Holset users unite!
Old Jan 10, 2007 | 07:16 AM
  #1501
speeddave's Avatar
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">IMHO the 12cm2 housing is the biggest to ever run on a gas motor. If you are going to use a holset turbine housing the 9cm is the way to go. The problem with that is that most of those have the nasty internal wastegate the make the turbine housing huge.
I guess this is the reason the BEP housings are so popular.</TD></TR></TABLE>
i stated this a bit earlier in the thread i think, but i run a hx35w w/a 14cm2 exh(wastegateless) i start seeing boost by about 4g and get 12lbs by about 4500rpm. this is on a 1.8l ls/vtec w/a stock cam'd b16a head.
Old Jan 10, 2007 | 10:55 AM
  #1502
TTT's Avatar
TTT
I just like good throttle response... That is why I usually go with the smaller A/R housings. The big turbine wheels of the Holset allow for good flow on the top end.
Old Jan 10, 2007 | 11:04 AM
  #1503
SL0WEGG's Avatar
Default Re: (TTT)
I want a highway beast and full boost by 6.5k revving to 7k. lol j/k. I'm still looking for a 12cm2 housing. From the looks of it the 9cm2 will die up top.
Old Jan 10, 2007 | 12:32 PM
  #1504
disamis's Avatar
Default Re: (gokhan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gokhan &raquo;</TD></TR><TR><TD CLASS="quote">can anybody give me the serial numbers that is written on the housing of the 12cm holset hx35? </TD></TR></TABLE>
help asap pls...
Old Jan 10, 2007 | 02:46 PM
  #1505
drumking15's Avatar
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">I just like good throttle response... That is why I usually go with the smaller A/R housings. The big turbine wheels of the Holset allow for good flow on the top end.</TD></TR></TABLE>
good throttle response...hell i step on it in any gear and within seconds im at full-song...i just think its pointless to choke down the housing when your already seeing decent spool times...
Old Jan 10, 2007 | 05:38 PM
  #1506
tyrone27's Avatar
Default Re: (drumking15)
Anyone have a compressor map for the HX40? need a enlarged one where I can see teh numbers. I'm mapping out a compressor map for a motor.
Old Jan 10, 2007 | 06:16 PM
  #1507
TTT's Avatar
TTT
Default Re: (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">I want a highway beast and full boost by 6.5k revving to 7k. lol j/k. I'm still looking for a 12cm2 housing. From the looks of it the 9cm2 will die up top.</TD></TR></TABLE>
That is why I recommend a 44mm wastegate with the smaller turbine housing. The oversized wastegate will allow the backpressure to come down considerably. I have seen around a 15-25% drop in backpressure in going from a 38mm to the 44mm and the HP went up about 5-10% too.
Old Jan 11, 2007 | 03:38 PM
  #1508
tyrone27's Avatar
Default Re: (TTT)
ok found a Holset HC1 Turbo with a 16cm3 for 300 bucks. anyone have any positives or negatives about it?
Old Jan 11, 2007 | 05:42 PM
  #1509
SwappedTURBOegg's Avatar
https://honda-tech.com/zerothread?id=1861531
Old Jan 11, 2007 | 08:02 PM
  #1510
Jockobo's Avatar
Default Re: (SwappedTURBOegg)
my 12 cm housing drops off power at 6600 on my ls...with the 14cm it keeps all the way to the 7400 rev limit i had on it...i couldnt imagine using a 9cm housing...
Old Jan 11, 2007 | 09:40 PM
  #1511
SL0WEGG's Avatar
Default Re: (Jockobo)
really? Interesting.
Old Jan 11, 2007 | 10:07 PM
  #1512
Minor Threat's Avatar
Butt dyno or real numbers?
Old Jan 12, 2007 | 03:08 AM
  #1513
tyrone27's Avatar
Default Re: (Minor Threat)
hmm when does it make full boost?
Old Jan 14, 2007 | 12:06 AM
  #1514
SL0WEGG's Avatar
Default Re: (tyrone27)
Good news, Just bought a 12cm housing for 50 shipped! Anyone want a 21cm housing
Old Jan 14, 2007 | 12:21 PM
  #1515
gokhan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">Good news, Just bought a 12cm housing for 50 shipped! Anyone want a 21cm housing </TD></TR></TABLE>
can you say what is written on the housing?
Old Jan 14, 2007 | 07:22 PM
  #1516
SL0WEGG's Avatar
which one? the 12cm or the 21?
Old Jan 15, 2007 | 03:13 AM
  #1517
disamis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">which one? the 12cm or the 21?</TD></TR></TABLE>
i need 12cm pls...
Old Jan 15, 2007 | 03:51 AM
  #1518
deeweezy187's Avatar
Default Re: (disamis)
which holset turbo do you guys think i should get for a f22b2 accord with pistons and rods looking to get 300 on 15 psi and 400 later on down the line when the engine gets fully built?
Old Jan 15, 2007 | 05:32 AM
  #1519
gokhan's Avatar
the 12cm one please
Old Jan 15, 2007 | 10:34 AM
  #1520
Bboy_Trevstuh817's Avatar
I join the holset thread I got my H1C for $60 now im looking for the info on it lol.
Assy: 3528918
Serial: H-395793
Custoer: 3528918-1-10/0
Type: H1C
Old Jan 15, 2007 | 01:17 PM
  #1521
boosted_crx's Avatar
On a map that i was playing around with. I have to go back and complete the final tune. This pull was at 18psi and the A/F were still in the 10's with 1000cc injectors and excessive timing pulled to be safe.
The lower graph was the run i did at 10psi to give a difference on how much of a power difference there is with an 8psi increase.
Ill post build specs later, but speedave knows me and knows the build. its a LSVtec built, with a Holset HY35 and Trust 50mm wastegate.
until next time...
Old Jan 15, 2007 | 01:19 PM
  #1522
Sry, i should mention that in the civic, shell you can really see the turbo anymore with the way the dump runs for the wastegate, however below is a pic of the stove in my crx shell before it decided to meet a hwy barrier.
You can see the turbo nicely hanging around and having a good time there.
Old Jan 15, 2007 | 10:47 PM
  #1523
SL0WEGG's Avatar
Default Re: (boosted_crx)
What color is that? nice numbers. Another question, Why are you running conservative timing and afr's on a built motor?
Old Jan 15, 2007 | 10:56 PM
  #1524
Here are some pics of my turbo I did the work myself:
Old Jan 15, 2007 | 10:58 PM
  #1525
KeyserSoze's Avatar
Why so rich? I would guess that is really hurting your power. Looks like you did ~238whp @10psi. I did 315whp @11psi and I know that it is a fairly conservative tune as well. No cam gear adjustments made, 3" exhaust w/cat, hy35 as well. Nonetheless, I bet its a fun car to drive.
