Holset users unite!
Old Nov 2, 2008 | 05:36 PM
  #2651
big-cat's Avatar
anyone/bump
Old Nov 2, 2008 | 11:14 PM
  #2652
CRXdan's Avatar
Default Re: (big-cat)
you need a hy35
Old Nov 3, 2008 | 05:06 PM
  #2653
big-cat's Avatar
i need to trade someone my hx40 for a hy35 or hx35 12cm housing(totally irrelevant comment
Old Nov 3, 2008 | 05:44 PM
  #2654
CRXdan's Avatar
if you get the hx35, look into building a divided manifold to help that turbo spool.
are you revving to 10k? if not the hx35 will still be a tad big for that motor, but will do nicely. the hy35 can be had for cheap and looks like it will work perfect for a d series. good luck.
Old Nov 3, 2008 | 05:48 PM
  #2655
spoolin turbo s's Avatar
Default Re: (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan &raquo;</TD></TR><TR><TD CLASS="quote">you need a hy35
have you dynoed that setup IMO the hy35 is the best holset for sohc its very similar in spool and power output as a t3t4 50 trim on a 18t 20v VW motor anyway
the one on the vw had a 9cm housing and it seem to spool just a tad earlier than a .63 t3t4 50 trim
what size housing are you using? how much boost are you running? how is the spool?
what mods do you have to your motor? how high are you revvin?
Old Nov 3, 2008 | 07:37 PM
  #2656
big-cat's Avatar
50trim is weak sauce I like big turbos. going to be revving to 8500 with a fully built head(possible to rev to 10k but my tuner and I dont want to. hmmm I have a hx35g but it has 16cm housing and it is like a 53ish trim. wonder if I will be able to get that spooled.
  #2657
HiProfile's Avatar
Default Re: (spoolin turbo s)
Anyone know a good turbo place that rebuilds Holsets? I might even need a new turbine/shaft wheel here. I got a VGT HE351VE for almost free, it just needs some work.
Any links to part number info? I'm curious what a new turbine wheel/shaft will cost.
Old Nov 4, 2008 | 03:48 PM
  #2658
Turbocivic94's Avatar
Default Re: (HiProfile)
Hey guys, I need your input. I'm looking for T4 holset turbo.
Its going on stock lsvtec with built head.
Old Nov 4, 2008 | 03:51 PM
  #2659
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">look what i has
what turbo is this?
Old Nov 4, 2008 | 04:02 PM
  #2660
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know a good turbo place that rebuilds Holsets? I might even need a new turbine/shaft wheel here. I got a VGT HE351VE for almost free, it just needs some work.
Any links to part number info? I'm curious what a new turbine wheel/shaft will cost.</TD></TR></TABLE>
pm TheShodan i've heard that holsets are the easiest of all turbos to rebuild
do you know anything about that turbo cause i do pm me if you want to talk about it
if i was going to picka holset that one is the one i would pick
pm me and we'll chat about it
Old Nov 4, 2008 | 04:12 PM
  #2661
tony413's Avatar
Default Re: (Turbocivic94)
lol it says HX55
Old Nov 4, 2008 | 06:13 PM
  #2662
Default Re: (tony413)
Can someone sell me HX40 with T4 Flange?
Old Nov 4, 2008 | 06:25 PM
  #2663
the best place i've found to find good cheap holsets is truck shops that do suspension work and stuff like that
usually they like to upgrade their turbo while they are there and the shops have no use for the used turbos and will sell them for dirt cheap
Old Nov 4, 2008 | 06:41 PM
  #2664
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone sell me HX40 with T4 Flange?</TD></TR></TABLE>
i think your gonna need a 14cm^2 housing or larger i cant really remember
Old Nov 5, 2008 | 05:09 AM
  #2665
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
i think your gonna need a 14cm^2 housing or larger i cant really remember </TD></TR></TABLE>
Thats German to me. LOL
Old Nov 5, 2008 | 06:11 AM
  #2666
tony413's Avatar
haha its the A/R of the turbine for holset. 14cm^2 is like a .63 or .82 i'll list the equivilants laters
Old Nov 6, 2008 | 03:54 AM
  #2667
alright, I figured out some other stuff.
What would be a good turbo for stock lsvtec. want to make 400whp
I have T4 manifold and I'm gonna drill for T3 so I can use any turbo.
Old Nov 6, 2008 | 07:23 AM
  #2668
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">alright, I figured out some other stuff.
I have T4 manifold and I'm gonna drill for T3 so I can use any turbo.</TD></TR></TABLE>
i ran the hx35 on my ls/vtec...never got any dyno sheets but anything over 15psi open dp ripped my dr's right off...spooled hella fast too since i had the 12cm housing, although after it all id probably go a lil bigger to the 16cm so that the onset of power wasnt so quick
Old Nov 6, 2008 | 01:10 PM
  #2669
Default Re: (drumking15)
I want to try one, I guess I'l keep watching ebay for one.
Old Nov 6, 2008 | 02:49 PM
  #2670
The G2 Racer's Avatar
Where are you guys getting your turbos? Egay?
Old Nov 6, 2008 | 10:31 PM
  #2671
CRXdan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">
what mods do you have to your motor? how high are you revvin?</TD></TR></TABLE>
Ive had a .48 and a .63 50 trim and 60 trim on the car before. best setup out of the 4 IMO was a .63 50 trim, but then again i only ran 12 psi.
My relevant setup info that pertains to spool is as follows
Vitaras
TT rods
59300 cam
stock head
ramhorn
3" exhaust
2.5" charge pipes
Id like to see full boost (~20 psi) before or right at VTEC crossover
power goals mid 300s on pump 400+ on race.
Oh and FYI, the HY35 flows similar to the 60 trim wheel from the comp maps ive seen, and is less likely to surge. It also is much more efficent at higher boost levels. I have a 9cm2 housing which from my understanding is .64 AR, although I may be wrong. Either way, its on there and im using it. I think its good for the d series. Id be concerned about putting it on a b series though. HX35 for sure.
Old Nov 7, 2008 | 03:36 AM
  #2672
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">question. I have an hx40 with 18cm housing and the wheel is 57trim(not sure the housing size for the compressor side. it has a 3.5in v band on it.
for a decently built d16 with a log manifold and 3.5in DP. Do you guys think I will have a chance in hell of spooling it?????? thanks to any help.</TD></TR></TABLE>
Sell me HX40 and buy yourslef a hy35. You would thank me later
Old Nov 7, 2008 | 03:39 AM
  #2673
CRXdan's Avatar
Sell me HX40 and buy yourslef a hy35. You would thank me later </TD></TR></TABLE>
you finish grade 12 english?
Old Nov 7, 2008 | 03:48 AM
  #2674
you finish grade 12 english?</TD></TR></TABLE>
no sir, still learning
Old Nov 7, 2008 | 08:59 AM
  #2675
oneslowstd's Avatar
Holset rules
