Holset users unite!
Old Jan 16, 2007 | 01:25 AM
  #1526
boosted_crx's Avatar
boostededej1- color is Electron Blue Metallic. We were running a conservative map, b/c i was just playing around on the dyno and trying to get a feel for the car and the motor and what not. Once i get some other little quirks sorted out with it, ill be heading back to see what i can sqeeze out in a serious tune. As others have mentioned, at around the 10-12psi on a b-series holset motor, the car should be able to hit around the 300 mark. we'll go back drop the boost down and start working from there and see where we get.
KeyserSoze- its rich b/c as i mentioned above, this was not the final tune for the motor.
my cams gears are at +2 intake -2 exhaust with a 3" exhaust, 2 resonators, no cat, and the HY35
Old Jan 16, 2007 | 10:05 AM
  #1527
SL0WEGG's Avatar
Default Re: (boosted_crx)
hx35 12cm2 housing should say 3533139
heres something else if you cant find out what you have.
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old Jan 16, 2007 | 10:51 AM
  #1528
Bboy_Trevstuh817's Avatar
Thanks for that link boostedej1 Im sure my f22b1 would like the H1C!
Old Jan 16, 2007 | 10:58 AM
  #1529
SL0WEGG's Avatar
Default Re: (Bboy_Trevstuh817)
i'm sure it would. What motor wouldn't?
Old Jan 16, 2007 | 11:05 AM
  #1530
Im still trying to find info on it and none of the pin numbers where on that site, but I got a good deal $60 with very lil shaft play!!
Assy: 3528918
Serial: H 395793
Cutomer: 3528918-1-10/0
Type: H1C
That's on the compressor side and on the exhaust side:
3521934
16-27-32
Modified by Bboy_Trevstuh817 at 12:31 PM 1/16/2007
Old Jan 16, 2007 | 11:05 PM
  #1531
SL0WEGG's Avatar
if you didnt know thats a 16cm turbine housing. Shouldn't have any problems spooling that up with the f22.
Old Jan 17, 2007 | 07:16 AM
  #1532
j-spec_cc2's Avatar
I have a holset h1e w/ what i believe to be a 19cm turbine housing. would that be too big to spool on a 2.5L? i heard some people on this thread stating that a 14-16 would be good on a 2.2, so i'm ASSuming that 19 should be ok for a 2.5.
Old Jan 17, 2007 | 09:39 AM
  #1533
SL0WEGG's Avatar
Default Re: (j-spec_cc2)
theres someone using 14 or a 16 on a b series motor. I dont think you'll have any problem spooling the 19cm on a 2.5l. Maybe someone else can chime in.
Old Jan 17, 2007 | 09:47 AM
  #1534
Minor Threat's Avatar
Default Re: (boostedej1)
You will like it.
I've spooled an 18cm on a 1.6L, in 2nd gear it made 15 psi around 5500.
Old Jan 17, 2007 | 10:21 AM
  #1535
tyrone27's Avatar
Default Re: (Minor Threat)
Any one have info on what size Turbo this is and what housing is on it?
Assy: 3538868
Serial: C01264495
Model: HX35W
Turbo was given to me and I'm trying to find information on it.
Old Jan 17, 2007 | 11:06 AM
  #1536
SL0WEGG's Avatar
Default Re: (tyrone27)
duh, its an hx35.
Old Jan 17, 2007 | 11:51 AM
  #1537
tyrone27's Avatar
yea but what housing? I'm trying to see what cm number it is.
Old Jan 18, 2007 | 03:13 PM
  #1538
Jockobo's Avatar
anybody ever use one of those rebuild kits on ebay?
Old Jan 18, 2007 | 03:21 PM
  #1539
TTT's Avatar
TTT
Default Re: (Jockobo)
Holset Rebuild kits
Old Jan 18, 2007 | 03:36 PM
  #1540
Jockobo's Avatar
Default Re: (TTT)
any sucess with them?
Old Jan 18, 2007 | 06:37 PM
  #1541
Sonic Reducer's Avatar
Default Re: (dubnit)
who has maxed out an HX30, at what boost and power? trying to decide between 9cm hy35 and hx30. lower the boost comes on the better. around 320 at the crank would be nice. thinkin HY35W but dont want to count out the hx30.
2.2L
8.3:1
heads do 260cfm intake 180 exhaust @ .354" lift
Old Jan 18, 2007 | 11:07 PM
  #1542
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyrone27 &raquo;</TD></TR><TR><TD CLASS="quote">yea but what housing? I'm trying to see what cm number it is.</TD></TR></TABLE>
look for numbers on the turbine housing and report back. Then we can find out what you have. By doing a quick search on the numbers you posted, i didnt really come up with much except the fact that its could be a 14cm housing
Old Jan 20, 2007 | 07:52 AM
  #1543
deeweezy187's Avatar
which holset turbo do you guys think can get a f22b2 accord to 300 whp by 15psi. The engine will be built with pistons and rods.
Old Jan 20, 2007 | 10:28 AM
  #1544
SL0WEGG's Avatar
Default Re: (deeweezy187)
hx35
Old Jan 20, 2007 | 02:17 PM
  #1545
gokhan's Avatar
guys, i can find hx35w holsets here but i do not know which housing it is. The numbers that you give for the 12cm^3 housings do not match the numbers of the turbos that i found here. I think it is because we do not have dodge rams in here, the holset hx35w is used in bmc trucks in here. Do you have any idea how can i measure it or find out if it has a 12cm^3 housing?
Old Jan 20, 2007 | 03:25 PM
  #1546
SL0WEGG's Avatar
Default Re: (gokhan)
it says it on the inside of the turbine housing. I'll take a picture for you.
Old Jan 20, 2007 | 05:59 PM
  #1547
gokhan's Avatar
thanks i'am waiting
Old Jan 20, 2007 | 08:14 PM
  #1548
SL0WEGG's Avatar
almost forgot, here you go
Old Jan 23, 2007 | 12:14 PM
  #1549
Paul_VR6's Avatar
Selling mine: HERE
Old Jan 24, 2007 | 10:27 PM
  #1550
turboeg77's Avatar
Default Re: (Paul_VR6)
can a built D-series run an hx35 with a 12cm housing?
