Holset users unite!
Old Oct 7, 2011 | 08:50 PM
  #3326
BoostedEgHatchFl's Avatar
Default Re: Holset users unite!
What would be a good turbo for a built sleeved b16 stock head with itr cams. Looking for 400+ on pump and 550-650 on race gas
Old Oct 8, 2011 | 05:37 AM
  #3327
fmfkid250's Avatar
PTE 6266
I dont think any holset would fit that application...
Old Oct 8, 2011 | 08:07 AM
  #3328
mar778c's Avatar
Community Builder
Community Influencer
Originally Posted by Bseriescivic5
The drain is a standard t3 fitting, and the feed is a 12mm by 1.5 pitch, then just add your -3an feed or -4an, whatever you want.... I think Im using a 4AN
X2. I'm using a -4AN line for the drain.
Old Oct 8, 2011 | 11:24 AM
  #3329
Garage 808 Hatch's Avatar
Originally Posted by fmfkid250
PTE 6266
we made those numbers on a HY35 on a forged internal B16. 430 on 92, and 545 on race gas
Old Oct 14, 2011 | 06:59 AM
  #3330
fmfkid250's Avatar
I was looking his 650 number.
Old Oct 15, 2011 | 12:31 PM
  #3331
a1320honda's Avatar
Havent posted in here for a while, thought id throw a coulple things in.
My civic went 10.8@128 a couple years back when my Ebay 60-1 took a dump and i threw the HX35 on it just to get down the track. The car with the 60-1 was trapping 138 at 20psi and pump gas and switching to HX35 lost 10mph and had to really work on my short track to get the car back in the 10's on pump gas and 20psi.
My buddy/customers car has come a long way and is a true budget build.
EM1 100% stock full interior and power steering.
Stock LS tranny
stock sleeves
SRP pistons
Eagle rods
Ebay: Manifold, fmic, wastegate, 2.5" charge pipe kit
HX35 12cm
3" downpipe, full exhaust with cat and muffler.
23" slicks
Managed a bunch of 1.66 60ft's with a best ET of 11.4@121 at 364whp. Got on the dyno and made 466whp on 19psi with a mix of 92/110 gas. Never made it back to the track with the 466hp but if we had we were looking for a high 10 second pass.
http://www.youtube.com/watch?v=CMt2T6SSza0
http://www.youtube.com/watch?v=pTiLIPAv4mQ
Old Oct 15, 2011 | 02:49 PM
  #3332
hardcore97's Avatar
just a question, on the hx 35's which side is the oil inlet and which is the outlet?
Old Oct 16, 2011 | 04:05 AM
  #3333
a1320honda's Avatar
The side with the square opening and 2 threaded bolt holse is the "OUT" or standard T3 return flange...the single opening thats threaded is the oil "IN".
Old Oct 28, 2011 | 06:23 PM
  #3334
XSboosted10's Avatar
Just purchased a hy35 for my hatch. I have a fully built b16, stock sleeves, 255 pump etc, I think ima pick a set of 1000cc injectors up and get rlz to tune it. Its currently on a t04e ebay junk turbo making 302whp and im not happy with it. My goal is 400whp. Any input?
Old Nov 5, 2011 | 09:11 PM
  #3335
deeweezy187's Avatar
will this work with a h1c?
http://www.ebay.com/itm/Holset-HX35-...7#ht_768wt_932
Old Nov 7, 2011 | 01:52 PM
  #3336
rebel1988us's Avatar
i just picked up an H1C anybody have an opinion on what injectors, manifold that have the turbo all the way of the radiator, front mount kit? this is going on an LS swapped Crx not wanting much more than 300whp. 325-350 at the most. i still want to drive it to an from work.
Old Nov 7, 2011 | 03:25 PM
  #3337
sosxbmx's Avatar
so ive got a stock b16a2 w/ gsr trans and im gettin ready to run a holset hx35/40 hybrid on it. i was wondering how spool time is and how daily driveability is.
Old Nov 8, 2011 | 05:05 AM
  #3338
scottdh20's Avatar
i love the drivability of mine (hx35 8-blade).....its basically n/a....when you want to have fun you have all the power a fwd street car could handle.....
i do have a d16 but i dont think it'd be too different, i used to have a small turbo set-up didnt matter what gear i was in in i mashed the throtal it spooled right up now the biggest thing is dropping it in the right gear when cruising to have fun......for example at 60mph in fourth or fifth you really need to down shift to third, you cant just push the pedal it will lag pretty bad....i'd normally never think to downshift to third on the highway to do a pull cruising at 65.....but you got to..... if i mash it from the light first gets some boost and second just about build full if not builds full boost...i ganny shift on the street it'll drop like 3-5psi but almost instantly picks it right back up
edit: and i love on a clear sunny warm day you do a pull in third.....3k-nothing...4k start to sound like a jet engine and pulls a bit stronger.... 5k- start geting pulled into your seat.... 6-k your *** is planted and your tires just break loose..... i have a duel stage boost controller so i can flip the swith between 16psi and 22psi(currently plan on mid to upper 20's) over 16 the tires just break loose on dry pavement
Old Nov 8, 2011 | 06:33 AM
  #3339
sosxbmx's Avatar
yeah ive heard from quite a few people when it comes alive your tires fade out quick. thanks for the info
Old Nov 13, 2011 | 05:38 PM
  #3340
sosxbmx's Avatar
so im wondering, there's a lot of b16a holset hx35's on here and the majority have the exhaust cam adjusted out, ive gathered that it has something to do with spool time, how much are yall adjusting out, and how much is it helping spool time
Old Nov 18, 2011 | 10:15 AM
  #3341
Bseriescivic5's Avatar
What do you mean by "adjust it out" you talking swapping cams or changing overlap via adjustable cam gears?
I use Stock GSR cams on my setup, and so far works great. stock cams are fine if your only looking for like 400whp
Old Nov 18, 2011 | 10:38 AM
  #3342
a1320honda's Avatar
All depends on the cams in question. Most stock cams arent gonna pick up significant HP with adj. cam gears and adjusting them. Were talking like 5hp if that. Aftermarket cams is where adjusting the cams gives you the benefits.
Old Nov 18, 2011 | 12:52 PM
  #3343
sosxbmx's Avatar
by adjusted out yes i meant adjusted by a cam gear, im not looking for huge power im looking to spool my holset faster,
Old Nov 29, 2011 | 06:40 PM
  #3344
Anyone know where I can get a bolt on downpipe for my holset setup? Nobody around here can fab one for me and I dont have the means to do it myself right now.
Old Nov 29, 2011 | 07:12 PM
  #3345
93ls10.0's Avatar
I run a big comp h1c with a 12cm ex on my ls. its fun 18psi by 4k isn't bad. When it does hit this thing is strong.
Old Nov 29, 2011 | 07:15 PM
  #3346
hardcore97's Avatar
theres a guy on ebay who sells the flanges, then you would just need it welded to a DP
Old Nov 29, 2011 | 08:22 PM
  #3347
phatrick2332's Avatar
What kind of power can be expected from a d16 with hy35?
Old Nov 30, 2011 | 11:31 AM
  #3348
del_sol_freak's Avatar
I wonder if a J-series has enough rev to get one of these spooled up. Sick of only have 300hp.
Old Nov 30, 2011 | 12:43 PM
  #3349
scottdh20's Avatar
i think what you mean is that you wonder if a j can spin two of them
if my d16 can spin it your j can def. spin it
and flanges are all over the place....i got lucky cuz mine cam with the stock v-band flange so that was easy
Old Dec 1, 2011 | 05:21 AM
  #3350
fmfkid250's Avatar
The turbos are so cheap I usually just weld the downpipe right on.
