K24a1 vs k24a4
K24a1 vs k24a4
I got a k24a1 and a k24a4, im doing a k swap on my car will be doing the type s oil pump and changing the head to a k20z3 head probably with the cams and everything which block would be better to do it with? Will be doing rods and pistons as well too
Re: K24a1 vs k24a4
If you are going to replace the OE rods and pistons, then either block will be just fine. The only benefit to using the K24A1 (CRV) block is that the main girdle is flat, so your A2 oil pump will NOT have to be modified to fit.
Re: K24a1 vs k24a4
You dont want them. They bleed off oil and create lots of windage. If youre pushing the tuning hard enough to need them, you would want forged pistons anyway.
Spankedrican92
10
07-06-2013 03:47 PM
