b18c5 valve lash????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konlao »</TD></TR><TR><TD CLASS="quote">adjusted valve to specs and still is gettin the tappin' noise.... could it be somethin else????</TD></TR></TABLE>
B-series injectors are quite loud. Assuming you did the valve adjustment properly, there's a good chance you could be confusing the injector ticking with valve tap. Is this something you just recently began hearing?
I bet you never saw the FAQs ????
If you did... You would have been busy reading all these
ngine - Valve Adjustment - How often?
https://honda-tech.com/zerothread?id=723071
https://honda-tech.com/zerothread?id=105593
Engine - Valve Adjustment - Techical
https://honda-tech.com/zerothread?id=631935
https://honda-tech.com/zerothread?id=550113
https://honda-tech.com/zerothread?id=565551
https://honda-tech.com/zerothread?id=453814
https://honda-tech.com/zerothread?id=459045
https://honda-tech.com/zerothread?id=426405
https://honda-tech.com/zerothread?id=406588
https://honda-tech.com/zerothread?id=357511
https://honda-tech.com/zerothread?id=293109
https://honda-tech.com/zerothread?id=285288
https://honda-tech.com/zerothread?id=223340
https://honda-tech.com/zerothread?id=224619
https://honda-tech.com/zerothread?id=78449
https://honda-tech.com/zerothread?id=72382
https://honda-tech.com/zerothread?id=61088
Engine - Valve Adjustment - General
https://honda-tech.com/zerothread?id=578563
https://honda-tech.com/zerothread?id=486097
https://honda-tech.com/zerothread?id=400418
https://honda-tech.com/zerothread?id=84825
Engine - Valve Adjustment - Tools
https://honda-tech.com/zerothread?id=584581
https://honda-tech.com/zerothread?id=492528
https://honda-tech.com/zerothread?id=475005
https://honda-tech.com/zerothread?id=472553
https://honda-tech.com/zerothread?id=450030
https://honda-tech.com/zerothread?id=265655
https://honda-tech.com/zerothread?id=182979
https://honda-tech.com/zerothread?id=111128
https://honda-tech.com/zerothread?id=109047
https://honda-tech.com/zerothread?id=57296
Engine - Valve Adjustment - Aftermarket
https://honda-tech.com/zerothread?id=362773
https://honda-tech.com/zerothread?id=334961
https://honda-tech.com/zerothread?id=312772
https://honda-tech.com/zerothread?id=252155
https://honda-tech.com/zerothread?id=72541
B series valves are always loud anyways.
Rev the engine up, if the noise goes away on the rev down, and continues when the engine starts idling, it's just the injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell »</TD></TR><TR><TD CLASS="quote">in 0.15-0.19
ex 0.17-0.21</TD></TR></TABLE>
would this be the same for JDM? think they are the same cams and valves arent they?
could 1 injector be loud and the others normal? im having the same problem, it sounds like the valves in cylinder 3.
i hear a tapping just from one cylinder, it goes away for a little bit and then comes back, could it be detonation? i checked the plug and they are all fine, what else could this be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer2k1 »</TD></TR><TR><TD CLASS="quote">could 1 injector be loud and the others normal? im having the same problem, it sounds like the valves in cylinder 3.
if it was detonation youd know it, from what your saying sounds like injector to me.
anyone have the answer to my question?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJtypeR »</TD></TR><TR><TD CLASS="quote">
would this be the same for JDM? think they are the same cams and valves arent they? </TD></TR></TABLE>
