Holset users unite!
Old Oct 21, 2007 | 11:48 AM
  #2026
b18tegg's Avatar
Default Re: (Chiovnidca)
I was thinking of buying a new hx35 on ebay that was missing the compressor wheel.
But i was outbid by 2 dollars.
I found an hy35 comp wheel here on honda tech for 50 bucks brand new.
If it had worked out.... I would of had a new hx35 for 220 bucks. o well maybe i can get another good deal..
Might get a new hc1 for 250. ill keep you guys updated.
Old Oct 21, 2007 | 12:55 PM
  #2027
Minor Threat's Avatar
I am running an HY35 on my A6. I make a few pounds by 3000rpm, 18 psi around 5400-5500. It spools a few pounds very quickly and the rise in boost is very very smooth and gradual. It isn't like the typical on/off switch big turbos.
So far I'm really happy with it, I probably won't push the setup until next spring though as winter is coming soon here. The record on a gas application with the HX35, which through my research I have found to have a nearly identical compressor but larger turbine is 550WHP, so even if the HY makes a little less than that it's still more than enough IMO, especially for the price you can pick these units up for.
Old Oct 22, 2007 | 07:15 AM
  #2028
b18tegg's Avatar
I've been reading through all 82 pages but havent seen anything about the he351..
I'm thinking of buying one, but i dont like the idea of a 4 inch down pipe. does anyone know if I can use an hx35 or hy35 exhuast side with 5 bolt 3 inch v band?
Old Oct 22, 2007 | 05:32 PM
  #2029
holset b18c's Avatar
Default Re: (b18tegg)
you can only use the hy-35 exhaust housing!!! cuz its a clamp style housing ,unlike the rest of the holset turbo's that are bolt styles!!
Old Oct 23, 2007 | 01:50 PM
  #2030
GEN2 LS's Avatar
Loved
Default Re: (holset b18c)
anyone know where I can find a hx-30 or hy-35 for my LS motor? I've been looking on ebay and the honda marketplace and can't find any for sale.
Old Oct 23, 2007 | 02:58 PM
  #2031
90dxhmt's Avatar
Default Re: (GEN2 LS)
Check local diesel forums as alot of guys upgrade and sell there stock low mileage Holsets for reasonable price.Call some high performance diesel shops as well tell there what your looking for just dont mention its for a Honda or the might hang up on you or double the price
Old Oct 23, 2007 | 05:30 PM
  #2032
Dr. D-Series's Avatar
Anyone know where to get an oil feed line for an older H1C ?
My brother got one cheap for his b16 and needs a feed and drain flange.
My H1C on the d15 came with the stock feed which is working great.
And btw made 202.7 whp @ 10-11 psi. Non intercooled haha.
Old Oct 23, 2007 | 07:00 PM
  #2033
hybridpatient95's Avatar
hey guys. im new to this holset game. can you tell me which holset would be equvilent to a 35r or t3/t67? thanks
Old Oct 23, 2007 | 09:42 PM
  #2034
Default Re: (hybridpatient95)
HX-40 IS LIKE A GT-42 SO THAT WOULD MEAN ITS BIGGER THAN GT-35
NO TO SURE ABOUT A T3/T67!!
Old Oct 23, 2007 | 11:33 PM
  #2035
blundar's Avatar
Actually, no.
You're talking more like a HX50/HX55 to compare to a GT42R.
A HX40 is probably close to a 35R in terms of flow - maybe a little less. It's really not THAT much bigger than a HX35. Think of it as a SC61 on steroids that spools a lot faster
Old Oct 23, 2007 | 11:40 PM
  #2036
SwappedTURBOegg's Avatar
yea my 40 is only a 60mm. i may do a 55 next season. thats 72mm. 160mps or bust!
Old Oct 24, 2007 | 02:31 AM
  #2037
thats guys. what kind of spoool can i expect out of a 50 with say a 2.2L motor?
Old Oct 24, 2007 | 03:56 AM
  #2038
i remember when people use to ask the same thing about the 40. no one knew so i tried it out. maybe you should try something on your own.
Old Oct 24, 2007 | 05:54 PM
  #2039
i will try it. but my motors not even ready nothing is. might take a while lol
Old Oct 25, 2007 | 06:22 PM
  #2040
b18tegg's Avatar
so what do you guys think about the he351?
heard its the same as the hy35..
but also its like a hx35/40.. so i've gotten mixed reviews.
here is the one im getting..
Old Oct 25, 2007 | 06:40 PM
  #2041
CivicVX94's Avatar
what the hell kinda compressor cover is that??? homemade ported shroud? lol I like it
Old Oct 25, 2007 | 06:46 PM
  #2042
b18tegg's Avatar
Default Re: (CivicVX94)
I dont know.... I've searched and searched but thats the only one i've found.
all others look like regular hy35's. i just hope it isnt fake.
  #2043
just looks like a silencer drilled out to me.
Old Oct 25, 2007 | 06:48 PM
  #2044
b18tegg's Avatar
Default Re: (SwappedTURBOegg)
silencer was removed...
Old Oct 25, 2007 | 06:51 PM
  #2045
b18tegg's Avatar
i might have read wrong but here is another he351 that he is also selling...
Old Oct 25, 2007 | 06:56 PM
  #2046
b18tegg's Avatar
here is a close up...
if it is a silencer ring. thats freaking thick..
Old Oct 25, 2007 | 07:00 PM
  #2047
b20vtechb's Avatar
i'm going to be running an hx52 next season should put down some good numbers.
compressor wheel is 71mm inducer 100mm exducer. exact same specs as some of the gt42r's
all these pics are comparing against an hx35
Modified by b20vtechb at 8:21 PM 10/25/2007
Old Oct 25, 2007 | 07:06 PM
  #2048
b18tegg's Avatar
Default Re: (b20vtechb)
at work (heavy equipment operator) I operate huge farm(case steiger stx430) tractors with 2 big scrappers behind it.. digging big holes and building big grade hills
anyways they have holset hx55 turbos.. and those things are freaking huge.
hx52 isnt that much smaller. i can only imagine how big it is.
Old Oct 25, 2007 | 07:24 PM
  #2049
b20vtechb's Avatar
yeah i think the 55 has a 76mm inducer.. but the great thing about the 52's is they still have a small exhaust side only a 16cm3
Old Oct 26, 2007 | 08:43 AM
  #2050
THIS IS THE HE351CW THAT I HAVE !!
THIS IS THE ONE THAT COMES WITH SOME TYPE OF
ELECTRONIC BOOST SOLENOID!!
Modified by holset b18c at 1:32 PM 10/26/2007
