Holset users unite!
And... minty HY35 on the stockpile chopping block. Get it while you can.
http://hondamarketplace.com/showthread.php?t=2774350
HY35 holset be able to make around 600hp? I'm in the market for a turbo,and i have been trying to do some research but i havent found anyone making that kind of power off of one. ANy info ?
HX35 on a fully built LS w/ Crower 404 cams 464HP 321 torque on an AEM EMS @ 15lbs on 93 octane
@ SwappedTurboEgg
Car is looking awesome - let us know as soon as you give that HX52 some boost !!
@ 7psi that Turbo is probably not even on the map yet !!
I'm going to be running a B18C1 in a 95 civic coupe. 9:1 CP pistons, eagle h-beam rods, skunk2 pro series intake manifold, and to top it all off...A HOLSET HY35 TURBO.
I haven't decided on an exhaust manifold yet. Any suggestions?
im looking for a HY35, HX35, or HX40 so i can start gathering parts for my build. 15-18psi w/E85 on a stock JDM GSR w/ ARP head studs want 400-450whp stock block. I know im going to have to sell my 550s that im currently using with my JRSC. Also looking to get a Victor X.
i ran a hy35 on my old dsm but got a borg s256 off a cat truck and seen a big diff on the spool the borg hit full boost at around 3600 3700 on a 2.0 vs the holset at around 3900 4000
is anyone using the BEP housings for the HX35? i've been looking into the T3, but i don't know if it would be any advantage to me using their smaller, undivided T3 housing, as i have the divided twin scroll 12cm housing now..
any info? TIA!
any info? TIA!
not TOO laggy, just want less lol..
My IDEAL design would be the BEP .55a/r turbine housing in a twin scroll design, but they don't make them, and the guy i emailed there said it would be too restrictive, so they won't make it..
i like the manifold, but the way i made the DP, i have to **** the radiator, and it gets fawkin hot down here in SC, so it's rough driving right now with 108* temps during the day..
i have a h1c than i plan on using on a b18b1 motor with just a built head. I also want to only run 11 psi with the upgraded 12cm housing. Will the upgraded housing make the car more streetable. Also how important is it to run a twin scroll mani with this turbo and can i get away with runnning a single scroll mani?
can these turbos be ran on a single scroll manifolds and i have a h1c turbo and i want to get the 12cm housing upgrade and run 11 psi on a stock block ls with a built head. will i see me goal of 260whp.
