DA Integra's Only
I'm running a Go-Autoworks 12" slim fan & aluminum shroud. The shroud helps with cooling a TON, it helps disperse even air flow across the entire rad core. I had cooling issues before I installed it, but after that, no problems at all.
my rmf is one of the original replicas so the newer ones have revisions. its the polished version that was a prototype tester sent to dfe before the brushed finished one came out. mine has the fixed header flange and not the floating one like the newer ones.
Has anyone ever had problems with integrated control unit?
I have some issues with various electrical items that arent connected together except either dimmer curcuit or integrated control. Cant find any wiring diagrams or test procedure for these units.
I have wiring dia. for each affected elec. item (rear defogger, cruise switch light on, oil pressure guage, O2 guage, water temp. guage in dash cluster, coursty light w/ door open) not all items f*** up at the same time and sometimes they all work.
Cruise control has been deleted and cruise control unit unpluged. Indicator light on sometimes and sometimes not.
Rear defogger sometimes works and sometime not.
Aftermarket oil and narrow band (pretty light) guages work but shortly stop working. the lights stay on but both drop off to 0 and not at same time. Oil is wired dir. to sending unit. Both share common ground and feed wires.
Water temp guage in dash starts reeding hot then suddenly drops back to normal.
Turn car off and back on everything works fine most of the time.
I REALLY DONT GET IT. None of these items are related to one circuit. Oil pressure gauge is wired to sending unit. WTF!
Any guesses? Checked thermostate housing ground.
Anyone had problems with JDM cluster? No dimmer circuit in it.
Low rpm idle water gauge bounces, O2 guage, oil gauge start bouncing. I have low and lopy ilde crower 404's at 400rpms .
Any thoughts from the honda masters out there. I am running out of hair.
That damage was a hit and run while in a Ross parking lot -__- wasnt there wen i went in... there when i went out
I personally like the 90-91 bumpers better 92-93 just looks like a big smiley face..
