DA Integra's Only
Old Jul 28, 2010 | 09:39 PM
  #41651
Mattyg2's Avatar
Default Re: DA Integra's Only
Why is the license plate not in the middle on that DA?
Old Jul 28, 2010 | 10:03 PM
  #41652
uses0ap's Avatar
Originally Posted by esvinjose
can i touch it?
Old Jul 28, 2010 | 10:57 PM
  #41653
Mattyg2's Avatar
GAY
Old Jul 28, 2010 | 11:33 PM
  #41654
Ef9vsDa9's Avatar
WTF!
Old Jul 29, 2010 | 12:19 AM
  #41655
HeLLa iLL2ndGen's Avatar
I want to see a video of that K series DA
Old Jul 29, 2010 | 03:44 AM
  #41656
c_mack9's Avatar
j speed III? i wondered what they would look like on a da.
Old Jul 29, 2010 | 07:16 AM
  #41657
Mattb16teg's Avatar
Community Builder
Community Influencer
esvinjose, I see the car is still 4 lug, what axles and hubs did you use for the swap?
Old Jul 29, 2010 | 08:09 AM
  #41658
DumaDA's Avatar
i was not expecting to see a kseries under the hood of that car, it looks great, simple and clean and must be a beast with that K.
Old Jul 29, 2010 | 08:16 AM
  #41659
Ef9vsDa9's Avatar
thats the second K series Da i've ever seen.
Old Jul 29, 2010 | 08:17 AM
  #41660
DumaDA's Avatar
yup, this one and the orange one are the only two i've seen and i believe that orange one either got parted out or was sold
Old Jul 29, 2010 | 09:50 AM
  #41661
Ef9vsDa9's Avatar
does anyone else know if a Dc driver axle will fit a Da??
Old Jul 29, 2010 | 09:53 AM
  #41662
DumaDA's Avatar
it will not work without the da halfshaft, i asked a couple of my other friends yesterday as well
Old Jul 29, 2010 | 09:55 AM
  #41663
kNOwLedGe.'s Avatar
He's probably using base RSX axles and stock hubs.
Really? There are quite a few K swapped DAs out there. I even saw one for sale on Craigslist here in LA a few weeks ago.
Here is one from a G2IC member in Canada:
Old Jul 29, 2010 | 09:56 AM
  #41664
DumaDA's Avatar
I've heard that as well, for 4 lug you use the base model RSX axles and for 5 lug you use the type S axles
Old Jul 29, 2010 | 10:04 AM
  #41665
Ef9vsDa9's Avatar
first you said it wouldnt with a Da halfshaft now your saying it will, what is it?
Old Jul 29, 2010 | 10:06 AM
  #41666
kNOwLedGe.'s Avatar
Just found another:
Old Jul 29, 2010 | 10:09 AM
  #41667
Ef9vsDa9's Avatar
OMG fine theres more than two k swapped da's
Old Jul 29, 2010 | 10:14 AM
  #41668
Ef9vsDa9's Avatar
my stock Da halfshaft is still on the car, so that means i can use a dc axle?
Old Jul 29, 2010 | 10:16 AM
  #41669
DumaDA's Avatar
i meant to say dc
Old Jul 29, 2010 | 10:43 AM
  #41670
hb420's Avatar
There's a k swapped da for sale in pa
Old Jul 29, 2010 | 12:22 PM
  #41671
BNAV's Avatar
yeah thats like 5.
Old Jul 29, 2010 | 01:07 PM
  #41672
DumaDA's Avatar
link to the kswapped DA in pa?
Old Jul 29, 2010 | 01:12 PM
  #41673
g2_teg_'s Avatar
the passenger side will work without problems. drivers side you need the intermediate shaft.
Old Jul 29, 2010 | 01:42 PM
  #41674
teggi's Avatar
fellas, i'm having a little problem with my obd0 to obd1 conversion.
i used this info for the conversion http://hondaswap.com/hybrid-eg-ek-dc...version-88572/
the pinouts are half ways down the page.
the car is trowing two cels
#20- ELD
#41- o2 sensor
when i jump it, it starts fine, idles fine. however, when i try to start it without jumping it, the first time i turn the key it'll try to start but will quickly die and if i keep trying, the battery eventually dies within minutes.
i would appreciate if you guys can give me some advise on what to do here
Old Jul 29, 2010 | 01:48 PM
  #41675
DumaDA's Avatar
So you rewired and did everything yourself instead of buying the conversion harness basically? If you converted to obd1 the ecu will be looking for the 4 wire o2 sensor which you must still have the obd0. I've heard that having a bad o2 sensor or not running an o2 sensor can cause the car to not start and to die, try either adding the 4 wire o2 sensor or if you can get your ecu programmed have them delete it. im not sure about the other code
Edit: Just looked up the code 20 and it appears you can have the deleted from your ecu as well without affecting the drivability, The ELD just basically senses when the car is using more electricity such as turning on defrosters etc and supplies more fuel to make up for it
