTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopEndTuner &raquo;</TD></TR><TR><TD CLASS="quote">I'm hearing on some of the dodge and diesel forums that the HX35 is good till around 35 lbs. Then I've got a tuner that has done a few nissans with them bolted on having some shaft problems at around 18 to 20 lbs. Whats the deal here? Will this charger get me to 400HP and be reliable?
Modified by TopEndTuner at 9:49 AM 9/24/2008</TD></TR></TABLE>
i've made 422 whp on 19psi on a pistons and rods ls/vtec with and HX35, that was on pump gas and i still coulda pushed it a little harder
Old Sep 25, 2008 | 07:40 PM
  #2605
oneslowstd's Avatar
Default Re: (b20vtechb)
Man I made 404whp and 342ftlbs on 10psi with a hx35 tuned on crome. You could make 500+whp with a hx35 man. They are good for 38psi on a diesel. It all depends on your setup.
Old Oct 2, 2008 | 03:13 AM
  #2606
h23isnotabigblock's Avatar
Default Re: (oneslowstd)
wow! that seems like alot of hp for only 10lbs. i got mine up and running and im running 10lbs on basemap, and the a/f is pretty decent and there is no knock, and i know im nowhere near 400...
thats a hell of a good tune!
what are the specs of the motor it is on?
Old Oct 2, 2008 | 09:41 AM
  #2607
oneslowstd's Avatar
Default Re: (h23isnotabigblock)
It was tuned on a S200, Now crome! The Specs are as follows: Stock Internals Jdm H22a/lsd with less than 50xxx on the engine! I was runing a Tial 38mm wastegate, drag gen1 manifold and then switched to tublar (which actually hurt me with the tune I was running) I foget the type of intercooler, 680cc prescion injectors running at like 88% duty cycle which was a little high, walboro 255lph, 3inch open down pipe which is why I made so much power and 3 inch pluming! Mind you.... I only ran it like this for a short period of time, so I can almost be certain that the longivity of this setup would not have been long. No replacement for displacement and the closed deck I think really helps compared to a B series
Old Oct 2, 2008 | 05:59 PM
  #2608
Puscifer's Avatar
Other then Ebay, where are you guys finding these holsets for sell? I am looking for a HX40 with the 6-blade billet compressor wheel.
Old Oct 2, 2008 | 09:14 PM
  #2609
oneslowstd's Avatar
Default Re: (Puscifer)
Go to a cummins dealer around you! Get cool with someone there talk to them bullshit with them ask them if they have any "damaged boxes" containing turbo's?? Cause if the box is damaged they cant sell the turbo and if that happens they usally stick the turbo in a place where its most likely going to sit for a long time. Thats how I got all 4 of my Hx35's and 1 HX30
Old Oct 6, 2008 | 09:58 AM
  #2610
slowhitEJ1's Avatar
probably been asked before, but what fitting do i need for the oil line on an HX35? restrictor? going on a D16
Old Oct 6, 2008 | 10:26 AM
  #2611
oneslowstd's Avatar
Default Re: (slowhitEJ1)
I dont know the actual measurement but as long as you have some kind of restriction, Honda's are high oil pressure motors so people claim that they blow out the seals in the turbo?? But you will be surpised at how much abuse one of these turbo's can take. If you really want to know ask this guy named James at garage 808 just google it and call him!
Old Oct 6, 2008 | 02:24 PM
  #2612
marcj's Avatar
I need some quick info guys.. I just finished putting my setup together, and the damn garrett turbo I got is leaking/smoking on the turbine side.. so I'm trying to find a good holset as a replacement, but i'm not entirely sure which would be a direct replacement with little to no modification..
my current turbo is a T3/T04E 57 trim .60/.63, and it's mounted for an a/c compatible setup.. so the compressor side can't be any larger, and the exhaust can't be any wider, and would be nice if I could fit my garrett turbine housing on it so I can use my 5 bolt down pipe..
any ideas?
pics:
Old Oct 6, 2008 | 03:58 PM
  #2613
look what i has
Old Oct 6, 2008 | 05:34 PM
  #2614
oneslowstd's Avatar
Nice!
Old Oct 6, 2008 | 05:36 PM
  #2615
oneslowstd's Avatar
Default Re: (marcj)
Look man get a HX35 external wastegate and slap it on there as far as the downpipe goes either get one fabircated or see if what you have works
Old Oct 6, 2008 | 05:40 PM
  #2616
slowhitEJ1's Avatar
hey.. just got a holset with a reman tag (no model number), and the wheel measures 82ish mm, any info?
Old Oct 6, 2008 | 05:59 PM
  #2617
oneslowstd's Avatar
Pictures help more!
Old Oct 6, 2008 | 09:21 PM
  #2618
b20vtechb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">look what i has
hx52 FTW you want a manifold and downpipe for that turbo i'm debating on parting out my car
Old Oct 6, 2008 | 11:52 PM
  #2619
oneslowstd's Avatar
Are you planing on moving a city with that turbo? My god! Its huge! What you get full boost at like what 5000rpm?
Old Oct 7, 2008 | 12:57 AM
  #2620
not sure when it will spool probably like 7k
b20vtechb i have a manifold already thx.
Old Oct 7, 2008 | 09:50 AM
  #2621
bnorth's Avatar
Holsets have an internal oil restrictor. The 6bt's make a ton of oil pressure as well and don't have a restrictor anywhere inline.
Old Oct 7, 2008 | 12:01 PM
  #2622
oneslowstd's Avatar
Default Re: (bnorth)
This is true, is it true for all holset turbo's?
Old Oct 7, 2008 | 01:43 PM
  #2623
b20vtechb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">not sure when it will spool probably like 7k
b20vtechb i have a manifold already thx.</TD></TR></TABLE>
cool on my car the hx52 hits full bost 20 psi on my setup at around 6000 but it kinda hits all at once there turbo will barely make 5psi before vtec kicks in and thats on a 2 liter
Old Oct 8, 2008 | 05:09 PM
  #2624
Puscifer's Avatar
I am looking for a HX40 6-Blade Billet Compressor Wheel Turbo. If anyone has one for sell toss me a PM.
Old Oct 10, 2008 | 12:47 PM
  #2625
thehatchninja's Avatar
Is anyone using a VGT holset?
http://cgi.ebay.com/ebaymotors...27248
I found this HE351VGT on ebay for $250. The electronics shouldn't be too complicated, and lowend would be awesome.
*edit
did some googling, found a DSM guy on HMT that is successfully using a VGT holset. He got rid of the electronics though, and is using a 14b wastegate actuator to control it instead. to that guy.
czech it out!
http://www.homemadeturbo.com/f...770.0
He talks about it some more on VWvortex. link http://forums.vwvortex.com/zer...26563
Modified by thehatchninja at 5:39 PM 10/10/2008
