Holset users unite!
Old May 8, 2011 | 03:29 AM
  #3276
MoreCowbell's Avatar
Default Re: Holset users unite!
Anyone hear of a Vgt controller for Neptune or Crome? I should ask on thehttp://turbobyholset.com forum but figured I would check here to see if someone chimes in faster.
Old May 8, 2011 | 04:42 AM
  #3277
mar778c's Avatar
Community Builder
Community Influencer
Originally Posted by fmfkid250
Went to the track 11.37@123 11.5@124 11.4@122
update went 11.25@125.00 and 11.27@125.00
That is getting it done.
Old May 8, 2011 | 02:54 PM
  #3278
wantboost's Avatar
Who is Mr Robot?
The smaller hx35 map is what you need, its not 100% but its close enough
Old May 11, 2011 | 11:02 AM
  #3279
RyaN95i4's Avatar
Just out of curiosity, what are HX40's going for nowadays?
Debating a part out... Has a BEP turbine housing on it as well...
Old May 15, 2011 | 07:06 PM
  #3280
Bseriescivic5's Avatar
What size is the oil feed fitting on a holset HE351cw Im stumped trying to get this figured out. Thanks.
Old May 16, 2011 | 04:17 AM
  #3281
fmfkid250's Avatar
What i do for all the holeset turbos is just get an OEM one from the dodge dealer and I drill and tap it for 1/8npt. Works everytime perfect.
they are like $10 and usually can get them next day..
Old May 16, 2011 | 07:21 AM
  #3282
Thanks Joe, ill look into that. You dont think ATP turbo will have something for this? Spent too much time this weekend trying to find something to fit... these must be one off or something. Also, do you need to run a restrictor for these? The holset manual said they can see no more than 75psi at WOT which I think my motor will prob have more pressure than that. I was thinking a .08 restrictor? Thanks again. May be contacting you soon for a tune if everything goes well..... built motor got destroyed by a bad tune few months ago and put this setup together thereafter.
Old May 17, 2011 | 06:35 AM
  #3283
fmfkid250's Avatar
No problem. A friend told me he figured it out its a part abled to be ordered by the parker store. I find it way just as easy to drill and tap. I had a few sitting up here at some point but they are now gone.
If your running a -3an line I wouldent worry about running a restrictor. I have done 5 or 6 HE341/HE351 cars now and none ever smoked. My girl friends car had a 341 on her car for over a year now daily drivin. out of an oil sandwitch no smoke. what so ever and her gauge pegs 100 when its cold.
Old May 17, 2011 | 09:21 AM
  #3284
Ok sounds good. Thanks Joe. Now just need to get some injectors and im ready to tune. I have a set of 950cc PTE's if any of your customers need, ill let get dirt cheap to help fund my ID1000's; As a point of reference, ProTrucks out in murrysville was able to get the feed fitting for the turbo.
Old May 17, 2011 | 06:53 PM
  #3285
mar778c's Avatar
Community Builder
Here's my addition to this thread.
Old May 17, 2011 | 08:02 PM
  #3286
wantboost's Avatar
Who is Mr Robot?
read the thread....
Originally Posted by wantboost
Some were 12x1.5, mostly the hx and hy. It either takes the 12x1.5 with an o-ring under the fitting or it's 1/8 bspt
Old May 18, 2011 | 06:30 AM
  #3287
read the thread....
Thanks.
Old May 18, 2011 | 12:28 PM
  #3288
methodz55's Avatar
quiick question anybody using a spa cast top mount with a holset looking at a hy35 for my ls with spa top mount wanted to see if it would fit
Old May 18, 2011 | 02:36 PM
  #3289
ashb82's Avatar
what the setup on this
Old May 18, 2011 | 03:47 PM
  #3290
mar778c's Avatar
Community Builder
see link
https://honda-tech.com/forums/forced-induction-16/stg-1-boosting-my-hatch-fab-mainfold-2888738/
Old May 30, 2011 | 04:36 PM
  #3291
GsrRussell's Avatar
Anyone running a BEP housing. Where are you buying them?
Old Jun 7, 2011 | 02:15 PM
  #3292
hardcore97's Avatar
just curious, my hx35 was internally gated, any ideas on what to do with the empty spot on the compressor housing now? what size fitting would it take to screw in there so i could run a line from it or something? all ideas are appreciated
Old Jun 21, 2011 | 07:16 PM
  #3293
DS00ITR's Avatar
also interested in this. is anyone running a hx35 with the BEP t3 housing. i have a seven blade hx35 and i am having boost creep with a 38mm wastegate. thinking of trying this housing to help that and increase spool time. just curious if anyone has any experience with this.
Old Jun 23, 2011 | 04:18 PM
  #3294
Wyatt.Earp's Avatar
HOLSET FOR LIFE
Old Jun 23, 2011 | 09:38 PM
  #3295
boosted920's Avatar
LAG 4 LIFE
haha just messin with ya. I'm sure I'll end up running one in the future
Old Jul 10, 2011 | 07:57 PM
  #3296
wantboost's Avatar
Who is Mr Robot?
Im debating about picking up an hx52... just worried it will be stupid laggy on my ls/vtec... even with a divided manifold and housing.
opinions?
Old Aug 4, 2011 | 03:31 PM
  #3297
dirtyharryhatch's Avatar
A Digital Frontier
So you guys are running a divided manifold?
Old Aug 4, 2011 | 08:20 PM
  #3298
boosted920's Avatar
wantboost
opinions?
hx52 is wayyyyyyyy overkill for your setup. stick with an hx/hy35. hx52 is MAYBE ok on a v8 or built 6 cylinder. if it's free, sell it or trade it for something smaller
Old Aug 17, 2011 | 03:40 PM
  #3299
93egboosted's Avatar
im using the hx35w, i grinded down the orignal vband in order to fit a silicone coupling to feed into my ic, my question is the outside diamter is to small for a 2.5 coupling and to big for a 2.25 coupling? should i get a 2.25-2.5 coupling and stretch it? any ideas apprieacted
john
Old Aug 17, 2011 | 04:27 PM
  #3300
ashb82's Avatar
i ground very little off my flang. ground it till i could get 2.5 coupling on it.
